Question about Pioneer GM-X324 Car Audio Amplifier
How do I connect it?
I just bought a 2000 Mazda Millennia S. In the trunk, disconnected, is one these. The wires are all there taped together in a nice bundle. How do I connect this thing up?
  • 733 Answers
You need to figure out where the wires go and to what type power they are connected. if you look in the back of the stereo where the wires are(the ones from the radio harness), these are the main ones(yellow=12v constant) this one keeps memory for your radio. This one shouldn't be used to connect to your amp. Find out if the amp had a dedicated power wire directly from the (+)battery to the +12v connection on the amp. The other is the remote wire(it's always blue in color from the radio harness). it goes on the remote connection on the amp, when the radio turns on, so does the amp and when radio is off the amp is off. The last is the ground(black)wire. Connect this one to the car chassis(any bolt on the car, i usually use the seat bolt. Now the rest of the wires are for sound. The rca's go from the "output" of the radio to the amp's "input". What's left is connecting the speakers, that's the easy part, just make sure you trace all your wires and if you have to pull the stereo out of the dashboard to verify the connections...do it. This will save ensure that the job is done not only right, but safely. get a probe light tester from autozone or any parts store to check your voltages before you connect the wires. Better safe than sorry. Seems like a lot but it's really not. good luck.
Posted on Oct 06, 2009
I need electrical wiring diagram for 2002 Mazda millennia
Google 2002 Mazda Millenia wiring diagram
when it puts up the list go across the top of the page and click images.
You will see the one for your car
click on one and then click visit site and there you have it.
Hope this helps Mike
Mar 09, 2016 | Mazda Cars & Trucks
Whats the problem with tcs sensor on a 2000 mazda millennia s 2.3 engine.
I would first check for loose wheel bearings, or loose or frayed abs wire connections or even a cracked toner ring. These can all trigger this light.
Aug 30, 2015 | Mazda Cars & Trucks
Does a 2000 mazda millennia have a fuel shut off valve
Just because you hear the fuel pump does t mean it's good.....
Jan 11, 2015 | 2000 Mazda Millenia
Alarm system wont let start car
**Disclaimer**
I do not know how mechanically/electrically inclined you are. Take my advice "with a grain of salt."
Just stick your head under the dashboard and unplug the aftermarket alarm, if it has one it should be obviously stuffed in there. After that you just need to find the "starter cut relay." Usually it is taped, or "zip tied", up under the dash connected to the ignition switch harness. Once you find that, connect the 2 "big" wires together. On a standard "Bosch Style Relay" they will be terminal 87 and 30. The bottom of the aftermarket relay should be marked. From the wiring diagram, the starter signal wire is light blue with a yellow stripe at the ignition switch harness, all the way to the transmission, and black with a yellow stripe at the starter
The car should start fine when you are finished. without lights and horns going off randomly.
Jan 11, 2014 | Mazda MPV Cars & Trucks
Why are my suzuki wagon r lights main beam 2000 not working?
The Wagon R does not have a relay for the headlights! In MOST cases the problem is due to Suzuki's wiring, They simply twisted the wires together and taped them over in the harness!
Follow the cable trunking down the N\S inner wing and cut into the trunking (carefully) and work your way down to the bulk head, and inside you will find little blue twists of insulating tape! Find the one that is on the red/white wire and that will most likely be the cause of the problem!
Remove the tape and cut away the oxidised wire until you get good copper core! Tin the ends with solder, then either solder the ends together OR fit a double to single bullet connector to create your connection. Re insulate then rewind the whole harness where you cut in.
Hope this helps!
Apr 30, 2012 | Suzuki Cars & Trucks
Trunk lid warning sign won't go off even though trunk lid is closed for 2007 Hyundai Sonata
check the deck lid latch to ensure the wire harness did not get pulled off somehow... That would be the only thing I can think could cause the boot ajar light to stay on.
Sep 28, 2010 | 2008 Hyundai Elantra
1990 BMW 525i tail light + light
check for a loose wire connection on the side indicated you may also remove bulbs and clean light sockets
Aug 14, 2009 | 1997 BMW 328
Trying to remove the trunk; can't disconnect the wiring attached
There should be quick disconnects behind the drivers side trunk trim in the wheel well location, or they are attached to the rear deck (by the speakers)
If all else fails, cut them, and re-splice with crimp-on ****-connectors when you put it back together.
Jan 06, 2009 | 2001 Lexus ES 300
Stat
always disconnect from mains when you do that sort of thing.
disconnect from mains, short the two wires together - just tape them together - and see if cooling starts
Sep 06, 2008 | U-Line 75BWC
Pioneer GM-X324 Car Audio Amplifier Logo
150 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
