Question about Dryers
How to reinstall the belt on drum - Dryers
  • milten1
    milten1 May 11, 2010
    model and manufacturer? sorry but it does matter
  • 3 Answers
This is a fun one. :)
I'm assuming that you have the top and sides off so you have access, if not start tearing it down so you can manuvuer inside the frame.
Now would be a really smart time to inspect and either lubricate or replace worn roller bearings!!! They are cheap if replacement is required and will make you dryer run quiet like new.
I found that 2 of my 3 support roller bearings were almost impossible to deal with after the drum was back in place and had to leave one bearing out during the positioning of the belt for some slack. I elected to remove an upper bearing so there was bearing supporting the lion's share of the drum weight as I was doing this alone with no help.
You can test before reassembly and that would be a good idea incase there is something else you'd like to address while it's broken down.
P
Posted on Oct 06, 2009
Was drying cloth and just stop working, the element comes on but no running of drum
Most electric dryers are 220V and are essentially 2 -110V circuits.. You should have either 2 circuit breakers or two fuses supplying the power to the dryer . One is probably tripped or blown. Either reset the breaker or replace the defective fuse and you should be in bussiness!
Feb 16, 2011 | Whirlpool LER4634J Electric Dryer
Belt broke -how to take off and replace
Greetings,
UNPLUG and Remove the two screws from lower front panel...pull panel up and out to remove...
There will be four screws to remove front drum support. This is where you slip belt over drum and reinstall front drum support. The belt goes with the belted side up..The next step is to route belt around pulley and loop onto motor shaft. There will be tension when on correct,...reinstall front
Jan 27, 2011 | Maytag Dryers
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to searsdirect.com and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
My maytag dryer makes a loud noise when on. It sounds like a belt. Can I fix it and how? It's an older model, I don't know where the model number would be. It's loudest when first turned on. Thankyou
To remove the belt go the the rear of the dryer and remove the two or four screws holding the inspection door near the bottom corner of the dryer.Remove this small door. Unplug the dryer. Look inside and see how the old belt is positioned on the pulleys. Releive the tention on the belt by moving the belt tentioner and sliding the belt off the motor pulley.
Go the the front of the dryer and remove the two screws holding the front panel on. Tilt the dryer front forward and remove. Mark and remove the two door switch wires and move the front panel out of the way. Undo the four screws holding the drum support from the front of the dryer and remove. Grab the drum and sllide it forward out of the dryer.
Vaccum the inside of the dryer and inspect to make sure the rollers move freely. If they don't move freely or show wear, replace rollers and lubricate with light oil. Replace belt.
Put belt over drum. Reinstall the drum into the dryer. On some of the older dryers there were teflon drum gliders located inside the front drum support. Inspect glides and replace if needed.
Reinstall the front drum support and four screws. Reinstall the front panel with two screws.
Replace door switch wires.
Lift the top and make sure the belt is positioned on the drum where the old belt was.
Go the rear of the dryer and pinch the belt sliding threw the belt tentioner under the pulley and over the belt pulley.
Reinstall the rear door with all the screws.
Faster the top down and plug the dryer in and test.
Your done.
Jan 03, 2010 | Maytag PYE2300AY Electric Dryer
Help Changing Belt on Maytag PYET444AYW dryer
Normally if it is a front loading machine then you need to take the front of the dryer off.
This will expose the drum, roller, etc.
Remove the drum, install new belt on the motor pulley, loop around the idle arm roller, then install on the drum and reinstall the drum, reinstall the front and job complete
Sep 26, 2009 | Maytag Dryers
How do I replace the belt
you need to remove the drum.route new belt with ribs on motor pulley.and backside of belt on sping loades idler pulley
Sep 24, 2009 | Dryers
Drum won't turn Dryer is working in all ways except drum won't spin
Once opened, you will see the belt will be either broken or have slipped off. Before new belt is reinstalled turn drum by hand and see if there are any problems with the bearing stripps.(feld which seperates the two drums.
Sep 15, 2009 | Dryers
Dryer not turning
remove top cover and then front to reveal drum and belt,to repl belt lift up drum and install belt around drum and then on mtr and idler pulley then reinstall frt and top cvrs
Jul 11, 2009 | Whirlpool Dryers
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
Fitting the belt to the hoover 5050ed
nope,, but
all dryers are generically the same
remove the front panel and door
pull the drum
loop the belt around the drum, at apporximately the wear marks of the old belt
reinsert the drum
loop the belt around the motor pulley
pull the tensioner pulley hard against the spring to the end of its travel
loop the belt around the tensioner pulley
allow the tensioner to move back under spring pressure to tension the belt
rotate the drum by hand to make sure the belt is aligned and not coing to jump off the pulleys
reinstall front panel & door
26740a0.jpg the tensioner may be on the bottom belt run pusshing up, or the top run pulling down
breaking belts sometimes pull the tensioner out of its mounts, there is only one place that the tensioner will reinstall.
Its a standard whirpool dryer, rebadged as hoover, so the local parts guy has the belts rollers felts and glides as necessary, they are common to all the dryers whirlpool makes.
Oct 01, 2008 | Whirlpool LER4634J Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
