Question about kawasaki Full Suspension Mountain Bike Men
Headlight won't turn on.
00 Kawasaki ZX12R. Headlight does not turn on. everything works but for some reason the headlight does not. I already checked all fuses and they are all good. I also tested the headlight on my other Kawasaki and the headlight unit works. what else can i do?
  • 20 Answers
Try wire brushing the connections
Posted on Oct 06, 2009
  • homerv6472 Jul 26, 2011
    Its the relay assembly 27002-1086 £16-00 . Mine just lost dipped beam but high ok. Just need to know where its located.:)
Headlight does not come on
Check the light switch , wiring circuit for broken wires ,loose connection or corrosion or even a blown headlight bulb .
Sep 18, 2014 | Yamaha Xv1100 Virago Xv 1100 1989-1998...
Having trouble getting headlight to come on
Headlight will not come on until bike is running and charging system is functioning properly. Three things come to mind:
1. The charging system may not be working and therefore not triggering the relay in the junction box.
2. The headlight relay in the junction box may have gone bad.
3. The fuse may be blown.
If you suspect the relay, you can bypass it by moving the blue wire to the empty hole in the plug going to the junction box. This will make the headlight come on when the key is turned on instead of when the motor starts.
Jul 13, 2014 | 1995 kawasaki VN 750 Vulcan
2001 Kawasaki VN 800 Vulcan Drifter wiring diagram
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, dim or surges from bright to dim to bright the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty headlight relay.
9. Faulty wiring between battery positive and headlight bulb socket.
10. Weak charging alternator/generator/lighting coil.
11. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2001 Kawasaki VN 800 Vulcan Drifter wiring diagram Google Search
Kawasaki Motorcycle Wiring Diagrams
KAWASAKI VN800 Service Manual
OEM Parts for Kawasaki
Kawasaki VN800 Owner Manual
Jul 08, 2017 | 2001 kawasaki VN 800 Vulcan Drifter
03 zx12r headlights not working. Put new wiring harness on and new junctin box.
What about the ignition switch?? The get burned contacts and the headlight runs through it.
Aug 13, 2013 | kawasaki Motorcycles
Have 99 chevy silverado 1500 I have a headlight problem all the other lights work but headlights won't turn on
-Check "headLight fuse"
-Check connector at the headlight.
-Check the bulb. (It could burn out)
Mai
Apr 03, 2013 | 1999 Chevrolet Silverado 1500
Ninja 250r headlight, does bike need to be running for it to work
your lights should always work with the key in on position for safety reasons, eg if you had to pull over and it was dark you would turn the engine off but would still need lights.
Nov 10, 2009 | 2001 kawasaki ZX-6R Ninja
My headlight dont work wires diconnected also tail light and brak light dont work fuses are good any ideas? I tried everything
not wired properly.. temporarily splice a positive constant wire.. and hook to headlight.. to rule out headlight not working.
mess around with a tester (drawing a blank on actual name) but check to see if you're even getting power down to those components..
Aug 23, 2009 | 2001 kawasaki ZRX 1200 S
Headlight not working fuse good bulb good no power to switch
i had the same same problem with my 1992 vulcan 750. more than likely it is your reserve lighting devive located on the right side battery box. have you had a problem with your regulator/rectifier lately or a power surge of some type?
May 19, 2009 | 1992 kawasaki VN 750 Vulcan
Headlight wont light
Hi and welcome to FixYa,
Depending on the version, normally there would be two (2) relays for most Kawasakis that control the headlight(s). Often the hi-lo relays (with white connectors) would be behind the gauges. Again depending on the model, some would not have a headlight on/park/off but only hi-lo as the headlights automatically switch on when the engine is running.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 27, 2008 | 1998 kawasaki ZX-6R Ninja
kawasaki Full Suspension Mountain Bike Men Logo
288 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
