Question about KitchenAid Architect Series KEBC107KSS Electric Single Oven
No heat after self-cleaning
My problem matches all of yours. KitchenAid Model KEBC107KSS05
We used the self-cleaning feature for the first time and now it will not heat up, yet all the controls work normally.
I will yank it out tomorrow.
This is a long-term known problem and it does not look like there is an upgraded part. Typical.
  • 3 Answers
This was my exact problem. Our oven is almost identical, but mine so this could likely be the same fix. Check the details here:
This post was helpful as well: here.
Posted on Oct 17, 2009
2 Suggested Answers
SOURCE: After using self cleaning feature...oven door
Hello - we have had this same issue a number of times as well. Do you lose all power on the unit too? We do - have discovered that using the self-cleaning isn't really a good idea with these ovens. The ovens aren't really made to heat to such high heats that are used in the cleaning cycle and during that last hour of cleaning it hits it highest peak - and it blows it's fuses. We recently blew 2 fuses at the same time, locking both doors (Double oven) and knocking out the power for the entire unit. Our repair man said that the average on wall ovens is anywhere between 6 - 12 cleanings before you will blow the same fuses and the whole cycle starts all over again. Our expense was $350. So, self-cleaning now means elbow grease around this house. How this information was a bit helpful for you.
Posted on Aug 08, 2010
Owner's manual re self clean feature Kithcen aid Superba27 self clean double oven purchased 1988 Cannot get it to turn on and heat. The Lock light does not go on and no heat is generated.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 17, 2011 | KitchenAid Ovens
Convection won't heat up after I did the self-cleaning option
I ran into about 10 of these last week, when you ise self clean after a long time of not using it. It heats to about 550 degrees and fries the thermal cut off. This is a fairly inexpensive repair. Send your model number and i can tell you how much it would cost and how to do repair.
Dec 01, 2010 | KitchenAid Ovens
After using self cleaning feature...oven door locks up...4th time this has happened...kitchenaid says "no known issues with your unit or the problem you reported...can you halp
Jul 02, 2010 | KitchenAid KEBC208 Electric Double Oven
The self cleaning feature does not work. After I
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Jan 30, 2010 | KitchenAid KEBC107 Electric Single Oven
KitchenAidKEBS107: NO HEAT after power failure during self clean
Thermostat on the back needs replacement. The problem is caused by overheating the oven. Improper installation or inadequate blower. Depending on the model, the oven might need a new blower in addition to the thermostat. Try calling KitchenAid to find out if the oven needs that blower and get the part number for the thermostat, they might have replaced it with the one with higher temperature rating.
Nov 26, 2009 | KitchenAid KEBS177 Electric Single Oven
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
Missing my manual
I suggest you read this link before you use the self clean cycle. http://www.fixya.com/support/t241114-oven_will_not_heat#SameProblemContinued
I used mine for the first time two days ago on model KEBC147 and it will not heat now.
You might not want to try self-clean unless you have time to call for repair afterwards before
using your oven again.
Very disappointed in KitchenAid in Texas ...
DBN
Oct 24, 2008 | Magic Chef 9815 Electric Single Oven
KitchenAid Architect Series KEBC107KSS Electric Single Oven Logo
171 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
