Question about GE (PSS26MSRSS) Side by Side Refrigerator
Gsh25vgpccc ge side by siderefrigerator
I have cold air in the freezer but the fridge is hot. I removed the damper and installed a new one because the old was always closed. Apparently that wasnt the problem because I open the flap and it closes again. I now have it propped open to keep fridge cool. what can I look for next?
  • beater Jan 03, 2008
    the only problem with the ice maker is thatr it doesnt stop makin ice. it will overflow with ice unless i turn the ice maker switch off.This u think may be a related problem?where could the thermostat be located?
  • 33 Answers
Well if you keep that damper open im sure everything in your refrig- will freeze is the temp- in the freezer o.k. if you have an ice maker is it working properly because if your freezer does not maintain the right temp your ice maker wont work. if so you might have a bad temp control (thermostat)
Posted on Jan 03, 2008
GE Monogram side by side built in model # ZISB48DYB. Freezer side ice cold but the refrigerator side is very warm/ hot no cold at all
Check to see if your fan is running, if its running your more than likely have a damper issue. check the damper on the top of the fridge and see if air is coming through. if not you need to replace or repair the damper.
Aug 05, 2013 | General Refrigerators
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Side by side GE turbo-cool Gss25XSRBSS, the freezer seems to be fine, the fridge is not cooling. Fans seem to be running smoothly, no weird noises. Turbo cool turns on. It hasn't been running for
if you go here you can see the damper,fan assy. that's in the top of your machine in the fresh food side
http://www.repairclinic.com/PartDetail/Damper/WR49X10091/1055112
this is a damper with another fan in it,when the t-stat calls for cold air the damper door opens to let the cold air in from the freezer and the fan in it blows the cold air around inside the fridge,if the freezer is fine and the fridge side is warm most likely this is your problem,part number WR49X10091 and it's around 130 dollars.unplug the machine,remove the light cover on the ceiling,remove the 1/4 inch screws and drop the light assy.remove thhe filter cover on the right side so you can remove the damper assy.pop off the cover on the piece that runs up the back center,remove the screws to the damper,read the instructions and put it back together again.should take you around 45 to 60 minutes.hope this helps and good luck.
Sep 27, 2012 | GE Refrigerators
My GE model GSH25JFTCBB side by side is not cooling in the fridge side. Freezer seems to be doing fine. What could be wrong
you could have a defrost problem,a bad damper,bad computer board.first thing,open the freezer door,do you hear the fan blowing in there?you should,if not the evap fan motor is bad,if it's blowing touch the back inside wall of the freezer to see if any frost or like snow is on it,from the bottom up in the freezer remove the second bin of food and touch the back inside wall with your hand,if it has frost or snow you have a defrost problem,bad defrost thermostat,heater,sensor or board,if there isn't anything on the wall then you have a bad damper,all that happens is the evaporator coil in the freezer gets cold,then the evaporator fan in the freezer blows the cold air over into the fridge section,you have a damper in your machine that opens and closes when it's cold enough or when it needs to get colder,the door on the damper isn't opening to let the cold air in when it calls for cold air.if you can write back and let me know what you find and hopefully we can get it fixed.
Sep 15, 2012 | GE Refrigerators
My freezer is working but not at top notch capacity. The refrigerator is definitely not working properly as the spring water, for example, is not chilled. What must I do to resolve this...
Hi Alexandra. Hey New York? Brrrrr.
The thermostat actually controls the freezer side. The fridge side is controlled with cold air blown from the freezer side. The controls in the top of the fridge box contain the thermostat/switch, and the damper adjustment for the cold airflow from the freezer to the fridge side. Your problem is a blockage of the cold airflow from the freezer to the fridge side.
1. Frost blockage of the passage
2. Fan stoppage on the freezer side
3. stuck or broken damper
Some dampers are just simple movable plastic doors, some are servo/solenoid/motor operated.
Look up your fridge on Sears Parts, and the exploded diagram will help where to find the passage and how it can be blocked.
Jan 08, 2011 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
I have a GE GSS25LGMF side x side refrigerator. The compressor never shuts off and everything in the fridge section is freezing. Is this a thermostat problem?
it could be the damper part number WR49X10091,if the damper door isn't closing correctly cold air will just keep coming into the fridge side from the freezer,usually the damper door opens to let the cold air in when the fridge starts warming up and when it gets cold enough the door will close but your damper is stuck open
Nov 25, 2009 | GE GSS25LGM Side by Side Refrigerator
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Refrigerator approx. 8 years old. Fridge side barely cold.
With your fridge, does the light go out when you shut the refrigerator door?
That could be your issue, that light running inside will create Alot of heat.
Also check to see if there is air circulating from the freezer to the fridge side through the damper. The damper is on the Fridge side left wall up towards the top. That is where the cold air gets to the fridge side. If that damper doesn't open that will also cause your problem, Let me know how you make out.
Bill
May 14, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
193 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
