I have magnetised my tele how do i reverse it, i put a box with metal bars in front of it and all the colour was pulled to one side
    President:
  • 788 Answers
You should be able to turn the set off for about 30 min. Then turn the set back on and it will degause itself. If it is really bad you may need to do this five or six times.
I hope this helps.
Thanks for using FixYa
asnowman
Posted on Oct 06, 2009
I removed the entire oven door to clean the oven. I am now having trouble putting the door back. Any suggestions.
The process is likely model specific. Your owner's manual might describe how to do it.
I have a Frigidaire/Electrolux (PLEB30S8CCB) and I find removal and replacement some what tricky. The owner's manual says to reverse the removal process, but I believe that that is incomplete.
To take it off, you open the door all of the way, flip up a metal connecting loop on each of the door sides to "bind" an upper J-shaped and lower L-shaped bar on each hinge, and pull the door out, while lifting up the outer handle side. (The pull motion frees the lower L-bar and the upward motion allows the J-bar to slip under a metal roller.)
To put it back on, each side of the oven has a two-part slot. The upper part is for the J-bar and the lower for the L-bar. Put the J-bars part way into their upper slots with the handle side of the door raised slightly to help slip under the metal rollers. Then ensure that the L-bars are fitting into their lower slots. Push the door straight in until a notch on the bottom of the L-bars sets on the bottom of their slots. The trick then is to push the door down to its fully open position, which allows you to flip the metal loops to separate the bars and allow the door to close. Note that pushing the door down makes some noise, but the door should go no more that level with the floor or something may be out of position.
Jul 31, 2013 | Kitchen Ranges
1987 NISSAN 300 ZX REPLACING HEATER CORE. DASHBOARD REMOVED. WHATS NEXT? DISCONNECT STEERING COLUMN TO REMOVE METAL CROSS BAR STILL NOT SURE HOW TO GET INTO HEATER BOX. ANY MECHANICS IN SAN DIEGO?
You got that far, and you seriously want to give up now? With the dash off, I think you could easily pull the whole heater case out, if you need to. On older Datsuns, there was a cover on the front of heater case that unclipped to expose the core for pulling straight back and out-don't know about your 300 ZX, though. Suggest you buy a repair manual for the procedure, or visit a library for a manual. Don't give up now!
Mar 25, 2013 | Cars & Trucks
How to use the buttonhole attachment
You haven't listed the model of your machine so its hard to give you step by step instructions as there is variations in how buttonholes are done. Some machines have a 4 step sequence on a knob, it may be colour coded with a little buttonhole symbol.
Other computerised machines you just select the buttonhole style and pull down a lever behind the needle bar which lines up with the special buttonhole foot to trigger the return stitching down the buttonhole side.
Have a look in your accessories and see if you have a buttonhole foot like this
tally_girl_76.jpg If so, remove the current pressure foot and put this on, clip it onto the little metal bar you see near the front of the foot. Now put your button into the back ratchet bit of the foot, you pull it out, place the button in there and close it up firmly to hold the button in place. This helps to give you the right length buttonhole.
Now you need to start the buttonhole stitching sequence and sorry, but I don't know what your machine's is, you really need to check the manual for this bit. It may be a 1,2,3,4 sequence on a dial and probably stitch length set to 0.5 so its a closed up satin stitch.
But you stitch the butttonhole in the folowing sequence:
near bar tack, reverse down right hand long side, far bar tack, then back up left hand long side, then a couple of stitches in place to finish off.
The buttonhole foot will sit firmly on your fabric and the inner part of it will move backwards as the machine stitches, then comes back to the front again.
The computerised machines will have a little lever you pull down and these will trigger on a lug on the buttonhole foot to start the reverse stitching at the right length buttonhole. Sometimes they will stitch both long sides in the same direction too, so sequence is near bar tack, down right hand side, far bartack, then it will stitch back to front in little straight stitches, then do the left hand long side to the back and finish off.
