Question about Photography
Nikon F55 camera
No auto focus and indicating dot in viewfinder not stationary
  • sail 456 Dec 23, 2007
    not worth $9.99
  • Anonymous Dec 23, 2007
    tried 3 different lenses, and cleaned contacts, viewfinder indictor keeps blinking as it goes from infinity to min.and back and when manually focused.
  • 667 Answers
You should try another lens. It sounds like a communication problem between the camera and the lens
Posted on Dec 23, 2007
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Nikon F65 won't auto-focus or take shots
You're on the right track with oxidation. Try cleaning the contacts in the body and on the lens with contact cleaner, and let it dry. Remove the battery, and clean the contacts inside the camera.
Mar 09, 2017 | Nikon F65 35mm SLR Camera
The screen of the viewfinder has a black dot.. i tried to clean it but it cant be removed,..how can i removed it?
Remove the lens of your camera, do it in a clean room, look at the mirror insie the lens to see if the dot is not there rather that on the outside of your viewfinder.
If it is not there it might be on the inside part of the focusing screen. Still inside the camera look at the upper part of the body, the focusing screen looks opaque.
If you still cant find the dot it might be on the inner side of the focusing screen.
Here is a tutorial on how to remove it on a d70 it is essentially the same thing on your camera.
Otherwise it can also be on the inner part of the viewfinder. In this case I recommend to send the camera to a repair shop as the removing of the viewfinder seems to be more difficult on the d3000 than on other camera.
Hope this helps.
May 30, 2011 | Nikon D3000 10.2 Megapixels SLR Digital...
My Canon EOS 450D shows busy while trying to click on AF auto mode and it does not click at all.
There are several contributing factors to this problem and I'll try to list a few that may be the cause.
All Canon EOS camera auto focus modes us contrast to focus this means simply that no contrast there is no focus. There is a small green dot in the lower right corner of the viewfinder that will come on and stay on solid when auto focus as been achieved. By default the shutter will not operate "click" if auto focus has not been made.
Here are a few examples of where auto focus will ether search (focus back and forth) or fail completely.
A solid painted wall, glass between the camera and subject, mirror, chrome, any large body of water, clear sky. Another place you wouldn't expect is clear skin in your subjects face or body.
Cameras with multiple focus points and set to other then the middle will have a problem if the photographer is still attempting to use the center focus point.
Look for the green dot in the lower right corner of the viewfinder that's your focus confirmation.
Apr 09, 2011 | Canon EOS 450D Digital Camera
I have the Olympus E-510. I haven't used it for a while but I have recently had a baby, so I've pulled it out from its hiding spot. The problem is, when I look through the viewfinder it's all blurry and I...
First make sure that the viewfinder glass is clean. If that is not the problem, it may be that the diopter adjustment has been accidentally changed. On the right side of the viewfinder screen is a very small knob. This adjusts the focus of the viewfinder to your vision. Aim your camera at a stationary object and let the camera auto focus. Look throught the viewfinder and turn this knob one click at a time until the image is clearest to you. Hope this helps.
Aug 05, 2010 | Olympus EVOLT E-510 Body Only Digital...
Will the Quanta 28-200 for the Nikon n75 work on the Nikon D5000?
Yes and no. I assume the lens is of more or less the same vintage as the N75? If so, the lens will fit onto the D5000. All of the camera's exposure and metering modes will work properly. However the lens lacks an interal focus motor and thus will not autofocus on the D5000. You can focus manually, and the green focus indicator in the viewfinder will continue to work.
Apr 22, 2010 | Quantaray 28-200mm f/3.8-5.6 for Canon AF
My nikon f55 wont focus
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
Jul 19, 2009 | Nikon N55 35mm SLR Camera
The auto focus is not working on my Nikon D50
I assume the AF/M switch on the body is set to AF as well? This has not been mentioned but the D50 has two drive systems for AF.
Feb 25, 2008 | Nikon D50 Digital Camera
Flashing red square area in viewfinder.
No, I don't think so, there could be differences between the Auto and the P setting. But the red flashing is where your camera is currently focusing on. It's possible that the black was indicating the focus box, but it was not latched on to something with complete focus, which then is indicated by the red flashing. Check this link to read up further on this. I may not have pinpointed it exactly, because I have a D70s, but that's what I found so far. You'll maybe have to reset everything and see if it's still there, otherwise, it's a setting. =)
Nov 20, 2007 | Nikon D40x Digital Camera
Photography Logo
115 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
