Question about Crown CE4000 2-Channel Amplifier
Amplifier dead no power nothing - Crown CE4000 2-Channel Amplifier
  • Crown Master
  • 5,056 Answers
Unplug it. Look inside the unit and see if you locate a fuse. Also look around just to see if anything is damaged or burnt.
Posted on Oct 07, 2009
  • 313 Answers
Check on the back panel there should be a small head where the fuse is its usually looks like a black dial head undo this and check the fuse there.. I have one on teh back of mine that has blown before.. Good luck.. you have checked the fuse in the plug too I hope..
Posted on Oct 06, 2009
My hifonics Brutus 2000 watt has a dead short in it somewhere,as soon as you put power to it it blows the fuse,no lights nothing.any body got any ideas?i have it all tore apart now,but no burn spots
Call hifonics, they do flat rate repairs on their equipment for a reasonable rate. Most likely, you have a shorted mosfet transistor module in the power supply. these are not a smple repair, most local shops won't touch them. 25321271-zkea2bktkzr3q3lrmfdlr2m5-4-0.jpg
Dec 14, 2014 | Hifonics Car Audio & Video
Power to amp but no light happened when my battery went dead replaced
the power amp has a short in the unit and it drain everything out of the battery, that why the battery is dead. it is really possible that a capacitor is open or shorting out cause the unit to drain the battery.
Mar 26, 2014 | Volfenhag ZX-8400 Car Audio Amplifier
Completely dead NAD M15, is there an internal fuse that I can change ?
NAD M15
Problem : Dead
Possible solution : Check for Power Supply
How to Test a Transformer: 7 steps - wikiHow
If these has been done,
• Check amp power supply and low voltage regulators
These includes fuses ( many of them )
Tech Center tells you how to use a multimeter .
• There could be other electronic components but try on them first.
If the torroidal transformer is OK , then it could be a problem on the
Circuit boards.
There could be a shorted components somewhere.
Jul 29, 2012 | Audio Players & Recorders
Kac-8101 no power
no its not dead u prob blew a couple of heat sensors or a capacitor. most defenetly a capacitor. ceck ur capacitor and see if its blowned
Jun 28, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Peavey 8.5c amplifier. One channel dead. In
FIrst of all, in bridge mode there is only one channel. The "bridge" means that you combine the two channels together to get a single more powerful amp. The swollen part is probably nothing. Sometimes the plastic caps cup like that. Unless there is a specific problem with the amp, don't worry about it. Try placing the amp into stereo mode and testing each channel. If both work, there is no problem with the amp. If for some reason you need repalcement capactors, contact Peavey directly. They supply replacement parts.
Dan
Mar 19, 2009 | Peavey Audio Players & Recorders
Subwoofer has power but not getting sound
Some ideas.
Blown fuse in the amplifier section.
Dead amplifier
Dead speaker.
Amp is not that expensive, call Velodyne
Apr 29, 2008 | Velodyne CHT-10 Subwoofer
NAD C 340
Power surges and lightening can reak havoc. It may just need fuse replacement
Apr 12, 2008 | NAD C350 2-Channel Amplifier
Nothin will work
If you've got 12v constant on the yellow, 12v switched on the red, and chassis ground to black, your fuses are good the radio is powered properly.
When you plug the harness into the back of the radio you should hear the CD transport cycle. That's telling you the radio's getting power. Hit the reset button (pin-hole switch on front panel) and hold the small square open/close button for 2-3 seconds.
If still nothing, the radio needs service. I'd send that model to Alpine in CA for repair.
Jan 26, 2008 | Alpine CDA-7998 CD Player
Crown CE4000 2-Channel Amplifier Logo
105 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
