Washing machine won't drain the water What's wrong?
  • sparktgo
    sparktgo May 11, 2010
    have you checked the pump is working.If so remove the hose to the pump and make sure the pump itself or hoses are not blocked
    Problem Solver:
  • 18 Answers
Item stuck in pump
Posted on Oct 06, 2009
Pump won't drain water and keeps faulting for pump cleaning. Have turned it off, unplugged pump filter, cleaned it and restarted it several times with no luck. What else could be wrong??
Check to see if there is a drain filter. My GE has a small "door" at the bottom of the machine that has a filter behind it. If so ALL of the water will drain when you open it so be prepared. Then clean all of the junk from inside the filter or "trap"
Apr 15, 2013 | Washing Machines
Water won't drain.how do I know if drain hoses are
The problem is more likely a clogged pump or maybe a clogged drain line. If the machine worked at all, that would eliminate wrong connection of the drain line as a cause
Mar 25, 2013 | Washing Machines
Ecosmart washer won't drain it filled with water, washed and nowwon't drain the water.
you need to vacume out all the water so you make it light, then dolly out the washer to some place you can drain it. now take off the front of the washer and locate your water pump, its attached to your drain line. take off drain line to water pump and see if anything is clogged in the pump. This is most likely what is wrong if it wont drain. hope this helps.
Feb 22, 2013 | Fisher Paykel EcoSmart GWL15
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Kenmore washer 80 series does not drain
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Here are some steps to help you determine the problem and solution:
1. Pinched hose: Is the drain hose at the back of the washer been flattened or twisted in any area? A pinched hose could prevent the water from draining thoroughly. Gently straighten the hose, and make sure there is sufficient room between the back of the washing machine and the wall to prevent a repeat of the problem.
2. Clogged drain hose or pump: Does the drum spin normally, but the washing machine won't drain the water? Sometimes a piece of clothing, money, fabric or other debris gets into the water between the inner and outer tub. It may then make its way into a drain hose or even into the pump itself. The farther into the machinery a clog goes, the trickier it can be to remove. Call a repair professional for help.
3. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
4. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
5. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
6. Pump failure: Is your washing machine more than 7 years old? Your pump may simply have worn out. Even if it sounds as though it is running, the pump may not be working well enough to draw the water out of the machine. Replacement parts for pumps are generally unavailable. A new pump may be necessary.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Asko 620 washer won't drain well with heavy load
When your washing machine won't drain, it could be as simple as a kinked hose or as complicated as a faulty impeller on the pump. Overloading your washing machine can cause items to be swept into the space between the inner and outer tub, leading to clogs in the drain hose or pump. These clogs may be the reason for why your washing machine won't drain. Here are some steps to help you determine the problem and solution:
Oct 08, 2012 | Asko W6021 Front Load Washer
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Washing machine won't rinse and the water won't drain out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 04, 2011 | Washing Machines
Fills with water, won't spin water out, get F50 message
heatman101
Aug 28, 2011 | Washing Machines
Front loader won't spin and is filled up with water. Won't drain.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
May 15, 2011 | Kenmore Energy Star 44092 Front Load...
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
