Question about Panasonic KX-T7633 Corded Phone
Change ringer tone - Panasonic KX-T7633 Corded Phone
  • Panasonic Master
  • 2,460 Answers
Press PROGRAM and the C.O. or intercom button twice. The UP/DOWN navigator key will change and play the tones (30) or you can dial a number. ENTER or SAVE saves it. You have to do that for each line and each phone.
Carl
Posted on Oct 06, 2009
Testimonial: "Very helpful, this tip was not in the user manual."
How do I turn the ringer on, on the handset?
Press program/mute button to confirm and you may program the following items: Set Language, Handset Name, Ringer Tone, Ringer Volume, Message Alert, Ring To Answer, Security Code, VIP Melody, Key Tone, Audio Predial, Vibrate Ringer, Area Code, Tone/Pulse, Registration, Deregistration and Default Setting.
Ringer Volume
From the Handset Setup Menu:1. Press the caller ID-volume ( 6 or 5) button to scroll to the RINGER VOLUME sub-menu.
2. Press program/mute button to enter the menu. SET RINGER 1HI 2LOW 3OFF shows in the display.
3. Use the touch tone pad on the handset to select 1, 2or 3, or use the caller ID-volume ( 6 or 5) button to scroll to your selection. HI is the default setting.
4. Press the program/mute button to save your selection. You will hear a confirmation tone and the new volume setting shows in the display.
NOTE: If you turn the ringer OFF, the ringer off icon shows in the display.
May 27, 2016 | Uniden Cordless Phone
The visual ringer will not flashing.
At an educated guess sounds like dial tone is set to decadic if there are two phones the other phone will set off ringer when numbers dialed. May need to get phone provider to change dial mode in exchange line interface circuit to be Dual tone Multi Frequency Dialing and then switch phones to Tone dialing rather than pulse dialing.
Jun 01, 2015 | Lands Phones
How to change the ringtone
http://service.us.panasonic.com/OPERMANPDF/KXTGA101.PDF
When you get to ringer settings press select, then using the arrow keys scroll to ringer tone, choose one of the tones or melodies then select save and then select off to get out of the menu you should have chosen a new ring tone.
Jun 05, 2014 | Panasonic KX-TGA101S Cordless Handset
How do i change/control ringer volume on presidian cordless 5.8 ghz?
While the phone is on standby, press vol/bell to hear the current ringer tone. Press vol/bell again while the tone is ringing to switch to the other ringer tone. The last ringer tone heard will be selected as the phone's ring tone setting.
Get the manual from: http://www.google.com/url?sa=t&source=web&cd=9&ved=0CFcQFjAI&url=http%3A%2F%2Frsk.imageg.net%2Fgraphics%2Fuc%2Frsk%2FSupport%2FProductManuals%2F4300257_PM_EN.pdf&rct=j&q=presidian%20cordless%20phone%205.8ghz%20user%27s%20guide&ei=wPopTpSkE8zPmAXFhuitDA&usg=AFQjCNFGoj6kwkI8m_Hhi9K1t49wifNP2g&cad=rja
Jul 22, 2011 | Lands Phones
No ringtone
First Option:
You Go to Phone Setting in ringtone setting and check the Ring tone Setting If Ring tone Setting Ok But Not Ringe tone So
Secne Option:
Your Phone Ringer Default So Please change Ringer
And Ringing Problem will Solved Quickly
Aug 15, 2010 | Nokia 1100
My handset ringers are ''off''. How do I turn them on again? Uniden TRU4985
Hi there try this,
When the phone is in the standby mode, press menu/mute.
2) Press select/ch.
3) Press + or - to move the pointer through the ringer
settings (Ringer Off, Ringer Low, or Ringer High).
You will hear a ringer or melody at the selected volume.
4) Press select/ch, you will hear a confirmation tone.
Ringer Mute (temporarily)
You can temporarily mute the ringer tone. When the handset is off the base and the
phone is ringing, press end. The ringer tone will return to the previous setting starting
with the next incoming call.
[ 20 ] BASICS
• If you select “Ringer
Off”, “Ringer Off”
appears on the display
when you make or
receive calls, or
charge the handset.
Ringer Volume Setup
1) When the phone is in the standby mode, press menu/mute.
2) Press - to move the pointer to “Ringer Tones”, then
press select/ch.
You can choose from 6 ringers or 4 melodies:
- Ringer [Flicker, Clatter, Leap Frog, Ping Ball, Reminder,
Soft Alert]
- Melodies [Beethovens9, For Elise (Elise), Merry Christmas
(Merry-Xmas), Home Sweet Home (Hm Swt Hm)]
3) Press + or - to move the pointer. You will hear the ringer or
the melody as you scroll through the options.
4) Press select/ch and you will hear a confirmation tone.
Ringer Tone Setting
• If
Sep 27, 2009 | Lands Phones
Lost manual
Without the exact model it is difficult to find the manual.
Here the manual for 900 series/996:Uniden EZI996.
I also quote from manual:
Selecting the Ringer Tone and Volume
Base ringer on/off
The ringer switch allows you to set the base ringer on or
off. If you set the switch to off, you never hear the base
ringer tone.
Base ringer tone
Press the ringer tone button in standby mode to select one of 7 ringer tones.
Base ringer volume
Slide the ringer volume adjuster to set the base ringer volume.
Handset ringer tone and volume
Press the volume up key or volume down key (labeled as the volume/ /+ or volume/ /- key) in standby mode to select one of five ringer tones and volume combinations
Apr 17, 2009 | Uniden Cordless Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Change ringtone on base also volume
This is the best I can do to answer part of your problem. I solved my problem by taking this advice from Uniden for their dual phone set:
Selecting Ringer Tone (handset only)
Question:
How do I set/change my ringer tone on the handset?
Answer:
There are two different way to change you ringer tone depending on which model you have.
If you do not have an option in your menu on you handset for handset setup, then you will simply hit the volume ^ or v arrows on the handset rapidly scrolling through the 2 ringer tones and volume combinations.
Nov 16, 2008 | Lands Phones
Ringer
There are a number of ringing patterns which are programmable in the main switch unit, however I can find no information on various ring tones in the manual.........sorry.
Dec 17, 2007 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7633 Corded Phone Logo
189 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
