Question about Kenmore Washing Machines
Kenmore Elite HE3t, the hot water continues to run into the washer even when the cycle is over and or the washer is off. Had to turn the hot water off at the wall?
    President:
  • 1,304 Answers
Your hot water valve is stuck open the one inside the machine
Posted on Oct 06, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Nov 28, 2010 | Kenmore Washing Machines
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite front loader has hot and cold water reversed
I assume you verified the hoses are not crossed at the back of the machine??
:D
A better troubleshooting method is to call for a cycle of hot water and check that the proper solenoid on the water valve is being sent the signal. If it is, the water valve should be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite he3t wills with water when off
The electric valve (solnoid) is stuck partly open. Happens a lot with hard water. If that's the condition of your water, you can try turning off the hot and cold water, disconnect the hoses from the valve, leaving the other end connected to the washer. Drain the water out of the hoses and pour an ounce or two of CLR down the hose. Let it stand for a few hours or overnight. Hook up again and run at least a couple cycles on small load.
If it doesn't seem to fix it, you'll probably need to replace the valve.
Sep 23, 2009 | Kenmore Washing Machines
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t code problem
check your water supply make sure that you have both hot and cold water on at all times. Pull the hoses off and see if the screens on the water valve in the back is clogged.
Aug 10, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
