Question about Air Tools & Compressors
Air compressor not building air pressure above 125psi
  • lbb1200 Oct 06, 2009
    compressor keeps running it is set at 150psi and does not build above 125psi if i adjust the regulator down it turns on an off as it should with it turned up it runs and does not stop running not building enough pressure to turn the regulator off
    President:
  • 1,167 Answers
Is it stopping at 125psi bud
Posted on Oct 06, 2009
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
I have a cap2060 Bostitch pancake. When pressure builds to 125psi the pressure switch blows open and starts to release air. I replaced the switch and the same thing is happening. Is there a way to adjust...
A little suggestion as most compressors are build up similar in the same way if your Pressure relief valve (unloader valve) will start continues blow off until all pressure is lost , it has nothing to do with the pressostat switch in most case there is a problem with the checkvalve on the tank sometimes there are metal little oxidized parts coming out from the cilinder like the pressure hose connections Oxidized couplings or membrane you can open and inspect the spring and rubber valve iside the checkvalve clean it from corrosion and metal parts.
AB 9048053 Check Valve
Dec 06, 2013 | Stanley NEW Bostitch 2 HP 6 Gallon...
Load and unload issues
  • The 10 deg pressure band you are asking for is too narrow for the pressure switch. You are going to have to choose to have it kick off at a higher pressure or turn on at a lower pressure.
  • You could install a more precise pressure switch.
  • What are you doing that you set a 10 deg pressure band ?
Nov 12, 2013 | Air Tools & Compressors
My husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
May 27, 2010 | Air Tools & Compressors
Dewalt compressor builds pressure then pops off at max, never stops running
would best guess that the pressure switch is stuck shut. if the pressure is going over 125psi, "and check with a good gauge" then the switch needs to be replaced.
Nov 30, 2009 | Dewalt Air Tools & Compressors
Craftman 3gal/1hp air compressor runs normal, but
Chek for pressure BEFORE REGULATOR,if the problem remains worn rings or valve seats most likely source of trouble.
Aug 09, 2009 | Air Tools & Compressors
Husky 17gal 5hp compressor will not cut off when it builds up pressure. Pressure valve will pop open and then I cut it off buy hand
bad pressure switch or it is wired incorrectly replace switch and check the wiring or could be out of adjustment you compressor is made for max 125psi should be a screw to adjust on the pressure switch near where the wires are connected back out counter clockwise to lower and see if that turns it off
Feb 20, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Gas air compressor shuts down
IS IT BUILDING TO THE UNLOAD PRESSURE AND THEN STALLING OR JUST SHUTTING DOWN ANYTIME. IS THE UNIT SITTING AT AN ANGLE?
DOES IT WORK FINE WITH THE LOW OIL SWITCH UNPLUGGED? UNPLUG SWITCH AND LEAVE IT UNPLUGGED FOREVER.THEY'RE ALL P.O.S.
Feb 14, 2009 | Hitachi EC2510E 5.5hp Gas Air Compressor
Air Tools & Compressors Logo
97 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