On early machines, you actually set the stitch length to 0.5, and stitch width to 2 for sides and 4 for bartacks and made the buttonhole yourself by stitching down one long side, leaving the needle in the fabric and pivoting the work around, then stitching the bartack, then the other long side, then final bartack all manually. It can be done but obviously the new programmed ones are far easier and give consistently similar buttonholes on a garment.
ALWAYS, interface the fabric to be buttonholed, you'll never get a good practice buttonhole without interfacing in a sandwich between two layers of fabric so no point practicing without it.
And, never cut your buttonhole with the seam ripper unless you pin across the two ends first to make sure you don't have a woopsy moment and rip through the end bartack. I use a buttonhole knife and block of wood to cut and it ensures you never have a cutting disaster.
I also pull the thread tails through to the underside with a needle afterwards, tie them off and add a dab of fray stopper to make sure the buttonhole never unravels, then trim the ends off close.
I hope this helps you but obviously getting the manual to your machine would be a big help too.
Sep 21, 2011 | Husqvarna Sewing Machines
I HAVE A MATSUI 28WN20 CRT TELEVISION AND ITS COLOUR HAS TURNED REALLY WEIRD. FOR EXAMPLE BLOOD SPLATTER COMES UP AS GREEN AND ALL THE REST OF THE COLOURS YOU SEE ARE ONLY PURPLE AND GREEN .
Hi, this sounds like your TV needs De-Gaussing, the screen has become magnetised and the electrons being fired at the screen are being diverted or scattered and mixed to the area's that are magnetised creating the odd colours, what you need is a de-gaussing coil, you can wave this in a pattern to de-magnetise the screen thus allowing the electrons to flow properly to the screen, it may also be the PTC on the tv's PCB near the mains input, if this is faulty the tv's own degaussing coil may not operate properly, you local TV technician maybe able to help with this as the part is specific to the TV, they maybe able to degauss it too for a small fee.
Here's a better expaliation ---> CLICK HERE <---- it shows a circular pattern here but there are many kinds of pattern magnetism can create but the colours are nearly always the same just in different places witn different strengths.
Hope this helps.
Feb 11, 2011 | Televison & Video
Help removing the third seat on my Suburban
first open your rear hatch/doors.2nd fold third seat over buy using latch on right side. 3rd pull relase handle in middle of seat on the back bottom . this unhooks the back latches. use the other hand to pull meatl bar up, tipping seat. 4th while holding metal bar with the one hand use the other hand to pull small release strap. it is too the right of the metal bar, this releases the front latches, pull rearward the seat moves out. the seat is heavy good luck
Dec 30, 2009 | 2004 Chevrolet Suburban
How to replace cabin air filter in 2003 pilot
Step 1 Take everything out of the glove box on the passenger side. Squeeze the black clips on either side of the glove box interior to free it from its retainer and pull it toward you. It will glide forward on hinged arms. Lower it as much as possible so it's out of your way.
  • Step 2 Identify the gray plastic bar that runs from left to right across the bottom of the glove box opening. This is a piece of plastic molded to the rest of the glove box assembly, but it covers up a removable bar that is mounted directly in front of the cabin air filtermag-glass_10x10.gif case. You'll have to cut this plastic bar off with a razor knife to proceed. Fortunately, this isn't too difficult; just cut carefully and steadily, and make your cuts as close as possible to the ends of the bar.
  • Step 3 Remove the metal bar you uncovered in the previous step. It is screwed into the glove box assembly with Phillips head screws on either side.
  • Step 4 Open the cabin air filter case, which is the large plastic case on the left side off the glove box opening. The hatch will come all the way off when you open it.
  • Step 5 Take the old air filter out of the case and throw it away.
  • Step 6 Look at the arrows on the filter and the arrows on the filter case that indicate the direction of the air flow. Slide the new filter into place so that the arrows are both pointing the same way.
  • Step 7 Put the lid back on the air filter case and reinstall the metal bar you removed in Step 3.
