Question about HP Pavilion dv6000z Notebook
Tha laptop just beeps when switched on. power ok, nothing on monitor - beeps 4 times then that is it!!!
  • Anonymous Mar 24, 2014
    the laptop adaptor its ok but the laptop no power
  • 736 Answers
4 short beeps might mean you have a bad memory module (beeps are coded) .. if you have two memories installed you can try takeing one out at a time .. it will start working when the good module is the only one plugged in .. just removing and replacing the memory sometimes cleans the pins so that it works again .. ... there are other possibilities that are more expensive usually ... so you hope its just the memory .. here is a site that gives beep codes for many machines ..
http://kb.iu.edu/data/afzy.html
Posted on Oct 06, 2009
  • Helder
    Helder Jul 18, 2014
    Hi, my HP DV5215us had the same problem, I took one out at a time and the machine started up normally. Now I need to discover if the memory slot is dead or only dirty. Thanks a lot for your clue.
    President:
  • 1,185 Answers
Motherboard, Hard Drive or Ram failure.
    Problem Solver:
  • 14 Answers
The battery must be dead it is an very technical problem contact a computer specailest it cant be done by yourself
HP 2000-410US when turned on the power light button blinks 1 time every 5 seconds, nothing elas
1. Disconnect anything that is connected to your laptop. Usb Flash discs, External HDDs, Wireless Devices using dongles etc.
2. Make sure that your device does not receive any power i.e. Disconnect your ac cable, and remove battery from your laptop.
3. Hold down the power button for 5 seconds. This would drain remaining power from your laptop. But as the power cable and the battery are disconnected, you should not expect anything to happen.
4. Identify where your RAM is located under your laptop. Unscrew the cover off, then remove the RAM from your laptop. Replace the cover temporarily.
5. Flip over your laptop. Connect your power cable to the laptop, NOT THE BATTERY NEH! Then press the power button. Sometimes your laptop will make long beeps to let you know the RAM is not inserted in your laptop. But nothing will happen on your monitor because it needs RAM to show you something.
6. After those beeps, remove the power cable. Press the Power Button to drain remaining power on your laptop. Flip the Laptop and replace the RAM you have removed earlier.
7. Insert your power cable and try restarting your laptop and see what happens. I am sure by now you should have some response on your laptop monitor.
NB: While performing the above mentioned, remember PC or Laptop parts are delicate. Even static electricity can damage them. Thus before handling your laptop components, make sure you touch the wall or any large metal subject from time to time to discharge the static. Wear 100% cotton cloths as you are working on it. Bare feet even better to discharge the static
Jun 14, 2014 | Gateway MX8711 Notebook
4 Beeps on my Acer X1935 and then nothing, no display
maybe you check on Rams, sometimes BIOS battery
Nov 11, 2012 | Acer Computers & Internet
Laptop does not start!!!! Hi, I have a problem that maybe you can help me with. I have a HP Pavilion tx-2510us, I turned it off and now it just refusses to start. I tried several different ways of...
yes, we have like 1000000000 posts here, LT does not start.
endless it is.... and few come backs, to show whats up.
its always the same reasons, short list.
Ok, not on time did you say the word BIOS>
did you know BIOS works with HDD/SSD removed
forget the OS for now,
if the BIOS ok called up the screen is ok
if not, then its a catastrophic failure.
you can even boot it with external, screens, 15pin pin VGA.
if not its DEAD if BIOS IS DEAD, that is a clear 100% dead
with battery out.,
so the power pack is bad.
ever consider that, i keep them as spares, so if on say vacation
mine blows out, i have a backup.
with a good power pack
the MOBO will work
and will beep if you remove RAM.
with special beeps, beeps are BIOS code running,...
if it cant beep the MOBO is toasted.
I uses a voltmeter on the rear of the power jack
19vdc is spec (the pack side tells you that in clear text)
ok its got power. (even with power button pushed)
ok power good, push power botton
and i must get beeps BIOS
one or the other, even with
here are the LED flash codes on my hp 8540.
hp.com has yours too, if you RTM ,read the service manual. for free
nice how fixya wrecks photos. sad
the blinks mean,
gpu dead
bios dead
cpu dead
ram dead
and more, this laptop dont beep it only blinks
so you must read the book to learn what YOURS does.
Mar 13, 2017 | HP Pavilion TX2510US Notebook
The screen of my Vaio flickers when the charger is plugged in and the computer is switched on. If the computers switched off it charges ok and the screen is good when the charger not plugged in.
TRY SWITCHING OFF YOUR COMPUTER MONITOR( REMOVE THE POWERCODE). IS THE PRON SOLVER. IF YES PROB WITH MONITOR POWER SECTION. IF NO REMOVE POWER OF COMPUTER CPU. AND ON THA UPS . IF IT IS STILL FLICKRING PROBE WITH UPS. ELSE RE[PLACE SMPS OF COMPUTER
Feb 07, 2011 | Sony VAIO VGN-CR420E/T Laptop
Toshiba a205 s5000 laptop, power is ok, disk is ok, NOTHING on display at power on, no BIOS, nothing. Doesn't appear to be booting as the disk access light goes out almost immediately. Tried connecting...
Hi, I am Steve, lets get you some help
The computer is failing the power on self test (POST)
If the machine is beeping it can give us a better clue as to what is wrong - if it is can you let me know the no of beeps, but also try this:
  • remove the power and the battery, hold the power button for 60 seconds. try to power it back on.
If this is not successful and you are not getting any beeps it is almost certainly the motherboard - something has gone bang. This is usually the end of the life for the laptop.
you could try a service that replaces motherboard components - in the UK they charge £75 plus parts.
Jan 17, 2011 | Toshiba Computers & Internet
Power stable however no display, the lock keys flick and the bluetooth symbol always on.
no display after switching on the laptop?
1. try to connect to an external monitor using an analog video cable. monitor is on. turn on laptop after a minute press and hold on Fn key then press F8 at the same time to toggle the display between LCD to Monitor, if nothing happened do step 2.
2. turn of laptop. remove video cable. press and hold D key then press power button at the same time. this will test the LCD. check if there are colors display. if yes do step 3, if no replace lcd and lcd cable.
3. make sure laptop is off. press and hold on the Fn key then press power button at the same time to run a quick test. Even no display or anything wait for about 5 minutes check if you will hear series of beeps. If yes.replace video card if it is expansion, replace motherboard if it is integrated.
Sep 24, 2009 | Dell Vostro 1510 Laptop
Dell XPS 700 Black Screen, No Bios, Post error 1 2 3.
could be the cpu, its prolly the only thing you havent tested. or the power supply.
Mar 11, 2009 | Dell Computers & Internet
Ps3 light on but freezes
Hey ok wait a sec so nothing is displayed on the screen?
Does it power off or down?
Ok it sounds like a simple setting error..
Turn system off then on and let the red light show up.
Then push the power button down for 5 sec and/or wait until it beeps.. it will reset itself and turn back on.. still nothing? do it up to 10 times and let me know if this is not the issue thanks!!
Jun 27, 2008 | Sony Playstation 3 (PS3) Console
Dimension 4500S
hi!,
I hav a solution 4 u . Ur LCD monitor's wires of ur Laptop Has gone loose , U can just give ur lappy 4 a servicing.
byeee........
Mar 08, 2008 | Computers & Internet
Emachine t5026, 3 beeps
try a cheep video card from your local used computer parts store they're every where, you'll ask for a pci video card.
Mar 28, 2007 | E-Machines Emachine T5026 power supply **...
HP Pavilion dv6000z Notebook Logo
321 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
