Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
2004 Polaris 600 edge touring Perc reverse not working properly. Intermitent going in and out of reverse?
Check your engine idle speed..if idling too low it will not engage also check your belt deflection if too tight it will cause the engine speed to be too low causing the no reverse condition
Posted on Jan 24, 2010
  • 3 Answers
You will have to make sure that the helix you are using is notched properly for reverse or if the helix has been changed it may not have been changed to one that supports ER (electronic Reverse)
Posted on Jan 16, 2010
My PREC reverse does'nt work ! tried a new switch on handle bar ,but did not work ! what else my i look for ?
Posted on Jan 02, 2010
Why would my Polaris snowmobile overheat?
My sled overheated - HCS Snowmobile Forums
www.hardcoresledder.com > ... > Rush/Switchback (Pro-Ride Chassis)
Jan 6, 2013 - 12 posts - ‎3 authors
Hey guys, I was out riding my sled yesterday, and out of no where, it threw a code, and it went into limp ... I would be worried about where did the coolant go? ... (Knowledge + results / corrected HP)Polaris + Als input = WGAF ... overheating
Feb 23, 2013
05 Polaris Switchback 800 overheated
Dec 23, 2010
Overheating...
Dec 23, 2008
2001 xc 600 overheating
Nov 29, 2006
More results from www.hardcoresledder.com
02 800 rmk overheating - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris-snowmobiles/67778-02-800-rmk-o...
Mar 4, 2012 - Does anyone know where I can get free service manuals for my sled so ... for a 05 polaris edge touring but i have used it to fix my 02 edge 600. Edge 600 overheating
Jan 2, 2013
Snowmobile Overheat Problem :( F8 LXR
Jan 16, 2012
2000 touring 600 overheating
Jan 13, 2011
need help with overheating issue
Nov 20, 2005
More results from www.snowmobileforum.com
800 Pro RMK, overheating, coolers... a
Jan 01, 2016 | Winter Sports
I have a polaris 340 edge touring it cuts out on 1 cylinder idiling and when it slows down on grades and in deep snow
I believe you are going to find out that your PTO Cylinder has lost compression and when it gets under load, it is not able to function properly. Do a Compression Test and you will find that the PTO Cylinder is going to be well below 90 and your Recoil is going to be right around 110-120. The Repair is not difficult and only takes 4 hours when you get rings installed. I would also recommend that you purchase a new piston with rings, normally you are going to see Piston Slap on the Walls that will prolong the life of the Engine if you do it right the first time.
Feb 11, 2014 | Polaris 2004 EDGE Touring 340
Polaris 2003 600 classic perc rverse problem
my 2003 polaris 550 indy's reverse doesn't work maybe once in a great while it will work but like tonight i rode for about 1 hour and tried to put it in reverse and it didnt work it died down and stalled out then started it back up and tried it again and it went forward i need help and information
Nov 21, 2012 | Polaris New Genuine Polaris Snowmobile...
I have a 2004 polaris prox2600 snowmobile with perc reverse and every time i engage the reverse button the sled shuts off any ideas would be greatly appreciated
did you let the sled warm up first? If the sled is'nt warmed up flip the choke lever while its running and quickley press the reverse button make sure you shut choke back off or you can load up your sled. Good luck let me know
Jan 20, 2010 | Polaris New Genuine Polaris Snowmobile...
Polaris Sportsman 600 won't go into Park
Might need to change the needle bearings on the reverse shaft inside gearcase (transmission).
Jun 17, 2009 | Polaris ATV
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
1,183 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
