Question about Polaroid i733LP Digital Camera
My camera wont turn on.
I tried to replace the batteries, but it doesn't work. whenever i press the on button, the camera makes some kinda of noise and it seems like it will turn on but doesn't.
should i try using rechargeable batteries?
    Problem Solver:
  • 12 Answers
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Posted on Oct 10, 2009
  • Priyesh Beohar
    Priyesh Beohar Dec 24, 2011
    Superb , i also facing same error. I fix it without the help of any professional. I pushed lens inside. it was jammed. I heard a click sound, then error and noise gone.
    Thanks to Emeral5468
When I turn the camera on, the lens goes in and out several times. Then the message comes "turn the power off and on again". I tried taking the battery out, pressing the power button for 15 sec...
Hi there this is Lens guide pin problem. 99% chacHi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated e is replacing the lens. but before that try these below.
Feb 01, 2011 | Sony Cyber-shot DSC-W170 Digital Camera
Canon PowerShot A480 won't take photo. Pressing on button camera on then pressing silver button to take photo when pressed down screen turns black no picture taken. Batteries new. This is the story; camera...
its just a matter of batteries...some are not powerful enough to operate the camera ....Try to change them and buy some real good ones..like Duracell or Tatra...do not make any compromises when buy the batteries...get the best cause these kinda cameras really require powerful ones...or ...try to get a set of rechargeable ...
Jun 20, 2010 | Canon Powershot A480 - Silver Digital...
When we press the on/off button, the camera make a
Make sure the battery or batteries are either fully charged or are new. If it still will not work, then the camera needs repair, and it may be better to sell it then for parts or repair, as is on a site such as Ebay.
Mar 03, 2010 | Fuji FinePix A850 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
My camera is off but the lens are still open but it wont work when i press the on button
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable.
Jan 09, 2010 | Kodak EASYSHARE M1063 Digital Camera
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
Screen shakes have to use track ball
Try turning off the device and take off the back cover and battery. make sure the camera button isnt stuck and try pressing it in a few times...it should kinda make a clicking noise.
reasemble the phone and turn it on by holding the red key for about 10 seconds or so and see if it still happens. if it does, call t-mobile at 1800-937-8997 for a replacement.
Jan 26, 2009 | HTC G1
Need help
Mine does the same thing. It takes a few minutes to realize it has new batteries. lol. Keep trying, it will eventually come on.
Sep 09, 2008 | Samsung Digimax D53 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
Camera wont turn on
If you drop it this it is one of two: 1) A hardware component in your Camera is broken and need to be replaced. 2) A small power surge caused the camera Controller not to be recognized. You should send it to maintenance as soon as possible to determine what exactly happened.
Jun 02, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Polaroid i733LP Digital Camera Logo
285 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
