Question about Canon Pixma iP2600 Photo InkJet Printer
Both lights are flashing and it won't print
My mac tells me there's a paper jam but no paper in there!
    President:
  • 787 Answers
Open the back cover and check the paper road.
Posted on Oct 06, 2009
Both ink and paper jam lights flashing
The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.Go To Below official Epson Printer Page For Your problem and solve your paper jam problem https://files.support.epson.com/htmldocs/cx11nf/cx11nfug/trb_e_1.htmHope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Epson Printer Support
Mar 24, 2014 | Epson Office Equipment & Supplies
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Printer will not print, says that there is a paper jam but there is no paper in the print, and when we add paper the printer won't take it and the power light is blinking
you need to remove the black plastic on the back wipe the rollers that feed the paper put it back together plug it back in switch on and it should work some times u get a small corner of paper stuck so it tells the machine that u have a papaer jam
May 25, 2011 | Lexmark X1270 All-In-One InkJet Printer
The red and green lights are flashing continously and it won print
The lights continually flashing indicate a paper jam or the printer being out of ink. Check/clear any paper jam and verify the ink cartidge is set correctly.
Mar 05, 2011 | Epson Stylus C48 InkJet Printer
The green light on my HP Deskjet 3845 is flashing ..when I try to print it tells me there is a paper jam ..there is no paper jam. I have inspected the printer carefully, reloaded the paper. It will not...
i think u should check for peices of paper ,tiny objects etc that might be obstructing the movement of the paper. also check that the print head is not disconnected from the belt you can check this by slidind the print head from side to side and ensure that both of them are moving hope this helps.
Oct 19, 2010 | HP Deskjet 3845 InkJet Printer
Blinng orange light
Answer Part 1 of 2
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take appropriate action.
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Ink tank is not installed properly
Open the Print Head Cover and check whether an ink tank is installed. If an ink tank is installed, push the button of the ink tank, and reinstall the ink tank properly.
Five flashes: No Print Head installed, or Print Head failure
Install a Print Head.
When the error continues, contact a Canon service representative.
Eight flashes: Waste ink absorber almost full
Ink used for cleaning is absorbed in a waste ink absorber placed in the printer. Eight flashes indicate that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so that you can continue printing.
Important
If this error occurs, replacement of the waste ink absorber and maintenance of the printer are required. Canon recommends to contact a Canon service representative as soon as possible. Once the waste ink absorber becomes completely full, it cannot be printed until the Waste ink tank is exchanged.
Nine flashes: A specified period of time has lapsed without receiving a response from a digital camera or digital video camcorder / The digital camera or digital video camcorder connected is not compatible with this printer
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
The light is blinking on my maching (i believe it's the ink--or lack of it). i'd like to find out if that is so, but i can't seem to find the route to that on my machine, which is a mac. How do i get that...
I can't tell you how you could find out on you Mac as I've never used one with my C86 but I can tell you that you can translate the light flashing into a more meaningful "message" by observing the patterns.
  • Paper & Ink lights flashing alternately (power light off) = service required (ie: waste pads need replacing)
  • Ink light flashing = ink cartridge is empty or printhead is in the exchange position. Try pressing the ink button once (don't hold it down) and see if it moves to the exchange position or moves back to park.
  • paper light flashing = paper jam or no paper in feed.. Remove a jam or feed it with paper as required then press the paper button
  • Power light flashing = printer is busy... If it's doing nothing trying pulling the power lead out of the back of the printer, wait 5 seconds and then plug it back in, turn it back on. This should clear any error.
  • Both ink and paper lights flashing (together) = General error.. This could be anything from a serious paper jam, loose wire in the printer, parking station disconnect or similar..
Hopefully that will give you something to go on and get you working again... As far as software information goes, someone else may be able to help but chances are Epson's own support site will have some software called Status monitor or similar for your operating system which may help.
Cheers
Martin
Aug 05, 2009 | Epson Stylus C86 InkJet Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Close the front cover of the printer.
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
does not start printing, press the Go button.
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Error flashes
I've read several posts on the "red flashing error light" on the Brother HL-2170W. I have mine hooked to a mac - but I'm sure the pc is the same way. One other previous post said look for a paper jam. Well, there are only a few places to look...and I found no paper jam UNTIL I removed the toner cartridge and looked UNDER the cartridge and VOILA, there was a paper jammed underneath. I removed it and I'm back in business. Normally paper jams when it is almost out of the printer and you can locate it by opening the back of the printer. Well, this one was "sneaky" and hid completely underneath the toner cartridge.
Hope this helps someone else...
May 25, 2009 | Brother HL-2170W Laser Printer
Canon Pixma iP2600 Photo InkJet Printer Logo
142 people viewed this question
old marine
old marine
