Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Will not release ice and makes crushed ice, even when on cubed.
My GE side by side creates a big block of ice where the ice drawer and dispenser chute meet. Eventually the block of ice gets so big that it scrapes whenever the door is opened or closed. Water works fine, but no ice gets through the flapper. Instead it will just build up in the dispenser and then overflow.
  • russell233 May 11, 2010
    Problem was identified by Seabreeze on this post.Thank you very much for your time and help. He is a true professional !! The problem I had was the solenoid which opens and closes the ice chute. It was very corroded and therefore could not function as designed, which wouldn't allow the chute door to close fully and allowed warm air into the freezer, causing an ice dam to form. I removed the front panel from my fridge, exposing the solenoid. It has a metal pin coming out of the top, which pulls down on a plastic lever, opening the chute door. I removed the solenoids 3 mounting screws and took out the solenoid. I found the pin to be corroded and sticking inside the solenoid. I removed the pin and cleaned it up with a wire wheel on my bench grinder. I applied a small amount of never-seez to the pin and reinstalled everything.Works like new again!!!
  • John Tripp
    John Tripp May 11, 2010
    Ok I am trying to understand this correctly. The ice maker continues to make ice even when it it supposed to stop. Or the water is leaking into the ice maker while the ice maker is in the process of making a batch of ice? If this is happening while the ice maker is in between cycles that is either a leaking water control valve for the side of the solenoid that controls the water flow to the ice maker. Or the defrost element under the ice maker is stuck on and telling the thermostat that the water should refill the ice maker. Now, check that theory and correct me if I misunderstand. I will be back as soon as I look over the diagram for your model. Sea Breeze
  • GE Master
  • 4,655 Answers
I believe in your case the ice maker part number WR30X10093 being electronic with the control board in the front is the problem. I think the control board behind the front cover of the ice maker may have corrosion and causing the ice maker to malfunction. You can try disconnecting the set of wires to the coil on the water control valve and see if the water stops or turn off the ice maker first and try disconnecting the coil wires later. It has to be the control board or the water control valve part number WR57X10032
Posted on Oct 06, 2009
Testimonial: "Seabreeze was very professional and knowledgable. Fixed my problem very quickly. I should have come here sooner.Thanks again."
  • 5 more comments
  • John Tripp
    John Tripp Oct 06, 2009
    Here is a photo of the ice maker part number WR30X10093
    And the water control valve part number WR57X10032
    If you have more questions or need help feel free to let me know, You can find parts and answers at the links below, Thanks, Sea Breeze
    appliancepartsse@yahoo.com
    SEA BREEZE TIP'S
    Sea Breeze Parts and Technical Services
    http://servicepartstec.blogspot.com/
    http://appliancepartsse.blogspot.com
    Click here=> PROFILE ARTICA REPAIR MANUAL
  • John Tripp
    John Tripp Oct 07, 2009
    Does your Ice door open when the dispenser button is pressed?Can you clean it out and manually hold the door light switch closed while pressing the dispenser button and see the flap open. The solenoid may be stuck shut letting the ice build up and open just enough for warm air to be pulled in and freeze the ice solid before the door can open and drop the ice. Sea Breeze
  • John Tripp
    There is a solenoid in the rear near the auger motor that when the control is switched to cubes or crushed moves a lever that changes the auger blades to crushed or cubes. I have totally missed your point all along and my apologies. Can you remove the auger pan and press the door switch in at the same time you press the dispense button and switch to cubes the solenoid should shift a lever to chang th auger blades to crush or cubed ice. The only way to check this is while holding the door light switch in as if the door is closed. and change the crushed to cubes and watch to see if the lever is moving.
  • John Tripp
    I need you to test the power to part number WR62X58 Solenoid Assembly number 378 in the photo below.
    If while doing the door switch test this solenoid does not move the lever that may be the problem. Let me know if I am on the right track now with this problem. Thanks for not giving me a not helpful because I did misunderstand your explanation, Sea Breeze
  • John Tripp
    Here is a photo of the part number WR62X58 Solenoid Assembly
    Email me or call I would like to get this solved, Sea Breeze
    864-812-1887
    email appliancepartsse@yahoo.com
  • John Tripp
    There is also a solenoid for the chute door that may be bad or broken number 36 in photo.
    Photo of the dispenser door solenoid prat number WR62X10055
    Ok I will post no more because I made the mistake in the beginning, hope to hear from you, Sea Breeze
  • John Tripp
    Russell233,
    Thank You For The Great Rate And Those Words Of Respect. Russell you also have been Very Helpful so welcome to the team! Fixya needs good people like you too! I also want to thank Fixya and all of their Sponsors that provide the free help here! If anyone ask who the Sponsors are just look at all the great companies listed on every page. Again Thanks, Sea Breeze
    Scholar:
  • 103 Answers
You have a ice chute door that is not closing all the way. Quick way for a "non-tech" to check chute, open door to freezer, clean all ice build up out of chute, stuff it full of paper toweles, make sure no air can get around the paper towels. close door, then chek same area in about three to four days, if ice buildup is gone then you need an ice chute door repair kit. Common problem, nothing major.
If you still have the same amount of ice to the point that paper towels have ice around them then you may have a leaky door. Another subject all together.
Need full model and serial number to advise right part numbers.
Posted on Oct 10, 2009
Ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Aug 26, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice cube stuck on crush
remove the ice bin,there must be a chunk of ice blocking the cubed dispenser chute of the dispenser and channeling all ice thru the chopper chute,run hot water thru it to melt any chunks blocking the cube chute,then dry it and let it get cold before filling with new ice or you will have the same issue again
Aug 12, 2012 | Frigidaire Refrigerators
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Our GE Monogram Icemaker will only dispense crushed ice
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Monogram refrigerator icemaker problem
This is normal if you have previously used the crushed ice mode. The refrigerator will continue to dispense crushed ice for some time until the reserves are depleted. If this continues for a longer period then shut down the refrigerator and remove the dispenser compartment, clean any remaining ice and reinstall it. Start the power supply and wait 5 hours for the ice to form. Use the cube mode and you will surely obtain ice cubes.
Aug 27, 2009 | GE Monogram ZISS480DRSS Stainless Steel
25 ft side by side fridge which does not dispense ice
use a hair blow dryer to warm up the chute and dry up any moisture then lube the chute with a cooking spray, pam is a good one.
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Nov 06, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice dispenser not working - GE side by side refrigerator
Check auger motor if getting power then probably motor gone , if
not may be switch. good luck
Nov 09, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
719 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
