Question about Xerox Phaser 6350DP Laser Printer
I want to reset my Xerox Phaser 6350 DP Laser Printer. How??
  • 2072 Answers
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
Posted on May 20, 2008
SOURCE: Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Posted on Sep 15, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
nakshatraipu
  • 241 Answers
SOURCE: How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Posted on Feb 11, 2010
How do you reset imaging unit count on a 6350 xerox
You need to buy a chip, like the one in the link below and replace the original one:
http://www.zinetic.co.uk/Xerox_Phaser_6350_Photoconductor_Drum_Reset_Chip-details.aspx
Alex
Sep 12, 2011 | Xerox Phaser 6360 Laser Printer
There is no display on the screen.
if your display on your Xerox phaser 6350 is blank you should replace the control panel (part# 333-4424-00). It's a pretty easy fix, takes about 5 to 10 minutes to install. Here is a video that shows you how. Iteminc.com has this part in stock and ships same day. Hope this helps, and thanks for using FixYa!
Feb 02, 2011 | Xerox Phaser 6350/YDT Laser Printer
Trying to install a new mpt (shootout) assembly for the xerox phaser 6350. Is there a manual/diagram somewhere that I can refer to? Thanks!
Here is a link to the complete service manual for the xerox phaser 6350 it has full diagrams and step by step detailed instructions for every part of the printer
http://www.scribd.com/doc/42787465/XEROX-Phaser-6300-6350-6360-Parts-List-Service-Manual
Hope this helps
Mar 23, 2010 | Xerox Phaser 6350DP Laser Printer
Xerox phaser 6350 has stopped printing on two sides. Have document which did print correctly two weeks ago, now does not.
you need to change the settings again on the printer driver itself:) when printing choose the printer and the settings under printer properties
Nov 20, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox Phaser 6350 Control Panel display problem
If your display has a blank display, displays garbled characters, or the display is inverted or upside down, check out this video
Sep 10, 2009 | Xerox Phaser 6350/YDT Laser Printer
Xerox phaser 6350dp magenta flooding
Your Magenta developers are probably failing. Order 116-2009-00 and see if that fixes it.
Whit
Item, Inc.
Jun 15, 2009 | Xerox Phaser 6350/YDP Laser Printer
The menu screen is blank
If your 6350 has a blank display the most common reason is a bad control panel. It takes about a minute to replace and is very easy. Hope this video helps! Enjoy ">
Sep 18, 2008 | Xerox Phaser 6350/YDT Laser Printer
Phaser 6350 dp
If it is totally blank the control panel needs replaced (LED screen)
Xerox has been replacing those for free...go to xerox.com
This is a customer replacement item. Instructions can be found at:
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=254,E=0000000001178576660,K=1045,Sxi=3,Solution=obj(3229)
If you need further instructions, a video link is at the bottom of that page...
Aug 24, 2008 | Xerox Phaser 6350DP Laser Printer
Xerox Phaser 6350DP Laser Printer Logo
452 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
