Question about Microsoft Xbox 360 Console
Successful x clamp replacement but still has problems
Here's the story for me so far..
I have replaced the x-clamps, used no washers underneath or above the board.
It worked fine, shows green lights when i boot up the console.
I was able to play for 3 minutes or so then 2 red lights show up.
I put silicon compound on the GPU and CPU dies.
I boot it up again, still fine, and was able to play for 5 minutes or so.
Then I decided to clean the heatsink and GPU and CPU dies, removed residues of thermal compound underneath the heatsinks, on top of the dies and also on the sides of the dies (black gooey thing).
When I turned the console on, 3RLOD.
I also noticed that the board is somewhat bent, and when i look under the board, there is a curve or lump where the CPU and GPU are soldered.
I am currently using the shim method, placed 1 washer underneath the board, 2 washers above the board.
When I boot the console, still shows 3RLOD for about 3 seconds then 2RLOD.
So, was it wrong for me to clean the processors of any residues of thermal compound? Another thing, is that artic silver thermal compound on the sides of the cpu and gpu dies?
  • bally900 Jun 02, 2008
    I need photo's of underneath the gpu x clamp as I believe some components have blown.
  • 69 Answers
Try Again, tighten the screws a little .
Equal loading of the heat sinks for both
the GPU CPU then burn in . keep the fan on
the CPU .
normal
takes 3-5 min for fan get to full speed
and i like to see at least 3-5 more min before
two reds over heating
Posted on Jun 30, 2009
  • 3 Answers
Of course, then he would have had to deal with the rrod issue a few days/weeks/months after it was "repaired," since microsoft "fixes" the rrod with a reflow and a heatsink on the southbridge. imo, microsoft needs to stop saving face and admit that their engineers were more interested in the aesthetics of the clamping system than stability, then do away with the x-clamps entirely. horrible design.
Posted on Jan 17, 2009
  • the720k Jan 19, 2009
    I noticed that you are using one washer on the bottom of the motherboard. What has always worked for me is the use of two washers on either side of the board. One metal, one nylon on each side. Make sure the nylon washers are touching the motherboard on either side, to make sure that the washers are not conducting any electricity by accident or causing damage to the board. The softness of the nylon is the preferable way to clamp down your board. I've had similar problems as yours by not following this method. If you need them, here are the Lowe's part numbers you'll need for the complete fix:
    139065 - 4pk. of 5mm nylon washers (get 4 bags)
    138319 - 10pk. of 5mm metal washers (get 2 bags)
    138433 - 2pk. of M5 .80x10mm machine screws (get 4 bags)
    Try these parts and you should have much better luck. Hope this helps.
Yeah it needs to be cleaned off and replaced with arctic silver 5 dude. if you didnt have any compound on there it could have got HOT HOT HOT!
Posted on Jan 18, 2008
  • 121 Answers
Well if you would not have opened up your console nd messed with it you would still be covered by the 3 year warrenty and would be able to recieve a new console from xbox support now i think you must pay a fee for repair you can call them at 1-800-4myxbox
Posted on Jan 14, 2008
Do u have to replace the hold drain pump bracket if the black hose conected to the pump keeps falling off?
You do not need to replace the whole drain pump. The black drain hose is attached to the drain pump and secured with a hose clamp. If the clamp is not further down the drain hose, inside the unit on the base or has not fallen underneath the washer it can be replaced with a hose clamp from a hardware store. You will need the diameter of the hose to get the correct size. Rather than using a standard screwdriver to tighten the clamp a 1/4" or 5/16" nut driver or socket works much better. Make sure you unplug the appliance before working on it and have towels handy in case of water spills
Sep 02, 2014 | Washing Machines
Ignition switch removal/replacement for 1995 vw passat
Disconnect the negative battery cable. Remove the steering wheel, and then remove the steering column covers. Remove the turn signal and wiper switches. Disconnect the ignition switch wiring. Remove the clamping washer, spring and contact ring from the steering column, and then remove the lock housing up off the column tube and steering column. Remove the ignition switch mounting fastener and remove the switch. Installation is in reverse order of removal noting the following: Press the contact ring, spring and clamping washer onto the steering column using a properly sized and sturdy metal pipe or tube. If after installation of the clamping washer, the steering column is not projecting out far enough, pull the steering column out further.
Jan 23, 2013 | Cars & Trucks
Our Maytag Epic Z model mhwz400TQ01 front load washer is leaking some water out the bottom of the washer unto the floor. It seems to leak mostly when there is water in the tub and the washer is tumbling. ...
If it is indeed leaking form the door boot, you should be able to find a hole somewhere. Take off the bottom panel off the machine, and try to look up inside it to find the source of the leak. (Three screws underneath)
The part number for the boot is W10111435. It should be available at any major appliance parts shop, or online. Just google the part number.
