Question about Acer Veriton 3600 (V3600GT00150) PC Desktop
Blown capacitor in a Veriton 3600G...psu runs but system will no
I replaced a blown capacitor in a Veriton 3600G. Now the power supply fan runs immediately when plugged in but the PC does not boot.
  • dannobyte Oct 06, 2009
    Geekman, thanks for your rapid reply. Sadly the capacitor was on the motherboard. It would seem that when it blew it may have damaged something not repairable.
  • Acer Master
  • 32,281 Answers
It is not unusal for capacitor/s to blow their tops and could emit flames and smoke as the power supply ages. When they blow they could damage other components. Don't bother trying to replace them, get a new power supply.
Posted on Oct 06, 2009
Testimonial: "Rapid response and easy to understand."
Schematic diagram power supply
IT SOUNDS LIKE YOU MAY HAVE BLOWN YOU CAPACITORS AND OR OTHER COMPONENTS, FIRST CHECK THE FUSE. IF YOU HAVE A MULITI METER IT SHOULD READ AROUND 0 OHMS
Nov 23, 2013 | ION Audio Ipa16 Block Rocker AM/FM...
Tip
FI code check outside power supply board for blown capacitor
found blown outside board capacitor and part of the printed board strip burned off symtoms were fan would run for 1 or 2 min and then FI code
on Aug 31, 2013 | Amcor Aire AMS241HX Split System Air...
Will not power up. Replaced bad power supply(burned circuit board inside PSU) but still does not power up, PSU is ok. When power on button is pushed CPU fan turns for about 1/2 second but nothing else....
Sounds to me like when the power supply went out it allowed a surge to hit the mother board and you will have to replace it also .Look at the mother board and see if there is a green LED light showing if it is you are getting power to it and you have capacitors blown if not recheck you connections from the power supply and MB if they are all tight and correct then just figure on replacing the mother board
Sep 01, 2011 | Biostar M7VKB Motherboard
I turned on the TV and it popped and went off and will not come back on
Hi.
When that happens you have usually blown the PSU. The power supply is the board connected to the power cord. If there had been a pop sound, power went off, and now TV is completely off, then the PSU has blown.
There is a 6 Amp 125 VAC fuse in the AC section of the PSU, that is the first part to check.After that test the PSU. Sometimes it is even possible to spot a blown capacitor in the PSU board. They look bulged, sometimes burnt and in some case you can even see a leak. Sometimes is instead possible to see a burnt area that is revealing a short, often in the AC section of the PSU. The PSU is located at the back of the TV. Power must be disconnected before removing back panel. Do not touch PSU. Capacitors can store and release heavy discharge even with power cord not connected. There are also 3 small brown fuses located next to the flyback. Those can be tested using a multimeter. Testing must be done by a trained person.
The PSU cannot be easily replaced with a new one. The part is not in stock anymore (part number was 264102), and it is not even easy to find on Ebay. The PSU must be repaired.
Regards.
Ginko
May 24, 2011 | RCA HD52W59 HDTV Projection Television
Cpu fan works, power supply fan works why wont' computer come on?
Could be a number of reasons:
The CPu fan and the PSU fans will come on, even though the system is not working. There is a possibility that the CPU has blown, you can check this easily by (carefully) feeling the heatsink after it has been running a while. A dead CPU will not use power and therefore not heat up. If after say 10 minutes of running, the heatsink is clay cold, suspect the CPU. Replace with another one, spreading CPU grease on the top before putting the heatsink back on.
A blown CPU will usually be indicated bu there being NO beeps from the system (see below)
If the CPU appears to be generating heat, visually inspect the board, look for blown or blowing capacitors (the small cylinder like components) on the motherboard, any that are bulging or leaking a brown residue, or have blown, will render the motherboard inoperative.
If these appear ok (they still may be damaged), unplug all components except the hard drive, and ram and video card, see if the system then boots. If it does, proceed to re-installation of each in turn, until the faulty peripheral halts the boot.
Listen for any beeps as the ssytem switches on these beeps describe the type of problem
(repost if you hear any beeps)
Remove one stick of ram and try rebooting, if it works, suspect the ram module, try the other and see if that makes any difference.
Failing that, your last recourse is to power the system off, remove the bios battery, replace after 2 minutes and see if clearing the Cmos "unsticks" the computer.
After That, suspect the motherboard is dead.
Apr 25, 2011 | Computers & Internet
The computer won't power up. The power light keeps blinking yellow
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 15, 2011 | Dell POWER SUPPLY Power Supply
Computer boot problem
Temporarily swapping-in another power-supply is the first thing to try.
Don't connect the disk-drives, CD/DVD drive, nor 3.5-inch drive.
If the computer "beeps", and shows the POST (Power On Self Test) screen, then changing the power-supply is the solution.
Look at the motherboard -- any "blown" or "bulging" capacitors?
Oct 27, 2009 | ASUS A7N8X-E Deluxe Motherboard
Powers supply led flashing computer will not start
First, ensure that everything is seated properly in its respective slot. If problem persist, examine power supply ensuring that they are no blown capacitors in the unit. Often, blow capacitors will not hinder a PSU from starting when the power supply is JUMPED. However, when installed on the system board, the faulty capacitors will quickly render the PSU useless.
I am going to bet on your psu as being the culprit.
Sep 28, 2009 | Computers & Internet
Acer veriton M460 will not boot up
The acer veriton m460 has three faulty capacitors. Check and see if you have bulgy capacitors. I have ten of these computers and all have three blown capacitors.
Jul 31, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
Replace CPU Heatsink and Fan
okay as long as the heatsink fits it will work. socket type is for the processor. also dont forget the thermal paste. look up www.ribbitcomputers.com
Apr 29, 2008 | Acer Veriton 3600G PC Desktop
Computers & Internet Logo
290 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
