Question about Panasonic KX-FL511 Plain Paper Laser Fax
I have an error code call service 1 in panasonic
Error code call service 1
Ricoh 1813. Error code c551
The Ricoh copier error code SC551 / 551 is a fusing thermistor 1 error code.
It can mean:
1. The thermistor is not connected
2. The thermistor connector is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Oct 03, 2017 | Ricoh Office Equipment & Supplies
Tip
How to resolve Cannon ir400 Error e004
<span>Hi,<br /><br />For error code E004-001 or E004-002<br /><br />Cause:<br />The SSR has a short circuit.<br />&bull; The SSR has an error.<br />&bull; The DC controller PCB has a fault.<br />The heater relay has an error.<br />&bull; The heater relay has an error.<br />&bull; The DC controller PCB has a fault.<br /><br />Description:<br />&bull; The fixing heater remains<br />on.<br />&bull; The fixing temperature has<br />increased abnormally.<br />The heater relay remains on.<br /><br />FIRST TRY TO CLEAR ERROR:<br />Resetting Errors<br />1. The following error codes cannot be reset by merely turning off and then on the main power.<br />They require resetting in service mode:<br />E000, E001, E002, E003, E004, E032, E717<br />1) Start service mode, and select COPIER&gt;FUNCTION&gt;CLEAR&gt;ERR.<br />2) Press the OK key.<br />3) Turn off and then on the main power.<br />2. Error codes other than the above may be reset by turning off and then on the main power.<br />n Detail Code<br />Some error codes offer detail codes, which may be checked in service mode:<br />COPIER&gt;DISPLAY&gt;ERR (3rd block from the right)<br /><br />SERVICE MODE: <br />1) Press the asterisk key ' * ' on the control panel.<br />2) Press '2' and '8' on the keypad at the same time.<br />3) Press the asterisk key ' * ' on the control panel.<br /><br /><br />If these doesnt helps, you need to call service to locate the fault, which is probably bad thermistor.<br /><br />Hope that helps!<br /></span>
on Feb 06, 2011 | Cannon i70 Printer
Error code C3806 konica bizhub 5500
Recommend a tech do as this is straight out of the service manual. "DipSW3-1 of service mode to 0. If DipSW3-1 is set to 0 before defective parts are fixed, it may cause fire."
Feb 05, 2014 | Konica Minolta bizhub Office Equipment &...
Microboard error code 306
The 306 Error Code is generated when any corresponding process or operation could not be completed successfully by the application.
error 306 may prevent the user from performing the required action or may the application will close unconditionally.
Technical (Deep) Description of Error Code 306:
This is a full Description of ERROR 306:
ERROR 306: MCIERR_DEVICE_NOT_INSTALLED.This error is due to .The default facility code
ERROR 306: EVENT_APPMGMT_UPGRADE_COMPLETE.This error is due to Application %1 from policy %2 successfully upgraded application %3 from policy %4..The default facility code
ERROR 306: SQL_306_severity_16.This error is due to The text ntext and image data types cannot be compared or sorted except when using IS NULL or LIKE operator..The default facility code
ERROR 306: ERROR_SECURITY_STREAM_IS_INCONSISTENT.This error is due to The security stream for the given volume is in an inconsistent state. Please run CHKDSK on the volume..The default facility code
ERROR 306: CO_E_LOOKUPACCNAMEFAILED.This error is due to The system function LookupAccountName failed .The source of the error code is an RPC subsystem.
ERROR 306: STATUS_LOGON_SERVER_CONFLICT.This error is due to The Netlogon service cannot start because another Netlogon service running in the domain conflicts with the specified role. .The default facility code
Fixing Error 306 manually is a difficult process and it is not recommend unless you are an expert in this field.
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if you need more help with this post a reply with the error message details
hope it helps
Jul 13, 2012 | MicroBoards CFD-USB-15 1 Read,15-Port USB...
Error code is call service 3 on the Panasonic fax kx-fl422
You need to contact Panasonic Service personnel to resolve any error code that begins with "call service." Please call or e-mail using the following contact information:
Obtain Product Information and Operating Assistance; locate your nearest Retailer/Dealer or Service Center; purchase Parts and Accessories; or make Customer Service and Literature requests at:
http://www.panasonic.com/help
E-mail Panasonic tech support via:
http://www.panasonic.com/contactinfo
For in Limited Warranty programming and Troubleshooting Support:
Office Advantage assistance and Service Location finder: 1-800-211-PANA (7262)
If the Limited Warranty has expired, contact Continued Services Technical Support Line at 1-800-435-7329, for fee based technical support. A credit card will be used to charge this fee.
Mar 07, 2011 | Panasonic Office Equipment & Supplies
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dp 2000 pm error code e04-01 need help
this is fixing error
enter the service mode
f9
enter
Apr 02, 2010 | Panasonic Workio DP-2000P Copier
Service 900 error message
900 Error Code service check
1 Printer POR
Turn the printer off and on several times. If Error Code 900 continues
to display, go to step 2.
2 System board
Make sure the system board is properly seated in connector J7 on
the interconnect board.
Turn the machine off and on several times, waiting a few minutes
between power on and power off.
If Error Code 900 continues to display, go to step 3.
3 Factory defaults
Restore factory defaults. See “Restore EP Factory Defaults” on
page 3-18. This resets the non-critical areas of the user NVRAM. If
Error Code 900 continues to display, go to step 4.
4 Sub error codes
With Error Code 900 displayed, press Select and Return. Record the
complete list of Sub Error Codes on the display. Check the “Base
printer sub error codes” on page 2-6. If none of the Sub Error
Codes are listed, then call your next level of support.
From page 2-41 of IBM's service Guide
Feb 15, 2010 | IBM Infoprint 1352 Laser Printer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Error code 1 comes up when i access my mailbox
    Error Code 1
    Most likely this is temporary issue that will soon resolve itself. "Error Code 1" is generally caused from having multiple browser windows open or multiple tabs within the same browser open to your Yahoo! Mail service.
    If you are still receiving the error code, please try the following:
    1. Log out of Yahoo! Mail.
    2. Close all web browsers.
    3. Restart a web browser and log into Yahoo! Mail.
    Dec 19, 2009 | Yahoo Mail
    Panasonic KX-FL511 Plain Paper Laser Fax Logo
    601 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
