Question about Compaq Presario Notebook
While installing xp showing error
I am using compaq presario cq40-310tu...already vista is loaded. i try to install xp. it is showing blue screen error. pls help me.........
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
Hi Friend
Try this may help you in creating a dual boot.
First find the drivers for your network components, wireless card or nic, and save them to an external device such as a floppy disk or flash drive.
Then you will need to go into the BIOS on your computer startup. Scroll to the System Configuration tab and go down to the SATA Native Support and change its setting to Disabled. Then hit F10 to Save and Exit. (You don't need to change the BIOS if you have an ATA or IDE hard drive.)
Next, insert your Windows XPWhile installing xp showing error - mag-glass_10x10.gif CD and create the partition you wish to install XP on. After the installation is complete you should boot automatically into XP. (To do this, right click the Computer icon in start, and select manage. Then select Disk Management, and you can do whatever you want with your partition.)
Now you need to move some files. First, make sure you have set your folder options to see hidden files and to show protected operating systemmag-glass_10x10.gif files. Then open Windows Explorer and go to the drive where Vista is installed. Copy the folder Boot, and the files bootmgr, boot.ini, NTDETECT.COM and ntldr and paste them to the root of your XP drive.
Then download Vista Boot Pro and save it to your desktop or somewhere else that you can easily access. Unless you already have .Net Framework (v2.0 at least) it will redirect you to a Microsoft page where you can download this necessary component.
Install and run Vista Boot Pro and open the "Bootloader" tab. Select "Reinstall the Vista bootloader" and press Apply. Then go to the Manage OS Entries tab and select "Add new operating system entry" and make sure you select "Windows Legacy". Give the new entry a name (ie: Windows XP) and select the drive letter you have XP on and then select Apply. You can also choose which entry you would like as the default the system will boot to.
And now you should be able to dual boot between Vista and a previous OS.
I hope this will help you out. Please vote for me.
Posted on Oct 06, 2009
Compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK WON'T WORK REPLACED HARD DRIVE CAN'T GET BIOS TO RECONIZE HARD DRIVE SHOWS UP IN BOOT BUT NOT IN MAIN HP SAID TO INSTALL NEW OS HAD OLD 98SE LOADED WORKED...
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Jul 11, 2010 | HP Compaq Presario SR1650NX...
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
Jun 07, 2010 | Compaq Computers & Internet
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Mar 19, 2010 | Compaq Presario Notebook
I HAVE A COMPACQ PRESARIO CQ40 108TU WHICH HAS INTEL DUAL CORE 2.0GH, 1 GB RAM,AND SAMSUNG 150 HARD DISK. I CAN INSTALL WINDOW VISTA BASIC, WINDOW 7, WHICH I HAVE ALREADY TRY. BUT WHEN I TRY TO INSTALL XP...
what happen is this once you see such again change the Operating CD you are using and get another XP CD to try it again it might be the fault of the CD but if it persist then find a system that you will us it to format your harddisk and load the operating CD then later you change it back and ready for use
Feb 20, 2010 | Compaq Presario Notebook
Installation for xp problem
all the hardware on the laptop is most likely configured for windows vista meaning it will not allow xp to load up because your hardware cant run it
Oct 09, 2009 | Compaq Presario Notebook
Cannot install windows xp in CQ40-317tu
hi aman this is saurabh ....i can solve ur problem...let me tell u that tere has been a colobration between microsoft and hp that hp will not install any hard disk drivers of any old operating system that is basically xp...thats why when u try to install xp u get an fatal error of hardidsk error.....so i have made a cd in which the drivers r prem loaded and it will run in ur compaq presario.......so u call me i will send u the cd...my no is 09896038291
Sep 30, 2009 | Computers & Internet
Intalling window xp over vista
XP does not include SATA drivers in the distribution. You need to get the SATA drivers for your particular model from HP's website and watch for the prompt to hit F6 when prompted to install SATA or RAID drivers.
The trick is that the mechanism to add these drivers at this point assumes that you have a floppy drive which is rare these days. There are a number of work-arounds for this, here is one:
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Aug 18, 2009 | Compaq Presario Notebook
A blue screen of death appear during the installation of xp
It could of been a virus already on your system because vista isn't that good.
Feb 25, 2009 | Microsoft Windows Vista Ultimate Edition
Install Vista on cq40-144tu
Take out the hard disk put it on the externaslcase hard disk and format the disk wipe all data from it , and chek the bios seting, put the bios on default seting than you will be able to instal wich OS you want. chek if you have enogh ram for vista , if no put XP not vista. wen you will have more than 1GB  put vista.
Jan 20, 2009 | Compaq Presario Notebook
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
Compaq Presario Notebook Logo
154 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
