Question about HP Photosmart C6180 All-In-One InkJet Printer
Cannot start, keeps power failure - HP Photosmart C6180 All-In-One InkJet Printer
Keeps taling longer for tv to start
Probable power supply decline to failure.
Dec 28, 2013 | Toshiba 46XV640U 46 in TV
Frigidaire lra157mt1
Some of the new style Air conditioners have a auto time delay built into them for power failures. If power fails or you unplug the unit, they will not come back on for about 3 to 5 minutes. This is a safety feature to keep power failures from damaging the compressor. Keep it plugged in for 5 minutes and try again. If still no go then call for service. You should have a 1 year warranty on it.
May 27, 2012 | Frigidaire Heating & Cooling
PF code comes on
Check all the wiring to the dryer and even the wires in the wall socket. Sounds like there is a loose wire since you keep getting the power failure (PF) code on the dryer.
Dec 27, 2011 | Whirlpool GGW9868K Gas Dryer
What does the code 12 flashing mean
Flame failure. The stove started and ran for a while then quit. Out of gas, power failure??? Try to restart. IF you get an 11 code then you may be out of gas.
Keep us posted.
Tom
Oct 22, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Inspiron 531s will not boot up, keeps beeping, saying it is in power save mode. How do I fix the problem
System Beep Codes The Inspiron™ 531 / 531s system can emit a series of beeps during start-up if the display cannot show errors or problems. These series of beeps, called beep codes, identify various problems. One possible beep code consists of repetitive three short beeps. This beep code indicates the computer encountered a possible system board failure.
The series of beeps has a 3-second delay before it repeats. The series and delays continually loop until you press the power button.
Code Description Suggested Remedy 1 BIOS ROM checksum in progress or failure System board failure; covers BIOS corruption or ROM error 2 No memory modules detected
  1. If you have two or more memory modules installed, remove the modules, reinstall one module, and then restart the computer. If the computer starts normally, reinstall an additional module. Continue until you have identified a faulty module or reinstalled all modules without error.
  2. If available, install a good memory module of the same type into the computer.
  3. If the problem persists, contact Dell.
3 Chipset error (North and Southbridge chipset, DMA/IMR/Timer Error for Intel® platform); chipset error System board failure. Power LED is blinking amber. Time-Of-Day Clock test failure Gate A20 failure Super I/O chip failure Keyboard controller test failure 4 RAM read/write failure
  1. Ensure no special memory module/memory connector placement requirements exist.
  2. Verify the memory modules you are installing are compatible with the computer.
5 Real time clock failure. Possible battery failure or system board failure.
  1. Replace the battery.
  2. If the problem persists, contact Dell.
6 Video BIOS test failure Video card failure 7 CPU cache test failure Processor failure
Oct 06, 2010 | Dell Inspiron 531s Desktop Computer
When i plugged my cooker in the numbers started flashing all zeros and now none of the buttons will change the screen except the cancel button. When that's pressed the screen goes blank for a second it...
I am having the same problem. Here is what the Tiger people say. I haven't tried it yet though.
* If an external power failure has occurred, but only for a short time, then there's a possibility that when the electricity has returned, all functions may work normally and the clock is working correctly.
* When a power failure lasts for a long time, and the indicator is flashing 0:00...
--> Please set the time correctly by following the instruction manual.
If the electricity has returned as in these situations below:
(If it's already past the set time, after a lengthy power failure, cooking starts immediately.)
* While cooking rice (or reheating rice).
--> Continue to do the cooking (or reheating).
* Keeping warm (or Low temp Keeping warm).
--> Continue to keep warm (or low temp Keeping warm).
Aug 25, 2010 | Tiger JAE-A10U 5..5-Cup Rice Cooker
PF(Power Failure) error appears each time the washer starts.
PF simply means there was a power failure since the last time you used the machine.
To clear it - simply power cycle it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Itronix VR-1 Go Book Fan Failure message
After bios upgrade had same problem. DISCONNECT AC POWER PULLED BATTERY FOR AT LEAST 5 MINUTES THEN REATTACHED BATTERY AND FAN WORKED ON NEXT RESTART. Also make sure boot menu ( tap F12 at start-up) is set to boot from Hard Drive. I also started on battery power with no ac adapter.
Apr 17, 2009 | Computers & Internet
Problem with power
Since I don't know the exact circumstances of your power loss, here what I am guessing based on that you wrote.
This may be because the power does not come back cleanly after the power failure. Unfortunately, there is nothing much you can do about it. Since your router does work correctly after you manually reset it, the power supply seems to be fine.
If you have many power failures and find this situation to be annoying, you should look to buy a UPS (Uninterrupted power supply). This kind of devices have a battery that will ensure a clean power output when running, powering up and shutting down. It will protect you from interruptions and voltage fluctuation. You may also benefit from connecting you computer to a UPS because it will keep it running for a couple of minutes after a power failure to allow you to save your work and may also shut it down cleanly automaticaly.
Feb 23, 2008 | Compex NetPassage 27G Wireless Router...
HP Photosmart C6180 All-In-One InkJet Printer Logo
23 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
