Mitsubishi WS-65809 65 in. Rear Projection Television
Problem for Mitsubishi WS-65809 65 in. Rear Projection Television
Ws65909 powers off about 3 sec after power on
By danielrbd on Oct 06, 2009
I followed the instructions to get the diag code and the blinking lights said 1-2.
We've had the convergence ICs replaced about a year ago. The set was working fine last night, and this morning it was failing.
Comments:
Oct 06, 2009
- OK.. I just tried to power it on and then did the diag again and now it blinks 2-2.
Oct 06, 2009
Solution #1
posted on Oct 06, 2009
Not Rated)
digitaldump
Rank: Guru  Televisions & Videos  Expert
Rating: 92%, 67 votes
a code will always read 12-normal if you just plugged the tv in. it has to try to turn on then shut itself down to log a code. Or shutdown is caused by something the tv cannot detect . Or a front panel button has failed- does the green light turn on for a second when you hit the power button on the remote? if not try unplugging the front keypad behind the speaker cover.
Comments:
Oct 10, 2009
- 22 low voltage short protect .. its gonna be convergence again. that model has 1 convergence i.c STK393-110 and 2 picofuses rated 5A near the power supply that will need to be replaced plus if any 3.9 ohm resistors near the conv. i.c. looked burned they should be replaced too. make sure its an amp from mitsubishi that is used in the repair . generic amps can be gotten for much cheaper but there is a good reason that they are cheaper. also it is important to use enough heatsink compound but just as important to apply enough pressure to the amp to make the aluminum back of the amp touch the aluminum heatsink as possible.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-65809 65 in.
Questions and Unsolved Problems for Mitsubishi WS-65809 65 in.
Do you recommend Mitsubishi WS-65809 65 in. Rear Projection Television?
Answer
Answer
The TV will work for a while and then the picture will get lines in it and then the tv will shut... (More)
Answer
My TV picture just lost normal viewing and now I see grean lines going across the screen at an angle... (More)
Answer
The TV won't turn on. It clicks on and then clicks off within a second or so. One time it wouldn't... (More)
Answer
Is there a certain connector avail to connect my VS-60803 TV to a hd Blue ray player
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
