Question about HP DESIGNJET 500 InkJet Plotter Printer
Why my HP designject 500 PLU can't turn on, no power after lunch, before lunch is ok.
    Scholar:
  • HP Expert
  • 123 Answers
This sounds like a heat related problem. Try running the plotter with the back cover removed. Also, try turning the plotter off before lunch and back on after lunch to see if it works ok. If it does, you may be looking at a power supply replacement.
Posted on Apr 15, 2010
I created a barcode & used PLU programs 100/200/300 to register it with my ER-380M. The barcode works ok with Price Enquiry but if scanned for a sale brings up a "Scale Error". Where did I go wrong ?
It sounds like you set it as a scale PLU so now it is trying to check the weight of the product on your scale. Set it as a non scale PLU
Apr 19, 2017 | Retail Supplies
How do i correct an 026 code error on my casio te2200?
The PLU has a condiment or preparation PLU association. It needs to be told which PLU you are linking. For example, a PLU set for steak may need to be told the PLU for medium rare or well done. Otherwise, you need to use the codes to turn off the condiment/ prep link from the dealer manual. If you need it, one of the users has the manual here:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TE-2200_and_TE-2400_dealers_manual.html
Jun 20, 2014 | Casio Parts Cash Register PC Desktop
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Jun 20, 2014 | Samsung SAM4s ER-650 Cash Register
Drove van to lunch. Van will not start but has all power to everything else.
does it try to start? if not check the fuse to your starter motor its in the main fuse box one under hood and one in the car check both fuse boxs if fuses are ok check the wiring to the starter maybe got knocked loose at lunch
Sep 25, 2010 | 2000 Honda Odyssey
Flexion1. Hi Mark. Still my problem with the Department assigned in place of flat PLU buttons are not resolved (Dept 1 assigned to flat PLU 007 & 014 .......upto Dept 10 assigned to flat PLU 62 &...
48 is the code for the PLU button, not a flat PLU. they are different.
To set a flat PLU, Turn key to program 4 subtotal Type the PLU number to be assigned using the numeric keys Type 063 Press the flat PLU location to save the PLU number there Press SUBTOTAL
If you get an error when you press the location, then you already have an amount in the totaliser (end of day report) for that location and you will need to do a PLU report and possibly a department report in both Z1 and Z2 modes to clear the totals of that function before you can allocate it. Let me know if you get an error and I'll help you through. Good to see that you have almost removed all of the old programming
Sep 19, 2010 | Casio Parts Cash Register PC Desktop
Flexion1: Casio Cash Register TE-2400
You don't need to use the PLU button when operating in REG mode. The PLU button works like a flat PLU button except it allows code entry, so if you press flat PLU button 27, it is the same as typing 27 and pressing PLU. The PLU button is used to access the PLUs that aren't on the keyboard as flat PLUs. Since the machine has a lot more than the approx 70 flat PLUs on the keyboard, you would use codes and the PLU button to look up the others. The reason you needed to put the PLU button back was to allow us to use it in program mode where it is used to call up a PLU for editing (in this case to change dept link). The departments do not need to be on the keyboard. they are really just placeholders in the machine that total up the linked PLUs so you will only see them on your daily report when it has totalled at the end of the day. Try linking a PLU to a department as I showed you before. Then use that PLU in REG mode. Then do a daily report and it should show a sale in the department you linked the PLU to. I know it is confusing, but just link your PLUs at this stage and then you will start to see it happen as you use the machine and take reports.
Jul 17, 2010 | Casio Parts Cash Register PC Desktop
Why want my hp 500 plus plotter turn on, no power to it what so ever
First check the power cable and change the plug. If don't help you have a problem in power supply module in your plotter.
Sep 28, 2009 | HP DESIGNJET 500 InkJet Plotter Printer
Casio TE-2400 PLU programming
Hi. You have been given the wrong instructions. That is why it is now all screwed up. Pricing is dead easy. You have condiments setup because you have set key features in prog 3 mode. It shouldn't be too hard to fix. We'll start with prices: Turn key to Program mode Type the price (no decimal point) Press a PLU (item button) to set the price to. Press SUBTOTAL To remove condiments, you need prog 3 mode. While key is on program, press 3 then SUBTOTAL. The display must change to "P3" Now press 0 (zero) then one of the PLUs that has condiments set. Press SUBTOTAL to finish. It may remove the tax status, so turn back to REG mode and test the PLU. If the tax has gone, then reprogram the tax setting for that PLU. Let me know if you get stuck. Mark
Jun 09, 2009 | Casio Parts Cash Register PC Desktop
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
Turn key to program.
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
HP DESIGNJET 500 InkJet Plotter Printer Logo
188 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
