Question about Brother MFC-290C Printer
Clean unable 46 - Brother MFC-290C Printer
  • cene765
    cene765 May 11, 2010
    Probably the waste ink tank is full.Try this procedure: Access the internal maintenance modeby pressing the Menu/Set button, then press * 2 8 6 4 within 2seconds. This should put you in the maintenance mode menu. Enter 80,then scroll down with the arrow down (round) key. You'll find anentry listed as purge count. If number is over 6000, enter 2 7 8 3. This will reset the purge count value. Then the printer willrestart, hopefully without the annoying cannot clean message.
  • Arcie Mar 17, 2012
    I tried it and it works.. thanks..... :)
  • Brother Master
  • 379 Answers
This is very common on Brother MFCs - they self clean excessively and when they've done a set number of self-cleans, they refuse to print and give the error message you quote.
There is a work around - you can reset the self-clean counter - but this carries a small risk the waste ink from cleaning that is normally stored insde the machine in a tank/sponge MAY leak out. I've done the work around on my Brother MFC and, so far, no leakage so if I were you I'd take a punt.
Just Google "brother mfc unable to clean" and somewhere in the results will be how to reset the counter - it's all done from the keyboard so no tools required.
Posted on Oct 06, 2009
Printer is flashing "Clean Unable 46- Refer to Troubleshooting & routine maintenance in user's guide" BROTHER DCP-135C
printer is flashing "CLEAN UNABLE REFER TO 46- TROUBLESHOOTING AND ROUTINE MAINTENANCE IN USER'S GUIDE..BROTHER 2480C
Feb 23, 2013 | Brother Multi-Function Center MFC-3360c...
DCP-165C Compact Colour Inkjet Multifunction Printer: in brother dcp 165 printer the error message clean...
brother dcp-165c printer unable to clean , see troubleshooting and routine maintenance chapter in User's guide
May 16, 2010 | Brother DCP 165C Compact Color Inkjet...
Unable to clean error 46
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Apr 14, 2010 | Brother MFC 6490CW InkJet Printer
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
- CHEERS!
 email me if I help you. . ryuuzaki182@gmail.com
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean Unable 46
Clean unable 46 means that the ink tank is full. You need a replacement tank installed and the count reset. This is a holder inside for the used ink,best to be a shop repair.
Jun 23, 2009 | Brother MFC 240C All-In-One InkJet Printer
Brother DCP 330C 'unable to clean 46' printer will not print
responded to this on a error 46 post by joachim.
hth,
razors
Mar 24, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to clean
plz search this forum for unable to clean or error 46
it has been explained so many times
Apr 27, 2008 | Brother MFC 240C All-In-One InkJet Printer
Clean unable 46 : what does it mean ?
...because you have run the cleaning cycles too much, the waist inktank is fed up! needs replacing. contact brother hotline or try to get one from a service partner which can be found on the brother homepage of your country.
Feb 09, 2008 | Brother DCP-340CW All-In-One InkJet...
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother MFC-290C Printer Logo
436 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
