Question about Car Audio & Video
My c15 citreon van keeps blowing 10amp fuses for side lights etc since fitting a new radio, i have taken the radio back out but it is still doing it, can someone please help? It seems it is ok when vehicle is static, but when it has been driven for 30 seconds to 1 minute the fuse then blows again. i have been told by a fitter at local cireon garage to connect power antenna cable to negative ground cable, but it still blew once i had started driving .
  • 35 Answers
Please check your total circuit related or connected with 10Amp. fuse, anyhow i think it is semi short circuited. u have to find out where the short circuit occurred. to find out the problem u can start checking from side light holder...........
thanks
Posted on Oct 06, 2009
Ive had the pump overhauled by professionals,fitted pump onto van,timed all correct and theres no fuel getting to injectors,also keeps blowing 10amp fuse on glowplugs
Did you prime the system ? Fill the fuel filters with fuel ! For the glow plugs find a wiring diagram an do a voltage drop test on the circuit ! May have a shorted glow plug or the control module. You can find videos on you tube on testing ,probably .
Nov 15, 2015 | Cars & Trucks
Citroen c15 van i have fitted a radio only when you turn the side lights on it blows the fuse
Does the radio work if the dash lights are off?
I'm wondering if the power and lamp wires are reversed in the 3 wire connector that plugs into the side of the radio.
satellite radio receiver
Aug 24, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver with...
Where is the fuse for cig lighter, radio & interior lights on a c15 w reg van
Find a car lot with your van and ask to look inside. Use that vans fuse lid.
Sep 01, 2010 | Car Audio & Video
Hi there, I have bought a replacement brake light bulb for a Citroen C15 van, but I cannot see how to gain access to fit it? Many thanks Steven Chandler
The taillights on most vans are accessed from the storage compartments in the back of the van on each side. You open the cover, and sometimes you have to remove a liner, depending on the vehicle, and you can then access the back of the taillight.
Oct 21, 2009 | 2006 Fiat 124
Starter fuse under the hood keeps blowing....the factory deck was replaced by a new deck...every since then the ignition fuse keeps blowing..
the new radio install is causing this if the power was taped into the starter system. rec. removing wires then try to see if you can blow your starter fuse
Jun 01, 2009 | Car Audio & Video
Gearbox
its not hard, same as usual car, o/s drive shaft, u have to undo the 2 11mm bolts on engine mount, with a large chisel and hammer hit the shaft, there is a steel collar around the shaft, hit it there hard to push it out of the engine mount.
Apr 26, 2009 | 2006 Peugeot 505
Got a new Kenwood KDC-128 car radio recently, fitted it but the radio presets would not stay when the ignition was turned off. Then it stopped working altogether and I noticed the 10amp fuse at the back...
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Jan 02, 2009 | Kenwood KDC-128 CD Player
99 Camry it keeps blowing 10amp fuse
I agree with lobsterman...Aftermarket radios kill the gauge fuses.
Aug 24, 2008 | 1999 Toyota Camry
Car Audio & Video Logo
48 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
