Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
CANON POWERSHOT A640 LCD VIEWFINDER STOPPED WORKING
For some unknown reason my canon powershot A640 LCD viewfinder stopped transmitting an mage for viewing & shooting. The only thing I did was change two of the batteries correctly. It was working fine otherwise. Have never dropped it always carry it in a protective case. No water on it etc.
The playback and menus work fine so it is not broken. I musthave hit a switch or option by mistake?
Help!!!!!!!!!!!!!!!
  • 736 Answers
Nice camera ... the button at the bottom left is marked Disp ... each time you push that button it will change the display mode ... there are three modes .. OFF, ON , and NIGHT ... night turns down the brightness a bit ... push the button several times until you get the display you want ..
Posted on Oct 06, 2009
Testimonial: "Excellent Yes I did by that by accident but could not figure out what I did to get the 'Digital Zoom' row in the menu to become enabled again. "
I need a new screen for my canon powershot A640 ASAP.Mine is smashed for the second timme. Where could I possibally get1?
If you're confident you can do the job yourself, you can order the part from
http://uscamera.com/ck9-1241.htm
Dec 11, 2010 | Canon PowerShot A640 Digital Camera
Canon PowerShot A640 lens problem
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 31, 2009 | Canon PowerShot A640 Digital Camera
How to select date stamp on canon powershot a640?
You can print the date on image when Postcard is selected. The date will be printed on your images even if it has not been set at the computer or printer.
* Ensure that the camera's date/time is set beforehand.
* Set the camera to a shooting mode (except (Stitch Assist) or Movie).
* Press the <DISPLAY> button so that icons show on the LCD screen.
1. Check that appears on the LCD monitor.
- If it does not, click here to view the procedure for changing the resolution.
2. Press the <MENU> button.
3. Select (Date Stamp) in the [ Rec.] menu using the or buttons.
4. Select [Off], [Date] or [Date & Time] using or .
5. Press the <MENU> button to exit the menu.
6. Shoot the image.
- The Date or Date & Time will be embedded into the actual image.
Jul 27, 2009 | Canon PowerShot A640 Digital Camera
LCD Screen not working, but camera still takes pictures
Looks like the contacts of the LCD of your camera are loose. Be advised that this repair would require you to take it apart and may vvoid your warranty. If there are no faulty contacts then you will have to replace the LCD screen. Should cost you around 100-150$
Nov 14, 2008 | Canon PowerShot A640 Digital Camera
Powershot pro1 viewfinder show blank white
Hi
When the LCD screen is open the viewfinder will switch of and when it is closed the viewfinder will switch on. You can switch between the two by pressing Monitor select button to the left of the Eyepiece (Viewfinder). as you look at the back of the camera.
Hope this helps.
Jul 15, 2008 | Canon PowerShot Pro1 Digital Camera
Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Jun 16, 2008 | Canon PowerShot A640 Digital Camera
Black screen on my Canon PowerShot A640
I had this problem too. Try the "DISP" button (bottom left on the display side of the camera. It allows you several viewing options, and is easy to accidentally hit and turn the LCD screen "off."
Apr 27, 2008 | Canon PowerShot A640 Digital Camera
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
279 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
