DVD player only plays in black and white on Soniq 42'' Plasma TV. (Have tried 3 different players all have the same problem)
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 157 Answers
The color loss is most likely due to a NTSC/PAL compatibility issue. If you bought the players overseas in a PAL region (http://upload.wikimedia.org/wikipedia/commons/0/0d/PAL-NTSC-SECAM.svg) and the TV is NTSC or vice-versa, there will be a color loss. Thiss because the different regions have different formats and when you go from one to the other, the color does no transfer over. You can buy a PAL to NTSC or NTSC to PAL converter to fix this issue.
Posted on Oct 06, 2009
2 Suggested Answers
lukster
  • 217 Answers
SOURCE: my dvd player keeps coming up in black and white
sounds like the video processors on the input are bad
Posted on Apr 30, 2007
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
PANASONIC TH37PX POB DVD ONLY PLAYS IN BLACK AND WHITE
alot of times u need to change the settings in your dvd player it has 2 video setting it will have 3 options pick auto and u will get colot its in your dvd meue not the tv....................
Feb 08, 2013 | Panasonic TH37PX60B TV
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
I've a Panasonic 42' Plasma tv purchased recently and when I connect my Comcast DVR box via Composite A/V connection, I see only black n white images..
Be sure the 3 video wires are color matched on both ends. Try a different cable. Connect another device like dvd player to that same Component input if it's ok then cable box is the problem. If still B/W then replaced a/v or main board.
Nov 23, 2009 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
We have a panasonic 42 inch plasma, less than 3 weeks old. When connected to our play station or dvd player, there is a white line at the top left of screen, only half way accross then stops. Tried...
Try changing the video output mode of the playstation and dvd player from CVBS (often called composite or video) to RGB. this should sort the problem.
Oct 06, 2009 | Panasonic Televison & Video
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Black & White picture for DVD
When using the Component outputs on the player, make sure they are enabled in the player menu system (or sometimes there is a rear panel switch and sometimes both), as most players default the Component outputs to off. Even when the Component outputs are off, you will often get a color-distorted signal out as many players share circuitry between the various outputs.
May 19, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Prolem with attached DVD player
u are using composite red,white,yellow. then connect it on video1. as there is only 1 yellow connectore on the tv.
Jan 23, 2009 | Sanyo DP42746 42 in. Plasma Television
Black and white images from dvd player
after a lot of patience ,perseverance and switching around of numerous cables,we were able to rectify the problem.Now all is well.Thanks for your concern and for asking!
Jan 10, 2009 | Samsung SPN4235 42 in. Plasma HDTV
My dvd player keeps coming up in black and white
Apr 28, 2007 | Hyundai ImageQuest HQP501HR 50 in....
Televison & Video Logo
246 people viewed this question
Top Televison & Video Experts
Electro Med Services...
