Question about Honda Garden
Compressor will not engage.is there a reset button?
Air conditioner blows hot but freon is full
Your compressor could be faulty. Check to see if it engages when you press the AC button with the car running.
Aug 05, 2014 | 2004 Ford Freestar
Cryostat no longer cools
Try to check the relays. There is what we call a protective thermostat and thermistor for the compressor. Maybe this is also busted. A starting thermistor usually gives way in todays compressors. You can see this in the connector of the compressor.
Jul 07, 2014 | Leica Cm1850 Cryostat
No electrical power to AC Compressor. The switch light comes on in car when AC power button is turned on.
  1. Check if air blows with the fan setting turned to high.
  2. Check that the radiator cooling fan engages when the A/C button is pressed.
  3. Locate the compressor.
  4. Turn on the A/C.
  5. Check if the compressor's clutch has been engaged.
  6. If the clutch engages, the fault is elsewhere.
  7. If the clutch does not engage, check for power to the clutch.
These steps might help find the problem.
Sep 16, 2013 | 1997 Ford Escort
Why does the compressor for the ac on my 2003 ford focus keep clicking ?
I assume it's because your clutch is engaging and disengaging. Could be from a loose electrical plug to your compressor coil on the compressor. It could be a loose plug to the pressure sensor or a bad pressure sensor because that sensor will shut it off if the car is low on Freon causing low pressure in the system. Could be low on Freon so it's on the edge of having enough pressure to turn it on and then shuts it down again because it dips below the pressure threshold when the compressor kicks in. Could be a bad compressor coil that engages the clutch. Maybe a loose connector to the AC Button in the car or the AC Button is intermittent. Could be an intermittent relay engaging the compressor clutch. That's a good list of what all could cause it and if you end up needing to replace the compressor, I made a video on how I did it.
Jul 07, 2012 | 2003 Ford Focus
AC Compressor will not engage.
Inner rim is the compressor. If it wont turn youre compressor is bad.
Apr 16, 2010 | 2000 Saturn L-Series
Air conditioning won't engage
To reset your AC compressor, you need to remove power for at least 15 minutes. After you reconnect, the compressor should turn on. If it does, immediately turn to high and try to add refrigerant. Best of luck.
Greg
Jun 01, 2009 | 1994 Cadillac DeVille
Compact refrig not cooling
Hi!
It is due to multiple reasons, compressor and relay of the compressor being the most common. Is the fan working?
Feb 14, 2009 | Magic Chef MCBR440 Compact Refrigerator
Taylor 770 soft serve
754-27 Taylor soft serve machine Beater motor not running - compressor not engaging - Power to beater relay but not out of relay.
May 18, 2008 | Ice Cream Makers
Garden Logo
80 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
