Question about Maytag Irons
Not generating steam. what is the problem? can it be fixed?
Can't get my Morphy Richards steam generator off of standby
do this and use the common sense. God bless you
f the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below). If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat (see the Appliance Controls Fix-It Guide).
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water
Sep 24, 2012 | Irons
My team generator iron will not steam
Have you any other suggestions? Yes. Dump it.
Jul 16, 2017 | Morphy Richards Irons
Rowenta steam generator iron will not shut off the steam (continues to steam until resivior is empty)
see the pictorial, and proceed according
clean the mechanismo +passages+examine steam component for loose, worn, or broken and replace. God bless you
Sep 06, 2012 | Rowenta Steam Generator DG050 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
Maybe the cap is coated with mineral deposits. Do you use ONLY DISTILLED WATER in the iron? If not, minerals from the water could be the cause. Try pouring some CLR or a similar product over the cap and see if that frees it up . If it does, pour some CLR into the iron's tank, and set it to the highest temperature setting. Run the iron over an old towel to help clean the steam vents. Then fill the tank with DISTILLED WATER and do the same proceedure two more times using DISTILLED WATER ONLY to flush out any remining CLR.
Aug 27, 2008 | Rowenta Steam Generator DG050 Iron
Hi i have an edbs920 steam generator iron, my problem is that it will dry iron but wont steam up anymore, after turning the system on the power indicator light should turn from the flashing orange pre...
it can be that one of the thermostats controlling the water flow pump into the steam generator has become open circuit, caution is advised as this can potentially overheat the steam generator for there being lack of water, depending on your system design...i could be wrong just a guess !
Apr 30, 2008 | Euro-Pro Steam Generator EP8001 Iron
EP8001 Steam generator.
Sears sells a screwdriver set (47486 is written on the handle) that has a lot of non-standard drivers. There is one on there that will fit the nuts on this unit.
Also, I used a rubber tube from an Auto parts store to replace the cracked hose. I figured the Automotive hosing was designed to withstand the heat of an engine. So, it should work on this iron.
Bring the cracked iron hose with you to the auto parts store.
Oct 07, 2007 | Euro-Pro Steam Generator EP8001 Iron
My Tefal Steam Generater Iron will not steam
check the little tube that regulates the water to the holes it needs to be changed.good luck.
Nov 08, 2006 | Tefal Ultraglide 1549 Iron
Irons Logo
23 people viewed this question
Top Maytag Irons Experts
Are you a Maytag Iron Expert? Answer questions, earn points and help others
