Question about Sony Ericsson K550i Cyber-shot Smartphone
How to solve the call waiting option problem in k550i
I cannot attend a new call and the call answer option is not working when a new call is coming,i activated the call waiting option still this problem is coming
please solve this issue
Once u reset ur mobile or u flash ur mobile. thn it will be working.
Posted on Oct 06, 2009
How can i attend the an other call
You can easily attend another call by activating call waiting on your cell phone.It is in the phone options.
Mar 24, 2011 | Cell Phones
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
The model of my AT&T answering machine is 1720...it is linked to a Brother's fax machine...when a call comes in I am not able to pick up the phone and interrupt the message from the answering machine...
Connect the telephone line of the answering machine from the series connection of the facts machine
.Now set the number of rings for the answering machine to activate to the maximum.{This is found on the side of the machine as a reed switch.}
Now when the calls comes in there is enough time for you to allow it to the answering machine or to attend a call or to set it to facts if a document is comming.While you are away you have to decide the priority needed for either facts or answering as it is a commonline. If answering machine has to work set the facts to telephone mode.If facts has to work set it to facts as the machine will activate before the answering machine.
Sep 02, 2010 | AT&T Lands Phones
Call display won't work as the phone system M7310 keeps picing up on the first ring. I have changed the Auto Attendant and the ccr # of rings but that doesn't help
Try this - keep the handset in the cradle and press:
"Feature 9 8 2", the system will prompt you for a password.
The default password is: "O P E R A T O R"
Scroll through the items by pressing "Next".
The "Answer Lines" should be changed to N(o) to stop the Auto Attendant from answering. You will need to wait at least 2 rings for the system to process the Caller ID info & display it on the phone.
Good Luck!
May 13, 2010 | NorStar M7310 Phone
Phone automatically activates call waiting feature.
Toss it in the dumpster No see if there is an auto answer option . Check and see if the (DELETE TRANSFER BUTTON ) is pushed in i just tested the exact phone and it makes it answer right away when the call comes in . See if perhaps your chin or hand is holding this particular button down
Good luck
~Rick~
Apr 07, 2010 | Uniden DXI-7286/2 Cordless Phone
Help answering calls during peak call times
Yes you need the PC ASA card and not ASX,
Example: to speak to a live person dial 72 and the zero time out option sends it back to reception and it will place it on hold,
reception would need to activate a programmable button ASA button when experiencing high volume calls,
If nobody picks up it will revert to the reception or zero time out attendant with another greeting depending on what type of avaya voice mail you have?
If you have R5 vs mail or Partner mail and not a PC mail some tricks can be done.
This may not solve your answer and ring delay on day or night mode needs to be looked at.
The reality is you can delay the callers ability to get to a live person for a minute or so if they choose to hang out without a ASA card.
Send them to an unused ex port and assign the port to automated attendant two. Depending on you VM we can have up to 5 AA's and greetings.
The fact is if your receptionist can't place the call on hold with a music on hold greeting that says's Bla Bla Bla and more nice stuff and stay on the line we will be with you shortly then you need to hire a new receptionist.
Aug 08, 2009 | Avaya Lucent Partner 616 Phone
With call waiting when you are on a call and another call comes through it disconnects you from the call you are on how do you stop this from happening?
1) Check if you have enabled auto answer facility in your phone.
2) Cancel all Call Divert options.
3) Cancel Call Waiting
4) reactivate call divert if already have.
5) Activate call waiting.
Now try, as I have the same problem with HTC TyTN II, I got solved this way.
Jul 22, 2009 | HTC Touch HD Smartphone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Need more rings
You have to change the rings from the voice mail server. If you don't know your way around the server, its best to get a local NEC tech although it is fairly simple to navigate. Depends on your skill. Typical default password for the server is NEC
Oct 16, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Sony Ericsson K550i Cyber-shot Smartphone Logo
52 people viewed this question
Top Sony Ericsson Computers & Internet Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Are you a Sony Ericsson Computer and Internet Expert? Answer questions, earn points and help others
