Roper washing machine walks across the floor on final spin.
    President:
  • 1,304 Answers
Hopefully you just have a bad leg lock going on
put the machine where ou want it
make sure your rubber feet are on the legs
now tilt the machine twords you about 3 inches high, back legs off the ground
DROP IT
that should force your legs to lock and rebalance the machine
make sure its level and you should be ready to go
Posted on Oct 06, 2009
Roper wwshing machine model rtw4640yq1 during spin cycle bounces across the floor
Sounds like your load of clothes are not balanced. Like more on one side than the other.
Oct 17, 2016 | Roper Washing Machines
Maytag washing machine walks across floor during spin cycle
Did you set the back feet before leveling? On most units to set and lock the back feet you need to pull the top towards you so that the back is raised off the floor, then set it down again, this will release the feet and lock then down. The you level the two front feet. After this is done you must make sure your load is balanced. Distribute the items as evenly as you can in the tub. Once it gets to the spin cycle if its walking or shaking a lot, stop it and redistribute the items more evenly in the tub. Also try not to overload the unit or combining many heavy items with few light ones. If this is a new machine, did you remove the shipping locks from the back before using it? They have plastic strips attached to them, make sure they have all been removed, as well as any shipping bolts.
Feb 17, 2015 | Maytag Neptune MAH6700A Front Load Washer
Machine shakes, rattles and "walks"
Possible that the drum is out of alignment, You will need to check the motor mountings, check to see if the suspension of the drum is good. if not remove and reset, check the counter weights and the shock absorbers.
Also check the drive shaft and the agitator assembly. finally the footings to be firm, use a water level to set.
May 16, 2011 | LG Washing Machines
Washer walks across floor on spin cycle and my level says its level
If the level is registering the machine as level, then you probably have an unbalanced load that is causing it to "walk." When it starts walking, lift the lid, wait until the spinning stops and redistribute the articles in the basket. I hope this helps. If you're satisfied with my solution, please rate my solution on Fixya.
Nov 19, 2010 | Amana Washing Machines
My Bosh washing machine has excessive vibration according the the level i put on the top of the washer it is level, but still seems to walk accross the floor on the final spin cycle.
it may be level but if the feet are not adjusted to be tight to the floor this will cause it to walk so try adjusting the feet then lock the locking nut I am sure you will find 2 that are not adjusted tight enough.
Feb 05, 2010 | Washing Machines
Maytag pav2300 spin cycle spins unbalanced and walks
I have the same problem from day one........... help
Dec 16, 2009 | Maytag PAV2300 Top Load Washer
Model MAH9700 - Washer travels across floor in the spin cycle
I suppose that the repairmen would know than I would, but I do know that any washing machine that is not level will walk and vibrate and really shutter on the spin cycle. I would try to level (using a level on the top part of the machine that is flat, if there is such a portion) the machine so that all four feet (pads) are secure with their locking nuts up against the body so that they can't turn and cause the machine to go out of level.
Sorry I can't be of more help.
Oct 12, 2009 | Maytag Neptune MAH9700 Front Load Washer
WHEN IT SPINS IT WILL WALK ACROSS THE FLOOR
the washer is not getting a balanced load need to adjust the clothes inside so it wont jog
Jun 02, 2009 | Washing Machines
Machine knocks and walks when spinning a small load
amke sure it is level and on a solid floor with little bounce.
Jan 23, 2009 | Admiral AAV7000A
Maytag neptuneMAH9700 front load washer
Another computer generated flaw.The worst thing is alot of times that "flaw" can be a costly one
May 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
