Question about Enermax (by Coolergiant) ELT400AWT Liberty (Lowest Noise) 400W ATX /BTX Power Supply ATX 12 Ver 2.2 ... (CSPSEM400AWT) Power Supply
In ELT400AWT Supply what is a THR1? What is equvivalaent replacement for repair? Have an circuit diagram?
2004 Chevrolet Silverado 2500 HD LS crew cab 6.0 4x4 right turn signal activates hazards. What would the steps be to diagnos this problem without purchasing parts that do not fix the problem
Do you know how to test automotive electrical circuit's using a wiring diagram an a DMM - digital multi-meter ? Do you know what a factory diagnostic flow chart is ? This will not set any diagnostic trouble code's in the BCM - body control module . Looking at factory symptom chart , their is no diagnostic trouble chart for your symtoms . Have four choices .
Hazard Lamps Always On
• Hazard Lamps Inoperative
Turn Signal Lamps and/or Indicators Always On or Flashing
• Turn Signal Lamps and/or Indicators Inoperative
Which one would you use to diagnose this problem .
Or would you just view wiring diagrams an wing it ?
Step
Action
Yes
No
Schematic Reference: Exterior Lights Schematics
Connector End View Reference: Lighting Systems Connector End Views or Body Control System Connector End Views in Body Control System.
Did you perform the Lighting Systems Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Verify that the turn signal lamps and/or indicators are inoperative.
Do the turn signal lamps and/or indicators operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Are only the turn signal indicators in the instrument panel cluster (IPC) inoperative?
YES - Go to Step 4
NO - Go to Step 5
Test the inoperative turn signal supply voltage circuit to the IPC for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - Go to Step 21
NO - Go to Step 13
5
Is only one turn signal lamp inoperative?
Go to Step 6
Go to Step 8
6
Inspect the inoperative bulb/socket for an internal short, poor terminal contact, or an open filament.
Was a problem found?
Go to Step 18
Go to Step 7
7
Test for an open, high resistance, or short to ground in the turn signal lamp supply voltage circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
8
Inspect the IGN E fuse and the FLASHER fuse.
Is either fuse open?
Go to Step 11
Go to Step 9
9
Test for an open or high resistance in the following circuits:
• The turn/hazard flasher battery positive supply voltage
• The turn/hazard flasher ground
• The turn signal switch ignition 1 supply voltage
Go to Step 21
Go to Step 10
10
Disconnect the multifunction switch, turn signal switch.
Test the multifunction turn signal switch for continuity between the multifunction turn signal switch ignition 1 voltage input terminal and the turn signal flasher signal output terminal in each respective position. Refer to Circuit Testing in Wiring Systems.
Is continuity present?
Go to Step 12
Go to Step 14
11
Test the following circuits for a short to ground:
• The multifunction turn signal switch ignition 1 voltage
• The turn/hazard flasher supply voltage
• The left turn signal switch signal
• The right turn signal switch signal
• The left turn signal lamps supply voltage
• The right turn signal lamps supply voltage
• The trailer left rear turn/stop lamp supply voltage
• The trailer right rear turn/stop lamp supply voltage
Go to Step 21
Go to Step 14
12
Test the following circuits for an open or high resistance:
Go to Step 21
Go to Step 15
13
Inspect for poor connections at the IPC. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the multifunction turn signal switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
15
Inspect for poor connections at the turn signal/hazard flasher module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
16
Repair the ground circuit of the inoperative lamp. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 21
17
Important: Perform the set up procedure for the IPC.
Replace the IPC. Refer to Instrument Cluster Replacement in Instrument Panel, Gages, and Console.
Go to Step 21
18
Replace or repair the inoperative bulb/socket.
Go to Step 21
19
Replace the multifunction turn signal switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column.
Go to Step 21
20
Replace the turn signal/hazard flasher module.
Go to Step 21
21
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 3
Jan 06, 2018 | Chevrolet Silverado 2500HD Cars & Trucks
My high beams on my 2002 grand prix wont work..now my turn signals n horn dont either
check the lighting module and light switch. GM have a massive recall on for modules and switches.
Jan 14, 2015 | 2002 Pontiac Grand Prix
Circuit diagram hp ac power adapter 0957-2094
Not available. Replacement is so inexpensive if the power unit has stopped working, cheaper to replace than repair.
They are repairable if you have the knowledge and skill to rework a switch mode power supply.
Jan 11, 2015 | HP Computers & Internet
How to repair the dso power supply ? is there a circuit diagram ? thx
repairing a power supply do not need a diagram often faulty on a power supply are the regulator transistor,capacitors,resistors,and diodes. just check these parts and you can fix the power supply.check also for loose contacts and connectors this also cause a fault on the power supply.
Jan 18, 2011 | NetGear ProSafe JFS524 24-Port Ethernet...
Boss psa 120s automatically shuts down and does not turn on
I'm going through here just to share the circuit diagram (schematic) for Boss PSA adapter because I know that many people need to repair their damaged fonts but can not get the original wiring diagram.
Savio
Jul 08, 2009 | Boss PSA-120 (761294015735) Power Supply
Intel dot station 2300 pc power supply problem
I suggest to buy a new replacement Power Supply to immediately fix your problem, instead of getting the circuit diagram & try to locate/replace the part/s that might be cold soldered /defective which if not handled properly will result to another possible problem. best regards
May 22, 2009 | Intel Dot Station (INTC300AIO) PC Desktop
Power supply failed
HI....
It's not worth going after...Cyberhome doesnt give out tech documents.
Mar 25, 2009 | Cyberhome CH-DVR1500 DVD Recorder
Thermal resister need a replacement for thr1fwstansbury@mchsi,com
THR1 is reference designator for the component on the PCB. What is the marking on the component. THR1 is a thermo resistor and is probably a TO-237 outline package. On the black tab part of the device it should have a marking like R100 or PCT with a symbol to represent the manufacture.
Nov 30, 2008 | Diablotek / APower / 420-Watt / Micro-ATX...
JVC THR1 DVD Digital home cinema system.
There is other Cinema Surround systems that use the same 8 Pin setup Aldis had one retailing at £49.99 and there are plenty on E-Bay www.eserviceinfo.com will provide schematics for these systems so you can select the right one.
Jul 17, 2008 | Audio Players & Recorders
Computers & Internet Logo
881 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
