Question about Sanyo PLC-XT16 Multimedia Projector
I want to show my DVD on a continuous loop at my art show from my computer which is the best projector?
  • 70 Answers
Sanyo plc-xt35 or xu105
Posted on Oct 08, 2009
Relaced bulb, but still flashes green goes to white screen and searches for source and continues to do this
Do you have a source plugged into the projector ? This means a computer, laptop, Ipad, or dvd player ?
Jan 28, 2016 | ViewSonic Pro8200 Projector
We do not understand how to project a DVD movie. Do we only hook up the projector or do we hook up the computer and projector?
Depends where the "source" is. If you want to show your pictures and videos that are on your computer. Or play a dvd from your pc, then yes you need to set up the computer
Nov 04, 2011 | Hamilton Electronics Hamilton Venu100...
Why does my epson emp 700 projector cut off after ten mins even when the fans are working
These models of projectors form Epson have a standby which the projector enters when it no longer senses video input. The fans will continue to run because they are cooling down the lamp which remains hot for a few minutes after it turns off.
This could be a problem with your computer, or dvd player, or whatever device you are using for your movies. Check to make sure these are working properly. Check to make sure that your dvd player or computer is still outputing video to the projector.
If this does not fix your problem, then the problem could lie with the projector itself. The projector fans may not be properly cooling the lamp, in which case the projector will turn off the lamp to ensure the projector is not damaged. To fix this, you could check if the fan outlets on the projector have become clogged with dust. If they have, definitely clean them out with compressed air.
Hope this helps.
Apr 12, 2011 | Epson EMP-740 Multimedia Projector
Well my epson projector fell and now the screen doesn't play it just shows the white screen but the audio works perfectly fine.
~ power on the unit and disconnect all sources (dvd,computer,etc) * if it shows "No Signal" and Blue screen, the unit is ok~ try using another cables
Jun 17, 2010 | Epson PowerLite® S4 LCD Projector
With the vpl cs 7 can two computers be run off the projector at the same time as the projector has two ports.
this manual will tell you if you can or not but with most projectors it will not show both the computers at once but you could have both pluged in and switch between computers,http://www.fixya.com/support/p201884-sony_vpl_cs7_multimedia_projector/manual-16017
Dec 14, 2009 | Sony VPL-CS7 Multimedia Projector
Dvd player to projector
Yes please.
You can connect it either thru the RCA Composite output(yellow) of your DVD or thru the S-Video or even thru the component out(YPbPR) connections. In the component out you would require three RCA cables and would give you the best possible picture.
Find a link below , which gives a review of the Viewsonic PJ 501.
http://reviews.cnet.com/home-theater-projectors/viewsonic-pj501/4505-7858_7-20722971.html
Hope this clarfies.
Please do rate this solution and thanks for using FixYa!
Mar 04, 2009 | ViewSonic PJ501 Multimedia Projector
Mitsubishi hc1500 banding
If you're using the VGA port, you'll see the banding because it's not really showing 720p, it's doing scaling (I'm not sure from what resolutions it's scaling). So, even though you're using VGA at 1280x720, the scaling is still going on and it's showing the banding.
You have to use HDMI to get true 720p.
Dec 09, 2007 | Mitsubishi ColorView XL30U Multimedia...
PowerPoint and Projector (InFocus LP640) Incompatability
I am unsure of this from your post, but don't try to hook the projector up to the laptop while either one of them is on. Power both the laptop and the projector off, hook up the projector to the laptop, then power on the projector first then the laptop. If you are already doing this, I apologize for stating the obvious.
Jul 03, 2007 | InFocus LP640 Projector Multimedia...
Problem with mitsubishi sl4u projector
make your pc or laptop start first and then the projector.
Mar 26, 2007 | Mitsubishi SL4SU ColorView Multimedia...
Sanyo PLC-XT16 Multimedia Projector Logo
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
