Question about Toshiba CX35F60 35" TV
I have a 35in Toshiba tv and it come on but have a stright line in the middle of tv.
  • 189 Answers
HELLO
If the line is VERTICAL and at the centre of the screen it is called LINE COLLAPSE, but when the line is HORIZONTAL this is called FIELD COLLAPSE.
It may be dry joints on the field/frame output IC or it may have gone open circuit. I know that the field/frame output IC's can be obtained, but if you are no good with a soldering iron then you'll have to put it in for service.
GOOD LUCK WITH IT (:-)
Posted on Oct 06, 2009
White line in middle of screen on a cx32h60 toshiba tv
The vertical sweep output is absent. Check its vertical output section circuit for the fault. Check all the solder terminals of that section, and resolder them by applying a little more solder. Take special care to the solder terminals of the vertical output IC. If these do not help you, check and replace the vertical output IC.
Jul 07, 2012 | Toshiba CX32H60 TV
MY 35IN COME ON PICTURE AND EVERYTHING WAIT 10 SECONDS AND GOES OFF 35IN TUBE ABOUT 15 YEARS OLD
There is likely something wrong with the tube itself. It could be a short that is only there when the line warms up (10 seconds is plenty considering the amount of power that runs through it) or the CRT has a crack.
If you want to continue with this type of TV there are quite a few reliable TV repair companies in almost every mid to large town around the US. If you don't want to invest in repairing a 15 year old TV (not a bad life span for electronics by the way) then you could very likely find a 32"-37" LCD TV at your local electronic store that is reasonably priced.
May 23, 2011 | RCA Televison & Video
We have a 52" Toshiba
This problems is not the causes by a human or an objects by hitting the LCD screen panel wright?If,yes this problems can't be repair,the LCD screen panel it dead.The tv now,only can be used as spare parts,not worth as a whole tv anymore.If tv it develope all these colors lines by it self?Yes,this tv can be repair,the board call the T-Con decoders board is the causes and the problems.This T-Con decoders board sit right at the middle botton of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-Con decoders board for the replacement.
Dec 03, 2010 | Toshiba Televison & Video
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Yellow line
if you turn off the set can you still see the line in the screen if so you have burn from loss of scan
Mar 03, 2008 | Toshiba 32AF43 32" TV
Toshiba MW27FN1
That problem is in the vertical section. Check for leaky or dry capacitor(s). Check the capacitor(s) with values less than 50uF.
Good Luck.
Jan 20, 2008 | Toshiba 24AF41 24" TV
Televison & Video Logo
136 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
