Question about Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea
My scooter will not work when you select reverse , i need to go forward and immediatly go into reverse to make it work ,,why ?
  • Shoprider Master
  • 1,271 Answers
It sounds like the speed pot is faulty, or otherwise known as a wig wam,
it sounds like its worn or simply come loose, there should be a allen screw in the side of the throttle lever, when in central position , tighting up the allen screw .
Also check the connection between the pot and main board it plugs into.
Regards
Gewiz.
Posted on Oct 06, 2009
My golden companion 2 Gc 321 goes forward when i push reverse and goes reverse when i push forward
Sounds like the motor cables are in reverse at the controller. Check that the red is in the positive and the black wire is in the negative on the controller.
Aug 12, 2014 | Golden Technologies Golden Companion 2 -...
Put in new batteries status light blinks no forward or reverse
The blinking is a flash code, maybe you should check the free wheel lever is in the drive position."hard to manually push"
Scooter Doctor App
May 31, 2014 | Pride Value Line Revo Scooter 3 Wheel
Why does my scooter stick in reverse & wont go forward
Your wigwag pot sounds faulty you can very often buy a good used one on eBay
Apr 24, 2014 | Pride Celebrity X 3-Wheel Electric Scooter...
Scooter won't reverse and makes clicking sound by the controller by the electric motor
There is a servo which switches the transmission from forward to reverse and it needs replaced.
murf427
Aug 01, 2012 | Electric Mobility Health & Beauty
Work all days yesterday, this morning went out to van, got to work and it would not move, lights come on flash but will not move
The code 6 failure code is the toggle throttle [engager] isn't in the neutral position when power is applied to the scooter. If the engager doesn't return to the neutral position as soon as you turn the key on the scooter would start to move, that woul
Engager
1. Check connections on red, white and black wires at crimps and soldered joints. (Flash Code
7)
2. Use meter to check for:
- White & Red: 5k1 + 10%
- Red & Black: 2.5k1 (approx.)
- White & Black: 2.5k1 (approx.)
3. With meter between Red & Black, squeeze engager forward. Resistance should go from 2.5k
down to 01 smoothly.
4. With meter between White & Black, squeeze engager reverse. Resistance should go from
2.5k down to 0 1 smoothly.
5. Check voltages (with key on):
- Forward - Red- 4.5V + .1V
- Neutral - Black- 2.5V + 0.1V
- Reverse - White - .5V +.1V
If using a Test Harness - White & Red: 5k, Forward - Red & Brown: 2-5k, Reverse - White &
Brown: 2-5k.
1. Use Red & Brown squeeze engager slowly forward 25 down to 0 slowly.
2. Use White & Brown squeeze engager slowly reverse 25 down to 0 slowly. Make sure dial
speed is set to10.
Jul 25, 2012 | Pride Jazzy Select Gt Scooter
Go Go Scooter travels in reverse, but when going forward it comes to an abrupt stop every few seconds. Everything else appears to work normally. Any ideas?
csr4 Well it could be the throttle pot or the speed control pot My leanings is toward the throttle pot since it works in reverse with the speed pot not being changed but not forward. when you are just changing the position of the throttle to forward thereby changing the pot wiper and getting the error. Contact Pride about the problem at 1-800-800-8586 and ask for Tech support for scooters and explain your problem to them. I hope this helps
Oct 02, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Goes in reverse but not forward
hi, that sounds like the scooter
a. the speed pot is faulty (Wig wam) thumb throttle , check just in case there a reverse switch,
b. been taking apart and reassembled incorrectly.
Regards
GeWiz.
Jul 03, 2009 | Pride Mobility Victory 3 Wheel Electric...
Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
Jun 03, 2009 | Pride Value Line Revo Scooter 3 Wheel
Shoprider Mobility Products, Inc. Hero 3-Wheel Scooter with Swivel Seat and Curved Tiller Blue 1ea Logo
249 people viewed this question
Top Shoprider Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
