Question about Sony Alpha DSLR-A200 Digital Camera
Just want to have a cleaning kit for my sony alpha200 dslr and its lenses. can you recommend a specific brand?
4 Suggested Answers
  • 11 Answers
SOURCE: sigma 70-300 +''no lense attached'' w/ sony a200 dslr
Unfortunately, there are electrical differences between early and later Sigma lenses. Although the bayonet connection is the same, and the lens can fit, it will not necessarily connect electrically with the connections on the camera. Sigma can modify the lens for you, but this can be quite costly, and you may be cheaper to look for an alternative lens.
Posted on Mar 15, 2009
ripleymojica
  • 643 Answers
clean brass contacts with qtip and rubbing alcohol. let air dry couple of hours. do the body and the lens. hope that helps
Posted on Jun 02, 2009
  • 58 Answers
SOURCE: The lens kit of my Sony DSLR A200 produces noise
If it's in continuous auto-focus and doing it, then it is just not locking on to one thing and jumping back and forth between two objects that are very close together in distance and it is normal. It should stop in manual, single shot or single point auto-focus. Sony uses Nikon auto-focus technology and my D-300 with a 70-200mmf2.8 will do it if I turn the auto-focus tracking time(lock-on) all the way down with the auto-focus in full auto.
Posted on Oct 01, 2009
Testimonial: "Thanks for the info"
Sigma 28-300mm f/3.5-6.3 DL Aspherical IF Hyperzoom Autofocus Lens for canon slr compatible with Canon t3i dslr
Sigma produces lenses for different brands of camera's. The optics are the same, but the connection differs from brand to brand. So if you have a Sigma lens for Nikon, you won't be able to use it on a Canon or Sony. Unless you buy a adapter. But when you start using an adapter, you will lose the Af in most cases, because the electronic in the lenses differ also. and that can't be bridged.
Dec 14, 2013 | Sigma 28-300mm f/3.5-6.3 DL Aspherical IF...
What DSLR to use with Tamron AF 28-200 and 200-400 lenses
Hi, all the Sony Alpha dslr's will work on these lenses, try to get a newer model, most of these older lenses are as good if not better than the new kit lenses that come with cameras now
Jun 20, 2012 | Tamron Cameras
How to mount Quantaray 70-300mm F/4.0-5.6 Zoom Lens in Sony Alpha DSLR?
This 3rd party lens (like all of them) makes lenses specifically to fit Nikon, Canon, Pentax, Minolta, etc. camera body mounts. Each has a style mount that is unique. You can not simply mount a lens made for use on a Nikon body on a Sony body.
In order to use this lens, it MUST be the model designed for use on a Sony camera. Functionally, the lens will be nearly identical on any camera it is designed to fit, only the mount (the portion that actually mates to the camera body) differs from one lens to the other.
If you bought this lens without specifying it needs to be used with a Sony camera body (and it is for a different camera) it will NOT mount. Determine if the lens is indeed designed for a Sony camera body. You may find additional letters & numbers on the lens that can help you determine which camera body brand it fits by plugging the number into Google for a search. Additionally, the Quantaray brand is / was a Ritz Camera "house" brand. You could probably bring it to one of their stores and learn all you need to know about the lens there.
Jan 31, 2012 | Quantaray Cameras
Image shifts off center and two corners appear rounded as if you are focusing on the rim of the lens.
Image shifts off center and two corners appear Problem with the Sony Alpha DSLR-A100 Digital Camera That
The Sony A200 kit (DSLR-A200K) comes with a DT 18-70mm (3.9x) f/3.5-5.6 zoom lens for an estimated US$600.
A separate Sony A200 kit (DSLR-A200W) includes two lenses: the DT 18-70mm mentioned above, and a 75-300mm f/4.6-5.6 telephoto zoom for an estimated US$800.
Click Here To Watch More Information about This Answer
Jul 18, 2011 | Sony Alpha DSLR-A100 Digital Camera
Can you use the twist-barrell zoom lens on a Sony DSLR camera (or any DSLR) when the camera is set to auto-focus? I've been told that this damages the gears in the lens if you do. Thanks for your help.
You can zoom completely independent of the focus.
Some lenses immediately override the autofocus when it senses you turning the manual focus ring. Other lenses don't, and you can damage the lens by forcing it. It depends on the lens, so you'll have to consult the documentation for the specific lens.
Jul 06, 2011 | Sony Alpha DSLR-A200K Digital Camera
Sep 29, 2009 | Sony Alpha DSLR-A200K Digital Camera
Sigma 70-300 +''no lense attached'' w/ sony a200 dslr
Jun 02, 2009 | Sony Alpha DSLR-A200K Digital Camera
Minolta SLR Lens on Sony - Does it work.
As I understand it, Sony bought Minolta, lock, stock, and barrel. Theoretically the lenses should fit and may work on manual, but I'm very sure they will not totally work on sony digital cameras. I wouldn't even try to fit them as the autofocus system on the camera may be damaged.
Mar 22, 2009 | Tokina AF 100-300mm f/4.0 II APO Telephoto...
Update to new camera
This depends on your budget and nature of photography. If you have the budget for a DSLR and you feel that you really need to use different lenses, go for a DSLR.
Feb 12, 2009 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
Sony Alpha DSLR-A200 Digital Camera Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
