Question about Apple iTunes
I tunes store problems
Recently,every time i try to access the store homepage, on the rare occasion it actually works i keep getting an extremely simplistic version which is slow and laggy and looked like it had been thrown together by a blind duck in the late stages of dementia. most attempts to access other links freeze up halfway or a message appears saying that itunes could not complete request. networking is not the issue as all troubleshooting tests were passed, so it seems like a problem on apple's end. any advise would be helpful.
gymowner
  • 679 Answers
SOURCE: iTunes store connection probomething
Check your firewall, enable it if it's stuck off. And also check your virus and malware programs, it sounds fishy if you can connect to every other site sounds like someone set it so you can't get in, check your security settings also
Posted on Feb 03, 2009
the_fire
  • 432 Answers
SOURCE: apple itunes problem code 3212/what is it? apple support no help
http://support.apple.com/kb/TS1368
If you have any firewalls ie mcaffee or norton or zonealarm then you will need to allow itunes access to the internet.
The article above explains a lot of options also if you have a router you could try and open all the ports for outgoing traffic and incoming to start with and see if that helps - if it does then you could try and port forward ( open the ports ) for ports 80 and 443
http://support.apple.com/kb/TS1629?viewlocale=en_US
Posted on Apr 10, 2009
the_fire
  • 432 Answers
SOURCE: itunes store says i'm not connected
un install all your firewalls completely for the time being ( you only need one so I dont see why you have norton installed - personally I would just get rid of norton as norton anything is rubbish !! )
Disable windows firewall as well and un install itunes and download the latest version and then re install using the latest version and try again.
Also if you have a router try and port forward ports 80 and 443.
If you post back with your make and model of router I can help you as best as possible to do this.
Fixitman909
  • 430 Answers
SOURCE: since i downloaded the new version of itunes 8.0 i can't download
yes restore your pc back to before the upgrade.. Click on start then progs to accessories then to system tools...click on restore and back up system. GL
Posted on Jul 24, 2009
  • 32 Answers
SOURCE: unknown error occurred (306)
some people have been doing this
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
do a google search for "itunes error 306" for other discussion boards on the topic, seems to have occured after an itunes update conflicting with OS (go figure right?)...hope this helps =)
Posted on Feb 04, 2010
I carnt tune ch78 into my Baurn flat screen
perhaps they have done something there that the channel has changed strenght and you will not get it . except on rare occasions .
Aug 28, 2015 | Televison & Video
When i do an auto set up on my samsung i fin d that there is no window saying to store them so everytime i switch on ihave to start again. I have no acsess to the guide either. when i try to do someth
Not being familiar with that particular item I cannot say for sure but 33 years in consumer electronics leads me to believe that you might have a hardware problem. If the IC that is suppose to hold the memory has malfunctioned. It could as simple as bad soldering connections or just a bad IC period. I would contact the MFG. and try to talk to one of their tech's about it. A lot of times they are familiar with the problem and know exactly what is wrong. On a very rare occasion I have ran into somethings that they had a recall on. It's worth a try!
Mar 08, 2014 | Televison & Video
I can't access my Facebook Homepage/Timeline/Search for Friends
Try a new browser to check whether is the browser problem
Jul 30, 2013 | Facebook Social Network
Sir i have purchased nikon p100 camera from croma stores belapur branch , the problem with the barrel and there were gear noise and on taking photos in dark back ground of moon there were several white...
You have to know the MODE your camera is in. If you have it in the wrong mode you may not be able to take a photo in some conditions. You typically cannot take a photo of the moon on any auto setting the moon will be a white blob. The moon almost has to be taken manually.
Search for Lens Error. There are many was to fix Lens Errors
Mar 15, 2017 | Nikon Cameras
Sometimes the water valve does not shut off and water overflows
Good day,
If it's the ice maker your talking about, it is usually a bad water valve, in the back bottom rear of the machine. Replace it with new.
On extremely rare occasions the sender in the ice maker can create this problem, but as said, extremely rare.
Apr 13, 2010 | Amana ATB1935HR Top Freezer Refrigerator
2002 Santa Fe 2.7 V6 (California Car) 260,000 + miles. Engine idle will increase to about 1500 RPM and drop back to normal without notice, at times difficult to start (must hold throttle about half open)...
I faulty Idle Air Control valve (IAC) can cause these specific symptoms. You could try diconnecting the IAC valve (usually near the throttle body) and regulating the idle yourself. If the fluctuations go away and you are able to hold a constant idle position with the gas pedal (if vehicle will start), the IAC is the problem.
Nov 14, 2009 | 2002 Hyundai Santa Fe
How come i can connect to the itunes store at work but not at home?
Are you sure you have the same I-tunes version and have you checked that your firewall and you antivirus not block some files of I tunes ??
Have you try to reinstall the software in this way :
Uninstall I-Tunes, reboot the computer and reinstall I-Tunes. Try to download the latest version from their homepage here :
http://www.apple.com/itunes/download/
OR here
http://download.cnet.com/Apple-iTunes/3000-2141_4-10235268.html
Hope it helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Oct 28, 2009 | Apple iTunes
Bebe Sounds Color Video baby monitor new interference problem
you can try to eliminate any electronic interference by unplugging or disconnecting any recent additions to the home
May 03, 2009 | Home Security
Yahoo Calendar code 41
Sometimes I get that message but it usually goes away either when I refresh or very shortly I try again and it works. Hopefully your calendar is already working for you.
Mar 13, 2009 | Microsoft Computers & Internet
Locating and replacing oxygen sensor
Is the check engine light on with oxygen sensor codes?
If there are no problems with it leave it alone. i have seen factory sensors working good with over 300k miles on them. I recommend using dealer tune parts. at least NGK plugs. I have found misfire problems with aftermarket tune parts on several occasions.
there could be 2 oxygen sensors and they will be in the exhaust manifold or the catalytic converter or the "A" pipe between the manifold and catalytic converter. if you have the correct tools you can do it. sometimes requires special tools and rarely they are seized in the exhaust manifold and damage the manifold than it has to be replaced.
Dec 27, 2008 | 2000 Honda Civic
Apple iTunes Logo
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