As far as replacement of the boot, it is fairly simple, although it can be awkward to reach the clamp. The outer clamp, the clamp holding the boot to the washer cabinet it just a spring clamp, the spring should be at the bottom of the boot. It just pulls off with needle nose pliers. The inner clamp is a bit trickier. Once the outer clamp is off, fold the boot back into the tub so you can reach into the machine (make sure it is unplugged first!). The clamp screw should be ont the right hand side, about the 2 o'clock position. It unscrews with a 8mm nut driver (may be 7 or 9, I forget). One that is loose the boot will just pull off. The new one goes back on the same way, just press it into the grove on the tub (be patient) and put the clamp on and tighten. Don't over tighten, or the clamp will actually pull the boot back off. Just snug it down. A trick to use if the boot is too stiff it to throw it in the dryer to heat it up for 5 min or so.
May 17, 2011 | Washing Machines
Washer leaks from under the front of the machine.
If you are having a problem with your washing machine i.e leaking, don't rush out to buy a new one just yet. Sometimes simple repairs to the machine can fix the leaks saving you hundreds of dollars and days of shopping for and installing a new one. Luckily, you don't have to be a master electrician to do repairs. These steps will walk you through the basics of fixing a washing machine.
Instructions
  1. Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
  2. Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  3. Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  4. Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  5. Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  6. Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Good luck and thank you and thanks for using fixya.
Jan 30, 2011 | KitchenAid KAWS750L Top Load Washer
My washer is leaking water out of the dispenser area . The hose for the water underneath the dispenser seems to be clogged how do i fix this?
Hi, follow the instruction below to clear the clooged hose.....
  • Pull the washer 2 to 3 feet away from the wall so you have enough room to access the drain pipe.
  • Locate the drain discharge hose where it comes out from the back of the washing machine. Typically it will be a 1 1/2-inch hose and leads to the drain in the floor, wall or laundry tub.
  • Detach the discharge hose from the drain. The hose may be secured by a squeeze clamp or screw clamp or it may just be inserted directly with no clamp. Use pliers for the squeeze clamp, screwdriver for a screw clamp or pull the hose straight up, depending on how it is secured.
  • Insert the pipe snake into the open drain until you feel the clog release. Typically this will be very close to the top rather than several feet down.
  • Check the drain hose section that is attached to the washer. If there is another clogged area, you will be able to see it; snag it with the wire and pull it out.
  • Replace the drain discharge hose into the drain and check all connections to ensure there will be no water escaping.
  • Move the washer back into place. It will now drain properly.
Nov 28, 2010 | Maytag Neptune Washer
Washing machine leaking from underneath. All the connections from the back are secure but water appears to be leaking from the bottom. The leak started almost 24 hours after the washer was used. The...
I had the same problem. I have tried replacing the spring clamp on the drain hose with a regular adjustable hose clamp I got from the hardware store. Not real happy with this situation since I just bought this washer two years ago to replace a previous Kenmore washer that we had for nearly 20 problem-free years.
Apr 07, 2010 | Whirlpool Inglis IP4400 Washer
Leaking
Hi
Please Follow this Instructions:-
Step 1 Look at the floor drain to make sure it isn't clogged. Sometimes it's not even the washing machine, but the drain causing those puddles of water on the floor. Unclogging the drain can be an easy and quick fix.
Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part.
Thanks for contacting fixya.com
Oct 30, 2009 | Washing Machines
Water leaking
hi friend,
  • Step 2 Inspect the hoses for leaks or wear and tear in certain spots. Filling the washing machine may help identify any leaks or faulty hoses. If hoses are worn, replace them with non-burst stainless steel mesh hoses.
  • Step 3 Check the fittings of the existing hoses to the faucet fixtures and on the back of the washing machine. Sometimes a loose connection is the cause for the leaks. Tighten couplings and hose clamps if necessary to fix the leaks.
  • Step 4 Replace internal washers inside of the hoses if not replacing the entire hose. Something as small as a rubber gasket can create a lot of water damage. Use a screwdriver to pop the worn washer out and replace it. Repeat replacing washers on the other end of the hose.
  • Step 5 Examine internal components by opening the cabinet and starting the fill cycle to see if anything is leaking internally. Calcium deposits and rust may be evident around areas that have leaks.
  • Step 6 Use hose clamp pliers to remove any corroded spring clamps and replace them with new ones. Make sure the hose is still intact underneath the old clamp. If not, remove the internal hose and take it to an appliance repair center to find the correct replacement part
  • hope this helps u
    thank u for using fixya
    please rate me.................
    regards
    sivaranjini
    Sep 12, 2009 | Kenmore Washing Machines
    Replacement of fan oven element on Nef U1721
    Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
    Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
    ROPER WASHERRAX6144EWO
    If that is a coupling--2 white plastic pieces holding a rubber coupling? Rubber with three holes? If so, you need to remove 2 holding clamps to the water pump above the motor, separate it, remove two screws and 2 larger holding clamps of the motor, pull motor out and replace coupling...alingn motor and coupling onto gear, clamp it and return pump into its place.
    I am new here, tried to post a photo of what I think you have but cannot just yet. Still trying.
    Nov 28, 2007 | Roper RAS8445KQ Top Load Washer
    Microsoft Xbox 360 Console Logo
    856 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
