Question about Dryers
When the start button is pushed the drum will roll for about 10 min. then when I try to restart it, it will not roll. Oh and I am lucky if it even starts the first time. Maytag ADE 308 But the
    Problem Solver:
  • 12 Answers
Check your berings on the drum or the seal and clean the motor with air compresosr, if you have bad bearings or seal replaced and also ccheck the blower wheel that nothing is stock in there. what happen that something is making the motor to get hot and overload .
Posted on Feb 16, 2010
    President:
  • 1,304 Answers
Hope this helps, you may have one or two issues here,
a. stuck or sticking idler pully, or it could be as bad, as your motor on its way out. over heating
Posted on Oct 06, 2009
Oh my rival microwave if I push a minute express cook and then push the power button and it says PL 10 what does that mean
Power Level 10, that's the highest power. You don't have to push the power level button every time you use it, just press the minute express button, then touch the start button
Feb 25, 2015 | Rival Microwave Ovens
My dryer tries to spin the drum when you push the start button but seems like it's having a hard time. If I spin it by hand it will start and run for about 5 to 10 minutes then shuts off and seems to
I would first check the belt, then check the belt tensioner, and finally the wheels the drum rolls on. You will find a worn belt, or worn or out of adjustment tensioner, or wheels that are worn at their axels. GOOD LUCK FRIEND.
Jan 16, 2015 | Whirlpool Dryers
No start or quits going down road then re starts after 10 mins no spark
a bad crank sensor will cause car to shut down, and restart in about 10 minutes.while driving down the road.
Mar 13, 2014 | 2004 Chevrolet Impala
My 1998 buick century 3.1 will not start. I changed starter , I changed the ignition switch , I even jumped the battery to starter with a push button , It now will turn or crank , but ,, it still will not...
THERE IS A CHIP IN THE KEY I BELIEVE. THERE IS A RELEARN PROCEDURE YOU CAN TRY IF WHEN YOU TRY AND START IT THE SECURITY LIGHT FLASHES. HOOK UP A BATTERY CHARGER. TURN THE KEY ON AND TRY AND START THE CAR AND RELEASE . DO NOT TURN KEY OFF LEAVE IT IN THE RUN POSITION. AFTER 10 MINS THE LIGHT WILL STOP FLASHING. TURN KEY OFF. TRY AND RESTART CAR AND AGAIN DO NOT TURN KEY OFF LEAVE IN THE RUN POSITION. LET SET 10 MINS AGAIN. LIGHT WILL STOP FLASHING AFTER THAT 10 MINS. DO IT AGAIN FOR THE 3RD TIME. SHUT KEY OFF LET SET 5 SECONDS AND START THE VEHICLE. HOPE THIS HELPS
Feb 22, 2013 | 1997 Buick Century
OKI c5650 flashing "K drum life" I buy new charge
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 08, 2011 | OKI C5650n LED Laser Printer
Well i have a Nvidia DeForce 9500GT graphic card and I have a big problem that I get it everytime I do something. It makes sort of squared on the monitor and they apear more and more till it is like 50%...
you need strong test you pc ram driv, and Vga drive, it may be from 3: 1.Ram drive, 2. Vga drive /9500gt/, and 3. operating system. And one way in first, reinstall your vga driver for your operating system, if system see it /vga/ automaticly, 100% install Vga driver from Vga driver disc.
Jun 03, 2011 | Nvidia GeForce 9500 GT, PCI Express Video...
My dryer keeps shutting off after about 10-15 mins. It starts make a noise likes it's slowing down just before it shuts off. If I try to push the knob back in to restart. It will make a buzzing noise. If I...
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Mar 13, 2011 | Dryers
Oki C6100 Laser Printer drum reset - from Fatal
8. Restart printer.
Feb 09, 2010 | OKI C6100n Laser Printer
Looking for manual of a chefmate bread machine
I have a manual for CM 725 if someone still needs it.
Sep 20, 2007 | Kitchen Appliances - Others
Dryers Logo
Top Dryers Experts
