Question about Cyberhome CH-DVD 300 DVD Player
Disc removal/ CH-DVD 300
My DVD player has frozen up on me. I am not able to remove the disc from my player.
I am also not able to turn the player on, either manually or with the remote.
  • Anonymous Feb 13, 2008
    The same problem. I exchanged it two times and all three stopped working. The DVD got stuck in one of them and i used the button on the bottom but was still unable to power on the unit.
On the bottom of the DVD player, there is an "emergency slot." I used a knife to push the botton over which manually opens the door to get your DVD out. However, I can't turn my DVD player on either. And can't figure out what the heck to do??!?!?!?!
Posted on Feb 10, 2008
It won't play a dvd! and when it does it just sits like it is stopped!!
Eject the DVD from the Cyberhome DVD player. Look over the bottom of the disc. If any dirt and fingerprints are present, remove them with a damp cloth, moving from the inner circle of the DVD to the outside.
Insert the DVD into a scratch repair device, if the DVD has any light scratches (deep scratches are not reparable). Turn on the DVD repair kit and the device literally sands down the scratch. When this is finished, the DVD should work correctly with the Cyberhome DVD player.
Avoid inserting homemade DVDs into the disc drive. The Cyberhome is not compatible with many self-created DVDs, causing a "Disc Read Error" message to appear on the screen.
Spray compressed air into the disc drive of the DVD player. The compressed air removes dust and other debris from the laser and reading lens in the player.
Apr 25, 2011 | Cyberhome CH-DVD 300 DVD Player
Why does my player display
Sorry, the player is dieing. i had this player with the same problem.
Jul 05, 2010 | Cyberhome CH-DVD 300 DVD Player
Cds fine; dvds won't load
Most likely the DVD laser lens is dirty. Unplug the CH-DVD 300 from the wall outlet, wait 5 minutes, then remove the top cover. Next, remove the rectangular metal plate which covers the area where the CD or DVD disc would be when in the player's tray. Underneath the rectangular plate you should see two small lenses. Gently clean these lenses using ear swabs moistened with isopropyl alcohol. Reassemble the CH-DVD 300 in the reverse order that you disassembled it, plug it back into power, and now it should read your DVD discs just fine.
Aug 13, 2009 | Cyberhome CH-DVD 300 DVD Player
Long loading time, then readout says, bad disc.
The lazer beam of the disc has a micro dust that need to remove. You can try to use the cd cleaner. If nothing happen , you need to open the disc and spray the lenses with soft air.
Jul 26, 2009 | Cyberhome CH-DVD 300 DVD Player
I have a CyberHome DVD 300. It will not load disc.Indicates that no disc inserted. I have cleaned the disc to no avail.
you will need to remove the cover and clean the laser eye with rubbing alcohol and cotton swab (q-tip)
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
Picture will freeze.
Either the disc is scrathed or you have to remove the cover and take a q-tip with rubbing alcohol and clean the lens.
Jan 22, 2009 | Cyberhome CH-DVD 300 DVD Player
Broken belt - cyberhome ch-dvd 300
belt available at dalbani uk(nikkai import/export)they are on the web....
Dec 09, 2008 | Cyberhome CH-DVD 300 DVD Player
take the top of it off and then take the disk thing that holds the disk on the thing that spins it off and remove the disk.
Oct 27, 2008 | Cyberhome CH-DVD 300 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
105 people viewed this question
Top Cyberhome Televison & Video Experts
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