  • Step 8 Push the glove box interior compartment back into place and listen for the snapping sound. Put the glove box contents back, close the lid and you're done.
  • Dec 06, 2009 | 2003 Honda Pilot
    I have lost my manual and can't remember how to thread the Tiptronic 2040
    Make sure you have your spool of thread pushed all the way back on the spool pin with the proper size thread cap. Make sure your foot is in the up position, as this opens the tension discs. There is a small metal circle on top. Pull the thread behind it and under it and directly down. Come back up the other side and around the take-up lever. If you cannot see the take-up lever, move your handwheel until it is all the way up. After you have threaded it around the take-up lever, it comes back down this same side. On either side of your needle bar are two small metal clips. It doesn't matter which side you put the thread into. To put it into the clip, hold the thread taunt and pull it from the outside in against the clip. Now put your foot in the down position. When you pull the thread, it should be tight. Push your needle threader all of the way down. It has a tiny (extremely tiny) hook that will come through the eye of the needle. Wrap the thread around the metal bar/hook on it and gently bring it in front of the needle but under the metal guides that are in front of the needle eye. This next part takes some coordination, gently realease the thread as you simultaneously release the threader. It should pull a loop of thread through the back of the needle.
    Also, when you wind a bobbin, you must thread it through the top of the metal disc on top and not underneath it. This provides the correct amount of tension for bobbin winding.
    If you are not sure if you have threaded correctly, with the foot in the up position, pull on your thread. It will pull freely off the bobbin. With the foot down you should have a lot of resistance. Good luck to you!
    Sep 11, 2009 | PfaFF Tiptronic 2040
    2008 honda pilot cabin air filter
    This solution pertains to a 2008 Honda Pilot...To replace the cabin air filter which is located on the passenger side of the vehicle behind the glove box: Open glove box and remove stored items...while sitting in the passenger seat, pull towards you on each of the two clips on the left and right side of the glove box...this will cause them to become loose and the glove box will tip out completely exposing the inside of the dashboard. (Alternately...carefully pull towards you on the top center of the glove box which will cause the left and right side stops to pull away from the edges and allow the glove box to tip out) Here it gets tricky...the box holding the cartridge for the cabin air filter is the large black box on the left side behind the glove box The filter fits in a removable tray vertically inside that box. A pressure clip at the top of the box allows the vertical cover to be removed exposing the tray with the Cabin air filter... BUT!!! There is a plastic bar an inch or so high which has been placed there by the manufacturer to prevent most from changing the filter without the service department being involved. This bar must be cut with a sharp sheetrock knife or hacksaw and discarded, (it will not be reinstalled). Then there is a flat metal bar behind the plastic bar that can be removed using an 8mm socket and a phillips screwdriver. There are 2 8mm screws and one phillips head screw on each side that must be removed in order to remove the metal bar. THEN you can remove the cover to the cabin air filter box, pull out the tray with the filter (note how the filter is in the box so the new one can be placed the same way) reinsert the tray with the new filter and replace the tray cover. All other steps to finish the job are obvious as everything is the reverse. Actually the whole process is a lot of trouble and unless you are determined to change the filter I would recommend not doing it.
    Aug 24, 2009 | 2008 Honda Pilot
    Need to replace my Maytag the door is reverseable. Who makes those now?
    The doors are reversabe they go from left hand open to right hand open. Just reverse the hinges, put the door fillers ( triangle shape go toward the front. Remove the plug put it in the other sidel. Now take the metal door strke and put it on the other side, Then take the filler from on side and put it on the other side. Takes 10 to 15 minutes to make the change.
    No need to purchase another door!
    Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Volume very low won't go up
    After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
    2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it. 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up. 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
    Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
    5. Put the FR speaker box back together in reversed order. 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again. As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
    Aug 08, 2008 | Altec Lansing Multimedia Computer Speakers
    Televison & Video Logo
    21 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
