I have a konica 3331 copier which is indicating an error message 36-01, i have don ea general servicing but the problem is still persisting.Please can you help me.
    Guru:
  • 389 Answers
F36-01Low fuser temperature. It's can be some of the reasons. The Fault can consist in breach contact of fuse, faults of the lamp of the heating, thermo fuse and thermistor, if when okay - cose on the controller of the direct current. You recommend to apply to service - complex repair , requires the special knowledges and adjustments. Good luck
Posted on Oct 08, 2009
  • Sergey Artuganov
    Sergey Artuganov Oct 08, 2009
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta biz hub c550 error code c-EEE3 Help please
To reset the malfunction code press follow keys:
Turn OFF the copier,press and hold pressed the Utility key and turn ON the copier.Wait will apaire the Trouble reset message on the display and release the Utility key.Touch the message and turn OFF the copier.Wait 1 minutes and turn ON.Good luck.
Mar 21, 2013 | Konica Minolta Office Equipment & Supplies
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
Jul 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL Fatal Error Code: 12H
I advice you power off the magicolor 2430 DL and power on after few minutes, while the magicolor 2430 DL is loading or booting, pull out the plug from the AC outlet and wait for minutes before plugging it back and power on, if the problem still per, press the stop button for about 5 seconds and release, see what happens, if it fix the problem.
Let me no what happens.
Take care.
Jul 10, 2010 | Konica Minolta magicolor 2430 DL Laser...
My konica 3331 is giving me an error code 36-C1 ,what should i do.
thid is a fuser error code causes could be heat lamp, thermistor, thermofuse or circuit board
Sep 30, 2009 | Office Equipment & Supplies
Konica 3331 copy machine ( osama tech )
JUST CHECK THIRMISTOR .IT IS DIRTY HAVING TONER ON IT JUST CLEAN IT .IT WILL BI OK
BY MIAN AKHLAQ
Oct 14, 2008 | Office Equipment & Supplies
Code 35-02 ( konica 3331 )
problem with fuser, check thermistor, thermofuse or lamp
Oct 06, 2008 | Konica Minolta DiALTA CF910 Copier
Konica 3331
make sure toner is full and corona wire leads havent come lose or broken.
How was the copy quality before the printer was moved also make sure mahine is level
Jan 15, 2008 | Konica Minolta DiALTA CF910 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
110 people viewed this question
k24674
