Question about Panasonic TH-50PV30 50 in. Plasma Television
Sagem 45 inch rear projection tv keeps switching off
My tv is 3 yr old and has started switching to standby everytime its switched on, gets picture, sound etc fine for about 40 seconds then switches off to standby, you can do this all day and everytime its switched on it works for up to a minute and shuts down again.. read somewhere it may be dust build up affecting the fan and its closing down due to safety mode, does this sound right to anyone as i dont want to open it up unless im sure cleanin it out will help.
  • Panasonic Master
  • 460 Answers
It is most likely some bad capacitors on the power supply board that are causing it to go into "safety mode" and shuts it down.
Posted on Jun 14, 2017
SOURCE: Power goes off automatically
The flashing light is not a stand by...that a service light telling you it has a problem that needs to be fixed...
Posted on Jun 29, 2007
  • 18 Answers
SOURCE: Panasonic VieraWidescreen Plasma TV Model No TH42PA50A - Power standby mode and tripping off automatically, Please help
Hi, you did not say how many times the red led flashes. This is an important clue as to where the problem might be. On some 6th generation plasmas, a regulator in the power supply could cause that problem and had to be replaced with an improved version.
Posted on Jul 21, 2008
  • 1124 Answers
SOURCE: tv keeps switching itself off
When that happens - try unplugging the tv for a few minuets & plug it back in.. Sometimes it will reset its self.. Or it could be a bad sercut or maybe a falty power suply.. Electronics is usually process of illimination - unfortunately..
Posted on Jul 08, 2009
  • 42 Answers
SOURCE: The TV switches it self off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your TV keeps turning itself off, I would advise firstly checking the power cable connected to the back of the unit to make sure it is secure.
Please also disconnect everything from the TV apart from thee power cable as it may an external device that is causing the problem.
If there are touch buttons on your TV, make sure they are not touching anything and they are clean.
Remove the batteries from your remote control as this could also be turning the TV off.
Posted on Jul 16, 2009
  • 116 Answers
SOURCE: problem with panasonic tv
It is usually caused by problems from lead solder that sometimes does not connect, so there are some points of the components that are not connected with lead solder to the circuit. if it appears vertical line means from the IC (integrated circuit ) Vertical, you can solder all the points in the IC ( Integrated circuit ).
Posted on Jul 23, 2010
My 10 yr old Sony KP-51WS520 rear projection tv come on for about 10 seconds and then shuts off.
Sadly yes. that is repairable but a 55" flatscreen TV is pretty reasonably priced these days. It will use a lot less electricity as well.
Jun 09, 2015 | Sony Televison & Video
My sagem freeview recorder box keeps switching itself off, do i need to buy a new power supply
A new power supply will probably fix this. Make sure to get the same voltage (current can be higher).
Aug 10, 2014 | Sagem Televison & Video
My 45 inch Mitsubishi rear projection tv's picture
Good day!!!
try to see the button below and find the trimmer try to look at it and find vertical hold adjust it..if not helped just go to this link
good luck..
Feb 04, 2012 | Mitsubishi Televison & Video
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung 50" rear projection tv switches off after a few seconds
probably need to replace the Ballast and Power Supply Board. If lamp has not been replaced, I would replace that too. can call 1-800-samsung for nearest service center.
LG 52 Inch Rear Projector TV - switches itself off
LAMP pull it out and see if it looks busted on the inside.
Dec 21, 2009 | LG RU-52SZ51D 52" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv help
This is bad. You need to either be under warranty on these big screen TVs or get the service manual. Especially since this is an off brand.
Jan 01, 2008 | Televison & Video
Panasonic TH-50PV30 50 in. Plasma Television Logo
47 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
