Question about Dishwashers
Loose wires.one white and one black at bottom of dishwasher
There are two wires one white and one black hanging from the bottom of my dishwasher Model mdb4100aww. is the a wiring diagram to referance this two.
  • 736 Answers
The black wire is the HOT wire ... it should be connected to 120 volts AC .. the white wire should be connected to the neutral/return wire (also white) ... the incoming AC line shoiuld also include a bare ground wire .. that should be attached to a green grounding screw ... if your machine is already hooked up then there should not be any wires hanging down not connected .. you may be able to see the incoming wire but it should be covered by the dishwasher panels .. all connnections should be made inside a metal box that should be provided under the machine and there should be a strain relief fitting that keeps the wire from pulling out of the box .. ..
Posted on Oct 06, 2009
Water leaking from door
replace the seal
Oct 20, 2016 | Dishwashers
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
Maytag Dishwasher mdbtt60aww1
sounds like it is the thermal fuse, located on the main control board. it will have 2 wires connected to it,a black and a black w/white stripe, pull one wire loose and check for continuity. if it is open replace it. should work fine.
Jan 07, 2012 | Dishwashers
Where on dishwasher is power supply? like how do we connect to power?
You connect your incoming 120v supply to the black and white wires on your d/w. the black and white wires are located at the bottom of your d/w on the right hand side in a small box. You may need 1/4in nut driver to open the box and there you will find your white(neutral) and black(hot power) wires located
thanks.
Dec 12, 2010 | Maytag 24 in. MDB5651A Built-in Dishwasher
My dishwasher did not come with power cord. what kind of cord do it need and how do i connect the cord? On the new cord how will i know which one to connect to the white and black wire? The dishwasher is...
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
Jun 13, 2010 | Whirlpool 24 in. DU930PWP Built-in...
How can i tell which wire connects to the white and which connects to the black wire if there not color coordinated?
Looking at outlet and if the round ground hole is on the bottom, the white wire comes from the left side and the black, the right. Reverse if ground hole is on top.
Jun 10, 2010 | Estate TUD8700SQ 24 in. Built-in...
New fixture, flourescent light controlled by switch. There are two bundles of three wires into connectors, one is black,one is white. Two single wires, one white,one red. Light has a black,white,and...
There should be two wires at the bottom of the fan that are loose ends ,, these wires connect to the two loose wires from the lighting kit, white to white and color to color .
Nov 18, 2009 | PROGRESS Lighting Ceiling Fan
Center Sprayer Does Not Fully Recede when cycle ends
There may be some food or mineral build-up on it. Get some dishwasher cleaner and run the dishwasher empty per the instructions.
Or place a dishwasher-safe cup filled with plain white vinegar on the top rack of the dishwasher. Using the hottest water available, run the dishwasher through a cycle - except for the cup of vinegar, the dishwasher needs to be empty.
The vinegar will help to wash away the loose, greasy grime, sanitizes, and helps remove the musty odor.
Aug 13, 2009 | Dishwashers
I have a roper dishwasher someone gave to me and it does not have anywhere to plug it in, no wires loose, and i dont see anywhere to plug anything into it.
Hi
Look at the bottom in front. There is a small metal cover usually with one hex headed screw holding it. Remove the screw and then the cover and there should be one white and one black wire in there. Feed your power supply through the hole in the back and use a romex connector, available at your hardware store to secure your power supply and wire nut the leads inside the box, very tight. Don't forget to put the ground on the Green screw.
Dec 10, 2008 | Roper 24 in. RUD3000 Built-in Dishwasher
Dishwashers Logo
143 people viewed this question
Top Dishwashers Experts
Owen Barnes
