Question about LG Flatron Ez T910BU 19" CRT Monitor
It looks very dark
Ispite of the brightness up to 100% and contrast also at 100% preset is 6500K. still it is very dark, any help to make it more bright would be appreciated even though temperature increases up to max. thanks
  • LG Master
  • 32,281 Answers
The fault could be a faulty inverter board or a faulty CCFD lamp.
The inverter supplies high voltage to the CCFL lamp. The CCFL lamp is a mini fluro lamp and can dim with age.
Check LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Posted on Oct 06, 2009
MY MONITER DELL E771A MONITER SCREEN IS VERY DARK I ALKREADY SAVE 100% BRIGHTNESS HOW TO SOLVE THIS PROBLEM
That's an old fashioned CRT. I'd increase contrast at well since it affects how bright the tones get and see if it helps. It should never be dark. It's may be dying.
Jan 10, 2012 | Dell Computers & Internet
I am using a Viewsonic VX2235WM monitor for photo editing
Hi!
Its actually normal. That normally happens to some monitor models at the 6500K setting. Try a higher one.
I hope this helps.
Jubert
May 18, 2010 | ViewSonic VX2235wm LCD Monitor
Lg 563n 15"crt monitor
brightness 60 , contrass 68, color 6500K
Mar 16, 2010 | Computers & Internet
The color is too dark how do i feel the color i already put the color contrast and brightness to the maximum which is 100 but its still not bright enough what else can i do. do i need a new monitor
open the monitor you will see the eht a biggest black part on pcb take the screwdriver and rotate the preset on that eht on which screen is written .do it in active monitor and look on the screen and finish after satisfaction
Mar 04, 2010 | E-Machines eMachines Monitor E15T4
VA721/Windows 2000 - contrast/brightness settings grayed out
The monitor is probably set to sRGB under "color adjust".
Change it to 6500K, which is default, and you should be able to adjust brightness and contrast.
Jan 01, 2009 | ViewSonic VA721 17" LCD Monitor
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
LG Flatron E700SH
Hi its not problem it is just setting difference
Try this one
go to menu setting and increase TEMPERATURE to 8300 or between 8300 to 9300
this will help you to solve your problem
thanks and regards
Teknas
Aug 17, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
Oct 15, 2007 | Toshiba 32AF43 32" TV
Monitor Coloring
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more). How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page). If you don't have the manual you can download the full manual from LG's download site here: http://www.lge.com/support/manual. If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you. Hope this was helpful.
Apr 26, 2007 | LG Studioworks EZ-FLAT E700B 17 in.CRT...
LG Flatron Ez T910BU 19" CRT Monitor Logo
134 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
