Question about Brother DCP 115C All-In-One InkJet Printer
Cannot use printer
Machine showing paper jammed carried out all on site checks unablke to clear fault
  • 2 more comments
  • Anonymous Jan 03, 2008
    Unable to Print....See Troubleshooting and routine,,,, and there is no paper jam
  • alb_tinker Feb 13, 2008
    black ink failed to print. i tried to clean it several times. the colored inks work well. i tried to change the black ink, still it's not printing. how do i reset this printer (dcp-115c). will appreciate a step by step guide. tried i tried to hold down "menu" while turning the printer on. but didnt work.
  • Anonymous Feb 14, 2008
    printer showing paper jam, but there is no jam carried out all checks.
  • mgaizu Nov 22, 2008
    unable to print error message. no paper jam
  • 832 Answers
Press menu then start bk copy then fourtimes arrow up (+). machine will be in maintenance mode. What error code does the display show up?
Posted on Dec 23, 2007
Colour Xerox Machine problem
its a problem with the fuser unit ,its overheating .two ways to solve it first check if the sticker paper is supported by your printer ,2nd you may need to replace the fuser unit
Oct 02, 2014 | Xerox DocuColor 242-252-260 PS
My printer (mp 160 pixma) shows error code 5,3,2 what is the problem
E2 = Reload the paper correctly and press [Black] or [Color]
E3 = If paper has jammed in the machine, clear the jam, reload the paper in the
machine correctly and then press [Black] or [Color].
E5 = The FINE Cartridge may not be installed properly, or the Cartridge may notbe the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Nov 02, 2013 | Canon Pixma Mp160 Mp 160 Photo All-in-one...
Repeat paper jam
there likely a jam in there your not seeing or feeling
Jan 26, 2013 | HiTi P510L Digital Photo Printer w/Breeze...
Machine diplays "paper jammed" with no paper in
Hello
This the method to clear paper jam, follow these steps:-
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Turn off the printer.
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Open any other doors that give access to the printer's paper path and to the ink cartridge. 5 If necessary, remove the ink cartridge. Place it in a bag or away from light to avoid damaging it.
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Replace the ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Good Luck
Dec 18, 2010 | Sharp UX-B20 Plain Paper Inkjet Fax
I get the E 3 error message which I understand means paper jam. There is no paper jammed in the printer. I unplugged it and replugged it and it sill shows the E 3 message.
E3 error mean if printer has jammed in the machine.Clear paper jam,or paper feed sensor was displaced.clear or check paper sensor then solve your problem.
Dec 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Printer keeps saying paper jam even after all doors are cleared of paper jam. Reset didn't work.
Dear, there is very minor mechanical fault but it is better to visit the repair shop to fix it.
Best regards
May 25, 2009 | HP Photosmart C6100 All-In-One Printer
Paper Jam fault
there are sensors that tell the machine the paper is jammed us a q-tip to clean them, remove the toner cartridge and check under that area when cleaning the sensors.
Mar 16, 2009 | Samsung SCX-4521FG All-In-One Laser...
Paper jam
HP has a web page on its site that shows you how to clear a paper jam for this printer:
Paper Jam Solution.
Good luck.
Oct 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Paper jam won't clear
Look for a small piece of paper remaining in the machine.
Also there may be a jam switch actuator that has fallen off.
Dec 07, 2007 | Panasonic Workio DP-2310 All-In-One Laser...
Brother DCP 115C All-In-One InkJet Printer Logo
85 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
