Question about Car Audio & Video
Car Stereo Hi, I have a 1998 fiat cinquento, bought with the stereo taken out. I have located all the speaker wires and the permanent 12v live and negative but can't find a 12v ignition live. Where can i connect to to give me this imput Thanks Elliott
    Problem Solver:
  • 6 Answers
Elliott, You can pick up this ignition "hot" connection on the fuse box at the hot side of any fuse labeled accessory or of course radio or stereo. Most fuse boxes have a male connection just for this. Barring that you can hook it along side any component on the car that only works with the key or or better yet something that only works with the key switch set to accessory.
Posted on Dec 25, 2007
Trying to install stereo in 01 impala. I need to know the stereo wiring diagram. I keep reading that the yellow is 12v constant but have no yellow wire. Any help? Factory harness was cut out -______-
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: White
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Oct 31, 2016 | Cars & Trucks
Trying to hook up aftermarket stereo with no factory harness. How can I go about wiring my new stereo wires or my replacement harness (with module) to my car's already existing loose stereo wiring??
Hi Daniel
You need to test & label all the loose wires.
Use a multimeter in Ohms mode to place a tickle of electricity to each speaker wire. you should hear each speaker crackle. (Multimeters only use a 9v battery internally)
Label each pair of wires for speakers.
Their color coding may help. Keep the negative & positive wires to the speakers correct so that the speakers all travel in a forward motion together or you will have distortion from one speaker that is out of phase with the others.
You will also have a permanent +12v line and a Ignition Key +12 volt line.
One keeps the station memory etc when the ignition key is off.
Cheers
Car Stereo Wiring Explained In Detail
Car Stereo Wiring Basics
How to Install Replacement Car Stereo
Mar 01, 2016 | Cars & Trucks
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
What is the color codes for the wiring harness of a 1998 ford zx-2 stereo?
1998 Ford Escort ZX2 Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: Green
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: White/Orange
Car Stereo Amplifier Location: Under the driver seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
Sep 26, 2010 | Ford Escort Cars & Trucks
Wiring for 1998 dodge durango car stereo
Hi there:Check this on 1998 Dodge Durango Car Audio Wiring Diagram:
Car Radio Battery Constant 12v+ Wire: Red/BlueCar Radio Accessory Switched 12v+ Wire: Red/WhiteCar Radio Ground Wire: N/ACar Radio Illumination Wire: Black/YellowCar Stereo Dimmer Wire: OrangeCar Stereo Antenna Trigger Wire: N/ACar Stereo Amp Trigger Wire: GreenCar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: 6 1/2" SpeakersCar Audio Front Speakers Location: DoorsLeft Front Speaker Positive Wire (+): Dark GreenLeft Front Speaker Negative Wire (-): Brown/RedRight Front Speaker Positive Wire (+): Brown/YellowRight Front Speaker Negative Wire (-): Brown/Light BlueCar Audio Rear Speakers Size: 6 1/2" SpeakersCar Audio Rear Speakers Location: Rear DoorsLeft Rear Speaker Positive Wire (+): WhiteLeft Rear Speaker Negative Wire (-): Dark Blue/RedRight Rear Speaker Positive Wire (+): Brown/WhiteRight Rear Speaker Negative Wire (-): Brown/Orange
Hope helps.
Sep 05, 2010 | 1998 Dodge Durango
AM FM CD DET FACE CAR STEREO: installed an alpine stereo in my mustang and every...
That's because the memory wire has not been connected to a permanent live supply.
There will be an ignition switched 12v supply and a memory wire. The first is yellow on many brands and the second is red, but you need to refer to your fitting manual to check or look directly at the wiring harness as the wires are often individually labelled.
Since they both take 12v some folks mistakenly think that they can just be piggy-backed to each other and feed from the same supply. They can, but only if it's to a permanent live feed but that then leaves the risk of the unit being left switched on when the car is parked and draining the battery.
May 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
How to install into my 1993 ford probe?
Here are the factory wiring colors match these to the aftermarket names (12v to 12v Ign - Ign, etc)
1993 Ford Probe Car Radio Stereo Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Radio Ground Wire: Black/Pink
Car Radio Illumination Wire: Orange
Car Stereo Antenna Trigger: Light Green/Yellow
Left Front Speaker Positive Wire (+): Blue/Green
Right Front Speaker Positive Wire (+): Blue/Black
Right Front Speaker Negative Wire (-): Blue/Orange
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Green/Orange
Right Rear Speaker Positive Wire (+): Green/Yellow
Right Rear Speaker Negative Wire (-): Green/Blue
May 26, 2009 | Car Audio & Video
Wiring a stereo
Here is the radio wiring color's and what they do, all have the harness installed.
Car Radio Constant 12V+ Wire: Light Green
Car Radio Switched 12V+ Wire: Yellow/Black
Car Radio Illumination Wire: Light Blue/Red
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger N/A
Car Radio Amp Trigger Wire: Blue
Front Speakers Size: 6 1/2′
Left Front Speaker Wire (+): Orange/Light Green
Left Front Speaker Wire (-): Light Blue/White
Right Front Speaker Wire (+): Dark Green/Orange
Right Front Speaker Wire (-): White/Light Green
Rear Speakers Size: 5′ x 7′
Rear Speakers Location: Side Panels
Left Rear Speaker Wire (+): Gray/Light Blue
Left Rear Speaker Wire (-): Tan/Yellow
Right Rear Speaker Wire (+): Orange/Red
Right Rear Speaker Wire (-): Brown/Pink
Nov 12, 2008 | 1998 Mazda Pickup
Car radio/cd player replacement, wiring problem
Yes. Both leads need to have +12v for the device to function.
Yes. You can run a bypass to the battery to make it work.
Mike
Jun 28, 2008 | Car Audio & Video
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
