Question about kawasaki Garden
The blades dont meet coming back.
Can anyone tell me where i can get replacement blades for kawasaki hedge trimmer I cant find them anywhere. thanks
  • 437 Answers
Go to www.precisionope.com. Put your model information It asks for under oem parts. It will give you a parts list and diagram. See if you can find the part number there for the blades. That may be more help for what you are looking for.
Good Day.
Posted on Oct 10, 2009
Qualcast GGT350A1
Hi. It all depends on the Lawn trimmer. What brand is it? You can go back where you purchased the Lawn trimmer and ask them for an attachment blade to use for trimming hedges (did you mean hedges as in edges?). If they have blades specifically for your trimmer then you can do best if you have it attached to the trimmer by them experts. Otherwise if you do it yourself and it's not attached to the trimmer properly, and it comes off while spinning at high speed, you'd better run for your dear life, man! Hedge blades, like the one I have on my trimmer, are subjected to strenuous work and can come lose if not attached properly. The main part is that you treat hedge blades with care when doing the changes yourself. I am not saying that the blade which is similar to a saw blade, could come lose and separate itself from the shaft and fly towards you, but it's better to be safe than sorry. Poorly attached blades do come lose and fly like a flying saucer spinning and whirling in all direction like a yo-yo. Cheers
Michael
Jun 16, 2014 | Garden
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
Stihl HS45 hedge trimmer runs fine, blades move well, does not appear to cut hedge - what could be the problem ?
Dull blades! Lol, or they're not meeting eachother on each reciprocating stroke so there is no shearing action, much like a pair of scissors. Check to see if the blade bolts are too loose or is the blades are warped or if the cutting edges are simply too dull
Sep 24, 2013 | American Gardener Rh25 18" Readyhedger...
I need a manual for a Ryobi RHT500R Electric Hedge Trimmer 500 Watt - 55cm
I found the manual for the Ryobi hedge trimmer here: fr.ryobitools.eu/local/uploaded/catalog/e_RHT500R-600RL_UM_UK_v1.pdf . The bolts you describe hold the blade to the hedge trimmer's motor. They shouldn't have come loose. However you can check if any of the bolts are loose or have backed out of the motor.
I would suspect either a part of the branch is stuck between the blades. I have one of the small edge trimmer which gets noisy when I get a woody weed stuck in the unit. Unplug the trimmer and look at the blade for some bark stuck between the layers. On each side there are multiple blades that overlap at parts of the cutting cycle.
A parts diagram for the RHT500R is available here: http://www.magic-parts.co.uk/acatalog/Ryobi_RHT500R.php .
II hope this helps.
Aug 23, 2012 | Ryobi Garden
Blades will not operate when engine is running on my HS 81-R hedge trimmer
check the gear box where the motor meets the drive
Mar 29, 2012 | Garden
Blades dont move
If the motor is turning and the blades are not moving it is likely that you have sheared the pin on the gear.
Aug 23, 2011 | kawasaki Kht600d Gas Hedge Clipper Trimmer
Blade moves back and forth,but won't cut anything
Check the bolts or screws holding the blades together are tight but not so tight that they cant move.
Ensure blades are sharp.
Feb 02, 2011 | Poulan Ght225 25cc Gas Hedge Trimmer
Starts but won't speed up enough to run
If this is a 2 cycle engine the problem could be that the exhaust is clogged. Most 2 cycle engines have a spark arrestor on the muffler which clogs. could also be the exhaust port from the engine. remove the muffler and check it out.
May 15, 2009 | Garden
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Garden Logo
140 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
