Keyboard lock out problem - Office Equipment & Supplies
How do I unlock the keyboard
Wired keyboard usually do not have locks, However some wireless keyboard do. A switch is usually on the top side of the keyboard that slides back and forth.
However you may also be seeing "Caps Lock" which means the Caps lock key is engaged. Simply press the "Caps Lock" key again to unlock it. The caps lock key is located at the left side of the keyboard.
Dec 12, 2014 | Microsoft Wired Keyboard 600
Where is the Scroll lock on the keyboard of lenovo laptop?
To Turn on/off Scroll Lock do one of the following: Press the Scroll Lock (sometimes appears as ScrLk) key on your keyboard. If your keyboard does not have a Scroll Lock key, on your computer, go to Start, All Programs, Accessories, Ease of Access, and then click On-Screen Keyboard.
Jul 14, 2014 | Compaq Keyboard
How do I unlock the keyboard of IBM Selectric III???
The Selectric typewriter has several "interlocks" that can cause the keyboard to be locked. When you turn the machine off there is a mechanism that locks the keyboard. When you turn it on the part should move and unlock the keyboard. Sometimes this part sticks and the keyboard will remain locked. When you type any character the keyboard is locked to prevent two keys trying to type at the same time. The machine locks and unlocks very fast. One keys is locked in and prevents others from working. try turning on the machine and hitting every key just a little bit harder and see if it then types. When you shift, as the ball is turning the keyboard is locked temporarily so it won't attempt to type as the ball is turning as that would damage the machine. Sometimes the shift mechanism can cause the keyboard to remain licked as the shift may not have finished it's complete cycle. Also, the return mechanism locks the keyboard temporarily when the carrier is returning to prevent you from typing when the carrier is moving backwards. Only a qualified technician can resolve those issues.
May 08, 2014 | IBM Correcting Selectric III Electric...
Dell keyboard locked up
Dear Sir,
PLzz folow this step to unlock your keyboard
Step 1 Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
    For desktops, disconnect the keyboard from the desktop. Reconnect after one or two minutes.
  • Step 5 Reconnect the power adapter or AC cord. Start your computer.
  • Step 6 If your keyboard is still locked on a Dell desktop, disconnect the keyboard. Restart your computer and reconnect the keyboard after the system boots. Allow your operating system to recognize and reinstall the keyboard
  • Thanks For Your Time.
    Apr 10, 2010 | Dell 0Y3740 Keyboard
    Down arrow in lock symbol on keyboard. what is
    That would be the Scroll Lock. Do you have a Scroll Lock key? Press it.
    Thanks for using Fixya.
    Oct 05, 2009 | Dell 0Y3740 Keyboard
    My dell bluetooth keyboard is locked i hve re
    check yor drivers. dell website has free downloads.
    Jul 23, 2009 | Dell 0Y3740 Keyboard
    Keyboard is locked, looks like in safe mode.
    Compaq laptop keyboard is locked, looks like in safe mode. How can I get the keyboard to work???
    Jul 02, 2009 | Compaq Easy Access Internet Keyboard
    Keyboard
    I believe it's the num lock that is causing that locked 9 to illuminate on your keyboard
    Oct 06, 2008 | Dell R6053 Keyboard/Multimedia Control...
    Cannot unlock Keyboard Scroll lock - EX110
    Found this little bomb shell after about 30mins of looking for an answer.
    http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=9220
    To toggle your scroll lock key:
    1. Click on the Windows Start button.
    2. Select Run.
    3. Type 'OSK' in the dialog box.
    4. Click on OK.
    5. The Microsoft on-screen keyboard will open. Notice that the slk, or scroll lock, key (located in the top row of the on-screen keyboard as shown below) is turned on.
    6. Click on slk (in the top row of the on-screen keyboard). This will toggle the state of the scroll lock key. Notice that the scroll lock key is no longer outlined in red. Scroll lock is now off.
    NOTE: If you have installed SetPoint (Logitech’s Mouse and Keyboard software) the confirmation message Scroll Lock Off will also be displayed for about 2 seconds on your monitor.
    Yipee!!!
    Aug 21, 2008 | Logitech Cordless Desktop EX110
    F keys don't work on a micrpsoft keyboard 1000 wireless
    Many of the wireless keyboards and Natural Keyboards from Microsoft have the F-Lock key.
    Here is a description of what the F-Lock does from a 3rd party website (http://www.mvps.org/jtsang/flock.html)
    F Lock Key
    The F Lock key on the Microsoft Keyboards is a relatively new concept facility for Microsoft Keyboards. Introduced with the Office Keyboard and used in later keyboards, it essentially allows keys to do more than one operation. The F Lock key, depending on its state, will allow either a function key's "normal" operation or a new "enhanced" operation. The initial state of the F Lock key is "off", and in this state, the function keys use their "enhanced" operation.
    The F Lock key is a hardware switch in the keyboard. Its state cannot be controlled programatically. Its default condition is "off". As a result, whenever the keyboard is reset, or loses power, the F Lock key will always be in an "off" state.
    For some, this is not a desirable default; some people want "normal" function key operation.
    Jun 15, 2008 | Computers & Internet
    k24674
    jasbo
    jasbo
