Question about NAD T532 DVD Player
Dvd t532 can not switch of
The issue is, I can only switch the DVD to stand by or to be ´on´ (red and green), I want it however to switch of entirely, as I have a remote control (an LG) that also works on the NAD. If I control the LG, the NAD reacts as well. There would be no issue if I could switch the NAD off entirely, as well as save electricity. Is there a way I can do this except for pulling the plug?
Thanks,
Mark
  • 3 Answers
Nad has become garbage, follow me?
Posted on Jul 22, 2009
Dvd playing in black and white only???
Most commonly with this unit there is a compatibility issue with PALS or NTSC Formatting. Make sure the DVD player, DVD itself and the TV unit are all compatible. Also, since this unit commonly comes with the Standard Red, White, and Yellow Video/Audio Cables, Try switching to the Composite Cables. (Red, Green, and Blue-generally). This should fix the incompatibility issue. Hope this helps
Sep 29, 2010 | Panasonic DVD-S47 DVD Player
We're not getting any sound from the dvd's. I have two cables (green/blue/red) and (red/white). but I'm at a loss how to connect from DVD to TV. Help please!
If your TV has the green, blue, red inputs then connect these 3 cables for the picture. DVD to TV, green to green, blue to blue and red to red. If your TV only has a yellow input, then connect the green cable only from the DVD yellow to the TV yellow. Now for the sound. Connect the DVD white to the TV white. Connect the DVD red to the TV red with the red cable. The white and red inputs will be next to the yellow and the green, blue, red inputs on the TV. Next select the TV input using your TV remote. Select the input for the DVD connection.
Sep 04, 2010 | Sony DVP-NS400D DVD Player
The only connections that work are the component cables(color stream, RGB-Red, Green, Blue) which I understand is a better quality picture but the connections for my DVD player are RCA (Composite - Red,...
You'll need a DVD player that has component outputs. The composite carries the entire video information, while the component sends the three different color signals separately. The red and white cables are output cables. No all DVD players have the component outputs.
Jan 27, 2010 | Hitachi 43FDX01B TV
I have a Home theatre DVD SC-PT460. Turned on this morning and the red stand by light is on but i cannot get it to come on?
the power supply in your DVD player may not have the proper voltage to the electronic switch and therefore the processor is in standby to protect the device.
Or you may have a remote that has left the unit in standby mode. check the user manual to see if this is the fact.
Checking manufacturers site in knowledge base usually has the solution for a "stand by mode" issue.
Or call and talk to a technical support rep.
Jan 23, 2010 | Panasonic Televison & Video
Need replacement disc tray for NAD T532
The link below is the source for NAD parts and support.
http://nadelectronics.com/parts-service
Jerry G.
Jan 17, 2009 | NAD T532 DVD Player
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
NAD T532 probem
CD and DVD disks use a different set of optics for each type of operation. Some units have a different laser for the different format types.
The fault could be mechanical alignment, calibration, or a failure in the signal and or processor path. These types of faults are impossible to guess at.
If the unit is under warranty, contact the dealer to find out how to get it serviced. If out of warranty it may not be feasible to service.
Jerry G.
Dec 02, 2008 | NAD T532 DVD Player
Memorex DVD player problem
Hit the PSCAN switch on the back of the unit.
Aug 09, 2008 | Memorex MVD2042 DVD Player
DVD player do not turn on
My JBL Cinema ProPack 600 System is stuck in stand bye mode (amber light). Anybody know how to resolve this problem?
Feb 15, 2008 | JBL Cinema ProPack 600 System
Component conecters
alright...those are Component Connectors...your DVD, and VHS will not work with that Monitor at all.
The Best and Cheapest Option...is to Buy a "Modern" DVD Player...which almost every single one Has Component Connectors.
On your Current DVD, VHS...ECT. The Red and White is Audio respectively, and the Yellow is the Video.
On a Component However the Red, Blue, and green...are all Video. You will need to use your "Current" Red and White Audio Jacks from your DVD and VHS Players on your New Monitor, and New DVD Player.
As Far as VHS is concerned...if you Buy a DVD/VHS Combo...you should have a S-Video Jack on Both the Monitor, and the DVD/VHS Player...Buy a S-Video Plug.
With that you will be able to watch both DVD's, and VHS Tapes without issue
Nov 26, 2007 | MegaVision MV220 Monitor
NAD T532 DVD Player Logo
120 people viewed this question
Top NAD Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Raj Patel
 Grubhead
Grubhead
Are you a NAD Televison and Video Expert? Answer questions, earn points and help others
